I added a second disk to an existing Ubuntu VM and after adding the disk, powering off and back on I am getting an error no boot device. I suspect it is trying to boot from the newly added disk but I do not seem to be able to get into the bios to change the boot order. How do I configure a VM to change the boot disk. I am running truenas scale 22.12.4.2. Below is the output of the logs from the VM.
OS Version:TrueNAS-SCALE-22.12.4.2
Product:B550M Pro4
Model:AMD Ryzen 5 4600G with Radeon Graphics
Memory:62 GiB
2023-12-06 18:51:53.925+0000: starting up libvirt version: 7.0.0, package: 3 (Andrea Bolognani <eof@kiyuko.org> Fri, 26 Feb 2021 16:46:34 +0100), qemu version: 5.2.0Debian 1:5.2+dfsg-11+deb11u2, kernel: 5.15.131+truenas, hostname: truenas.local LC_ALL=C \ PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin \ HOME=/var/lib/libvirt/qemu/domain-1-3_plex \ XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-1-3_plex/.local/share \ XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-1-3_plex/.cache \ XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-1-3_plex/.config \ QEMU_AUDIO_DRV=spice \ /usr/bin/qemu-system-x86_64 \ -name guest=3_plex,debug-threads=on \ -S \ -object secret,id=masterKey0,format=raw,file=/var/lib/libvirt/qemu/domain-1-3_plex/master-key.aes \ -machine pc-i440fx-5.2,accel=kvm,usb=off,dump-guest-core=off,memory-backend=pc.ram \ -cpu host,migratable=on,host-cache-info=on,l3-cache=off \ -m 4096 \ -object memory-backend-ram,id=pc.ram,size=4294967296 \ -overcommit mem-lock=off \ -smp 2,sockets=1,dies=1,cores=2,threads=1 \ -uuid 0a08a709-9237-47e2-922b-ce1bc75e48ad \ -no-user-config \ -nodefaults \ -chardev socket,id=charmonitor,fd=35,server,nowait \ -mon chardev=charmonitor,id=monitor,mode=control \ -rtc base=localtime \ -no-shutdown \ -boot strict=on \ -device nec-usb-xhci,id=usb,bus=pci.0,addr=0x4 \ -device ahci,id=sata0,bus=pci.0,addr=0x5 \ -device virtio-serial-pci,id=virtio-serial0,bus=pci.0,addr=0x6 \ -blockdev '{"driver":"file","filename":"/mnt/HDD_store/NFS_share/template/iso/ubuntu-20.04.3-live-server-amd64.iso","node-name":"libvirt-2-storage","auto-read-only":true,"discard":"unmap"}' \ -blockdev '{"node-name":"libvirt-2-format","read-only":true,"driver":"raw","file":"libvirt-2-storage"}' \ -device ide-cd,bus=sata0.0,drive=libvirt-2-format,id=sata0-0-0,bootindex=1 \ -blockdev '{"driver":"host_device","filename":"/dev/zvol/HDD_store/plex-moj9ni","aio":"threads","node-name":"libvirt-1-storage","cache":{"direct":true,"no-flush":false},"auto-read-only":true,"discard":"unmap"}' \ -blockdev '{"node-name":"libvirt-1-format","read-only":false,"cache":{"direct":true,"no-flush":false},"driver":"raw","file":"libvirt-1-storage"}' \ -device ide-hd,bus=sata0.1,drive=libvirt-1-format,id=sata0-0-1,bootindex=2,write-cache=on \ -netdev tap,fd=37,id=hostnet0,vhost=on,vhostfd=38 \ -device virtio-net-pci,netdev=hostnet0,id=net0,mac=00:a0:98:6f:39:a6,bus=pci.0,addr=0x3 \ -chardev pty,id=charserial0 \ -device isa-serial,chardev=charserial0,id=serial0 \ -chardev spicevmc,id=charchannel0,name=vdagent \ -device virtserialport,bus=virtio-serial0.0,nr=1,chardev=charchannel0,id=channel0,name=com.redhat.spice.0 \ -chardev socket,id=charchannel1,fd=39,server,nowait \ -device virtserialport,bus=virtio-serial0.0,nr=2,chardev=charchannel1,id=channel1,name=org.qemu.guest_agent.0 \ -device usb-tablet,id=input0,bus=usb.0,port=1 \ -spice port=5900,addr=0.0.0.0,seamless-migration=on \ -device qxl-vga,id=video0,ram_size=67108864,vram_size=67108864,vram64_size_mb=0,vgamem_mb=16,max_outputs=1,xres=1024,yres=768,bus=pci.0,addr=0x2 \ -device virtio-balloon-pci,id=balloon0,bus=pci.0,addr=0x7 \ -sandbox on,obsolete=deny,elevateprivileges=deny,spawn=deny,resourcecontrol=deny \ -msg timestamp=on char device redirected to /dev/pts/0 (label charserial0) 2023-12-06T19:14:07.575842Z qemu-system-x86_64: terminating on signal 15 from pid 3901015 (/usr/sbin/libvirtd) 2023-12-06 19:14:08.176+0000: shutting down, reason=destroyed 2023-12-06 19:14:38.966+0000: starting up libvirt version: 7.0.0, package: 3 (Andrea Bolognani <eof@kiyuko.org> Fri, 26 Feb 2021 16:46:34 +0100), qemu version: 5.2.0Debian 1:5.2+dfsg-11+deb11u2, kernel: 5.15.131+truenas, hostname: truenas.local LC_ALL=C \ PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin \ HOME=/var/lib/libvirt/qemu/domain-2-3_plex \ XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-2-3_plex/.local/share \ XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-2-3_plex/.cache \ XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-2-3_plex/.config \ QEMU_AUDIO_DRV=spice \ /usr/bin/qemu-system-x86_64 \ -name guest=3_plex,debug-threads=on \ -S \ -object secret,id=masterKey0,format=raw,file=/var/lib/libvirt/qemu/domain-2-3_plex/master-key.aes \ -machine pc-i440fx-5.2,accel=kvm,usb=off,dump-guest-core=off,memory-backend=pc.ram \ -cpu host,migratable=on,host-cache-info=on,l3-cache=off \ -m 4096 \ -object memory-backend-ram,id=pc.ram,size=4294967296 \ -overcommit mem-lock=off \ -smp 2,sockets=1,dies=1,cores=2,threads=1 \ -uuid 0a08a709-9237-47e2-922b-ce1bc75e48ad \ -no-user-config \ -nodefaults \ -chardev socket,id=charmonitor,fd=35,server,nowait \ -mon chardev=charmonitor,id=monitor,mode=control \ -rtc base=localtime \ -no-shutdown \ -boot strict=on \ -device nec-usb-xhci,id=usb,bus=pci.0,addr=0x4 \ -device ahci,id=sata0,bus=pci.0,addr=0x5 \ -device virtio-serial-pci,id=virtio-serial0,bus=pci.0,addr=0x6 \ -blockdev '{"driver":"host_device","filename":"/dev/zvol/HDD_store/plex-moj9ni","aio":"threads","node-name":"libvirt-1-storage","cache":{"direct":true,"no-flush":false},"auto-read-only":true,"discard":"unmap"}' \ -blockdev '{"node-name":"libvirt-1-format","read-only":false,"cache":{"direct":true,"no-flush":false},"driver":"raw","file":"libvirt-1-storage"}' \ -device ide-hd,bus=sata0.0,drive=libvirt-1-format,id=sata0-0-0,bootindex=1,write-cache=on \ -netdev tap,fd=37,id=hostnet0,vhost=on,vhostfd=38 \ -device virtio-net-pci,netdev=hostnet0,id=net0,mac=00:a0:98:6f:39:a6,bus=pci.0,addr=0x3 \ -chardev pty,id=charserial0 \ -device isa-serial,chardev=charserial0,id=serial0 \ -chardev spicevmc,id=charchannel0,name=vdagent \ -device virtserialport,bus=virtio-serial0.0,nr=1,chardev=charchannel0,id=channel0,name=com.redhat.spice.0 \ -chardev socket,id=charchannel1,fd=39,server,nowait \ -device virtserialport,bus=virtio-serial0.0,nr=2,chardev=charchannel1,id=channel1,name=org.qemu.guest_agent.0 \ -device usb-tablet,id=input0,bus=usb.0,port=1 \ -spice port=5900,addr=0.0.0.0,seamless-migration=on \ -device qxl-vga,id=video0,ram_size=67108864,vram_size=67108864,vram64_size_mb=0,vgamem_mb=16,max_outputs=1,xres=1024,yres=768,bus=pci.0,addr=0x2 \ -device virtio-balloon-pci,id=balloon0,bus=pci.0,addr=0x7 \ -sandbox on,obsolete=deny,elevateprivileges=deny,spawn=deny,resourcecontrol=deny \ -msg timestamp=on char device redirected to /dev/pts/0 (label charserial0) 2023-12-06T19:47:51.263137Z qemu-system-x86_64: terminating on signal 15 from pid 3901015 (/usr/sbin/libvirtd) 2023-12-06 19:47:51.703+0000: shutting down, reason=shutdown 2023-12-06 19:49:03.365+0000: starting up libvirt version: 7.0.0, package: 3 (Andrea Bolognani <eof@kiyuko.org> Fri, 26 Feb 2021 16:46:34 +0100), qemu version: 5.2.0Debian 1:5.2+dfsg-11+deb11u2, kernel: 5.15.131+truenas, hostname: truenas.local LC_ALL=C \ PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin \ HOME=/var/lib/libvirt/qemu/domain-1-3_plex \ XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-1-3_plex/.local/share \ XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-1-3_plex/.cache \ XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-1-3_plex/.config \ QEMU_AUDIO_DRV=spice \ /usr/bin/qemu-system-x86_64 \ -name guest=3_plex,debug-threads=on \ -S \ -object secret,id=masterKey0,format=raw,file=/var/lib/libvirt/qemu/domain-1-3_plex/master-key.aes \ -machine pc-i440fx-5.2,accel=kvm,usb=off,dump-guest-core=off,memory-backend=pc.ram \ -cpu host,migratable=on,host-cache-info=on,l3-cache=off \ -m 4096 \ -object memory-backend-ram,id=pc.ram,size=4294967296 \ -overcommit mem-lock=off \ -smp 2,sockets=1,dies=1,cores=2,threads=1 \ -uuid 0a08a709-9237-47e2-922b-ce1bc75e48ad \ -no-user-config \ -nodefaults \ -chardev socket,id=charmonitor,fd=37,server,nowait \ -mon chardev=charmonitor,id=monitor,mode=control \ -rtc base=localtime \ -no-shutdown \ -boot strict=on \ -device nec-usb-xhci,id=usb,bus=pci.0,addr=0x4 \ -device ahci,id=sata0,bus=pci.0,addr=0x5 \ -device virtio-serial-pci,id=virtio-serial0,bus=pci.0,addr=0x6 \ -blockdev '{"driver":"host_device","filename":"/dev/zvol/HDD_store/plex-moj9ni","aio":"threads","node-name":"libvirt-1-storage","cache":{"direct":true,"no-flush":false},"auto-read-only":true,"discard":"unmap"}' \ -blockdev '{"node-name":"libvirt-1-format","read-only":false,"cache":{"direct":true,"no-flush":false},"driver":"raw","file":"libvirt-1-storage"}' \ -device ide-hd,bus=sata0.0,drive=libvirt-1-format,id=sata0-0-0,bootindex=1,write-cache=on \ -netdev tap,fd=39,id=hostnet0,vhost=on,vhostfd=40 \ -device virtio-net-pci,netdev=hostnet0,id=net0,mac=00:a0:98:6f:39:a6,bus=pci.0,addr=0x3 \ -chardev pty,id=charserial0 \ -device isa-serial,chardev=charserial0,id=serial0 \ -chardev spicevmc,id=charchannel0,name=vdagent \ -device virtserialport,bus=virtio-serial0.0,nr=1,chardev=charchannel0,id=channel0,name=com.redhat.spice.0 \ -chardev socket,id=charchannel1,fd=41,server,nowait \ -device virtserialport,bus=virtio-serial0.0,nr=2,chardev=charchannel1,id=channel1,name=org.qemu.guest_agent.0 \ -device usb-tablet,id=input0,bus=usb.0,port=1 \ -spice port=5900,addr=0.0.0.0,seamless-migration=on \ -device qxl-vga,id=video0,ram_size=67108864,vram_size=67108864,vram64_size_mb=0,vgamem_mb=16,max_outputs=1,xres=1024,yres=768,bus=pci.0,addr=0x2 \ -device virtio-balloon-pci,id=balloon0,bus=pci.0,addr=0x7 \ -sandbox on,obsolete=deny,elevateprivileges=deny,spawn=deny,resourcecontrol=deny \ -msg timestamp=on char device redirected to /dev/pts/0 (label charserial0) 2023-12-07T16:42:28.776566Z qemu-system-x86_64: warning: Spice: main:0 (0x55a8abb1e860): rcc 0x55a8abdf1210 has been unresponsive for more than 30000 ms, disconnecting 2023-12-07T19:04:41.728446Z qemu-system-x86_64: terminating on signal 15 from pid 8194 (/usr/sbin/libvirtd) 2023-12-07 19:04:42.172+0000: shutting down, reason=shutdown 2023-12-07 19:08:02.003+0000: starting up libvirt version: 7.0.0, package: 3 (Andrea Bolognani <eof@kiyuko.org> Fri, 26 Feb 2021 16:46:34 +0100), qemu version: 5.2.0Debian 1:5.2+dfsg-11+deb11u2, kernel: 5.15.131+truenas, hostname: truenas.local LC_ALL=C \ PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin \ HOME=/var/lib/libvirt/qemu/domain-1-3_plex \ XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-1-3_plex/.local/share \ XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-1-3_plex/.cache \ XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-1-3_plex/.config \ QEMU_AUDIO_DRV=spice \ /usr/bin/qemu-system-x86_64 \ -name guest=3_plex,debug-threads=on \ -S \ -object secret,id=masterKey0,format=raw,file=/var/lib/libvirt/qemu/domain-1-3_plex/master-key.aes \ -machine pc-i440fx-5.2,accel=kvm,usb=off,dump-guest-core=off,memory-backend=pc.ram \ -cpu host,migratable=on,host-cache-info=on,l3-cache=off \ -m 4096 \ -object memory-backend-ram,id=pc.ram,size=4294967296 \ -overcommit mem-lock=off \ -smp 2,sockets=1,dies=1,cores=2,threads=1 \ -uuid 0a08a709-9237-47e2-922b-ce1bc75e48ad \ -no-user-config \ -nodefaults \ -chardev socket,id=charmonitor,fd=37,server,nowait \ -mon chardev=charmonitor,id=monitor,mode=control \ -rtc base=localtime \ -no-shutdown \ -boot strict=on \ -device nec-usb-xhci,id=usb,bus=pci.0,addr=0x4 \ -device ahci,id=sata0,bus=pci.0,addr=0x5 \ -device virtio-serial-pci,id=virtio-serial0,bus=pci.0,addr=0x6 \ -blockdev '{"driver":"host_device","filename":"/dev/zvol/HDD_store/plex-moj9ni","aio":"threads","node-name":"libvirt-1-storage","cache":{"direct":true,"no-flush":false},"auto-read-only":true,"discard":"unmap"}' \ -blockdev '{"node-name":"libvirt-1-format","read-only":false,"cache":{"direct":true,"no-flush":false},"driver":"raw","file":"libvirt-1-storage"}' \ -device ide-hd,bus=sata0.0,drive=libvirt-1-format,id=sata0-0-0,bootindex=1,write-cache=on \ -netdev tap,fd=39,id=hostnet0,vhost=on,vhostfd=40 \ -device virtio-net-pci,netdev=hostnet0,id=net0,mac=00:a0:98:6f:39:a6,bus=pci.0,addr=0x3 \ -chardev pty,id=charserial0 \ -device isa-serial,chardev=charserial0,id=serial0 \ -chardev spicevmc,id=charchannel0,name=vdagent \ -device virtserialport,bus=virtio-serial0.0,nr=1,chardev=charchannel0,id=channel0,name=com.redhat.spice.0 \ -chardev socket,id=charchannel1,fd=41,server,nowait \ -device virtserialport,bus=virtio-serial0.0,nr=2,chardev=charchannel1,id=channel1,name=org.qemu.guest_agent.0 \ -device usb-tablet,id=input0,bus=usb.0,port=1 \ -spice port=5900,addr=0.0.0.0,seamless-migration=on \ -device qxl-vga,id=video0,ram_size=67108864,vram_size=67108864,vram64_size_mb=0,vgamem_mb=16,max_outputs=1,xres=1024,yres=768,bus=pci.0,addr=0x2 \ -device virtio-balloon-pci,id=balloon0,bus=pci.0,addr=0x7 \ -sandbox on,obsolete=deny,elevateprivileges=deny,spawn=deny,resourcecontrol=deny \ -msg timestamp=on char device redirected to /dev/pts/0 (label charserial0) 2023-12-09T12:40:09.885348Z qemu-system-x86_64: terminating on signal 15 from pid 7244 (/usr/sbin/libvirtd) 2023-12-09 12:40:10.643+0000: shutting down, reason=shutdown 2023-12-09 12:40:18.896+0000: starting up libvirt version: 7.0.0, package: 3 (Andrea Bolognani <eof@kiyuko.org> Fri, 26 Feb 2021 16:46:34 +0100), qemu version: 5.2.0Debian 1:5.2+dfsg-11+deb11u2, kernel: 5.15.131+truenas, hostname: truenas.local LC_ALL=C \ PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin \ HOME=/var/lib/libvirt/qemu/domain-2-3_plex \ XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-2-3_plex/.local/share \ XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-2-3_plex/.cache \ XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-2-3_plex/.config \ QEMU_AUDIO_DRV=spice \ /usr/bin/qemu-system-x86_64 \ -name guest=3_plex,debug-threads=on \ -S \ -object secret,id=masterKey0,format=raw,file=/var/lib/libvirt/qemu/domain-2-3_plex/master-key.aes \ -machine pc-i440fx-5.2,accel=kvm,usb=off,dump-guest-core=off,memory-backend=pc.ram \ -cpu host,migratable=on,host-cache-info=on,l3-cache=off \ -m 4096 \ -object memory-backend-ram,id=pc.ram,size=4294967296 \ -overcommit mem-lock=off \ -smp 2,sockets=1,dies=1,cores=2,threads=1 \ -uuid 0a08a709-9237-47e2-922b-ce1bc75e48ad \ -no-user-config \ -nodefaults \ -chardev socket,id=charmonitor,fd=37,server,nowait \ -mon chardev=charmonitor,id=monitor,mode=control \ -rtc base=localtime \ -no-shutdown \ -boot strict=on \ -device nec-usb-xhci,id=usb,bus=pci.0,addr=0x4 \ -device ahci,id=sata0,bus=pci.0,addr=0x5 \ -device virtio-serial-pci,id=virtio-serial0,bus=pci.0,addr=0x6 \ -blockdev '{"driver":"host_device","filename":"/dev/zvol/HDD_store/plex-moj9ni","aio":"threads","node-name":"libvirt-2-storage","cache":{"direct":true,"no-flush":false},"auto-read-only":true,"discard":"unmap"}' \ -blockdev '{"node-name":"libvirt-2-format","read-only":false,"cache":{"direct":true,"no-flush":false},"driver":"raw","file":"libvirt-2-storage"}' \ -device ide-hd,bus=sata0.0,drive=libvirt-2-format,id=sata0-0-0,bootindex=1,write-cache=on \ -blockdev '{"driver":"host_device","filename":"/dev/zvol/NVME-Pool/plex-cachvol","aio":"threads","node-name":"libvirt-1-storage","cache":{"direct":true,"no-flush":false},"auto-read-only":true,"discard":"unmap"}' \ -blockdev '{"node-name":"libvirt-1-format","read-only":false,"cache":{"direct":true,"no-flush":false},"driver":"raw","file":"libvirt-1-storage"}' \ -device virtio-blk-pci,bus=pci.0,addr=0x7,drive=libvirt-1-format,id=virtio-disk0,bootindex=2,write-cache=on \ -netdev tap,fd=39,id=hostnet0,vhost=on,vhostfd=40 \ -device virtio-net-pci,netdev=hostnet0,id=net0,mac=00:a0:98:6f:39:a6,bus=pci.0,addr=0x3 \ -chardev pty,id=charserial0 \ -device isa-serial,chardev=charserial0,id=serial0 \ -chardev spicevmc,id=charchannel0,name=vdagent \ -device virtserialport,bus=virtio-serial0.0,nr=1,chardev=charchannel0,id=channel0,name=com.redhat.spice.0 \ -chardev socket,id=charchannel1,fd=41,server,nowait \ -device virtserialport,bus=virtio-serial0.0,nr=2,chardev=charchannel1,id=channel1,name=org.qemu.guest_agent.0 \ -device usb-tablet,id=input0,bus=usb.0,port=1 \ -spice port=5900,addr=0.0.0.0,seamless-migration=on \ -device qxl-vga,id=video0,ram_size=67108864,vram_size=67108864,vram64_size_mb=0,vgamem_mb=16,max_outputs=1,xres=1024,yres=768,bus=pci.0,addr=0x2 \ -device virtio-balloon-pci,id=balloon0,bus=pci.0,addr=0x8 \ -sandbox on,obsolete=deny,elevateprivileges=deny,spawn=deny,resourcecontrol=deny \ -msg timestamp=on char device redirected to /dev/pts/0 (label charserial0) 2023-12-15T14:06:41.456167Z qemu-system-x86_64: terminating on signal 15 from pid 7244 (/usr/sbin/libvirtd) 2023-12-15 14:06:42.274+0000: shutting down, reason=shutdown 2023-12-15 14:11:57.928+0000: starting up libvirt version: 7.0.0, package: 3 (Andrea Bolognani <eof@kiyuko.org> Fri, 26 Feb 2021 16:46:34 +0100), qemu version: 5.2.0Debian 1:5.2+dfsg-11+deb11u2, kernel: 5.15.131+truenas, hostname: truenas.local LC_ALL=C \ PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin \ HOME=/var/lib/libvirt/qemu/domain-3-3_plex \ XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-3-3_plex/.local/share \ XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-3-3_plex/.cache \ XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-3-3_plex/.config \ QEMU_AUDIO_DRV=spice \ /usr/bin/qemu-system-x86_64 \ -name guest=3_plex,debug-threads=on \ -S \ -object secret,id=masterKey0,format=raw,file=/var/lib/libvirt/qemu/domain-3-3_plex/master-key.aes \ -machine pc-i440fx-5.2,accel=kvm,usb=off,dump-guest-core=off,memory-backend=pc.ram \ -cpu host,migratable=on,host-cache-info=on,l3-cache=off \ -m 6144 \ -object memory-backend-ram,id=pc.ram,size=6442450944 \ -overcommit mem-lock=off \ -smp 2,sockets=1,dies=1,cores=2,threads=1 \ -uuid 0a08a709-9237-47e2-922b-ce1bc75e48ad \ -no-user-config \ -nodefaults \ -chardev socket,id=charmonitor,fd=37,server,nowait \ -mon chardev=charmonitor,id=monitor,mode=control \ -rtc base=localtime \ -no-shutdown \ -boot strict=on \ -device nec-usb-xhci,id=usb,bus=pci.0,addr=0x4 \ -device ahci,id=sata0,bus=pci.0,addr=0x5 \ -device virtio-serial-pci,id=virtio-serial0,bus=pci.0,addr=0x6 \ -blockdev '{"driver":"host_device","filename":"/dev/zvol/NVME-Pool/plex-cachvol","aio":"threads","node-name":"libvirt-2-storage","cache":{"direct":true,"no-flush":false},"auto-read-only":true,"discard":"unmap"}' \ -blockdev '{"node-name":"libvirt-2-format","read-only":false,"cache":{"direct":true,"no-flush":false},"driver":"raw","file":"libvirt-2-storage"}' \ -device ide-hd,bus=sata0.0,drive=libvirt-2-format,id=sata0-0-0,bootindex=1,write-cache=on \ -blockdev '{"driver":"host_device","filename":"/dev/zvol/HDD_store/plex-moj9ni","aio":"threads","node-name":"libvirt-1-storage","cache":{"direct":true,"no-flush":false},"auto-read-only":true,"discard":"unmap"}' \ -blockdev '{"node-name":"libvirt-1-format","read-only":false,"cache":{"direct":true,"no-flush":false},"driver":"raw","file":"libvirt-1-storage"}' \ -device ide-hd,bus=sata0.1,drive=libvirt-1-format,id=sata0-0-1,bootindex=2,write-cache=on \ -netdev tap,fd=39,id=hostnet0,vhost=on,vhostfd=40 \ -device virtio-net-pci,netdev=hostnet0,id=net0,mac=00:a0:98:6f:39:a6,bus=pci.0,addr=0x3 \ -chardev pty,id=charserial0 \ -device isa-serial,chardev=charserial0,id=serial0 \ -chardev spicevmc,id=charchannel0,name=vdagent \ -device virtserialport,bus=virtio-serial0.0,nr=1,chardev=charchannel0,id=channel0,name=com.redhat.spice.0 \ -chardev socket,id=charchannel1,fd=41,server,nowait \ -device virtserialport,bus=virtio-serial0.0,nr=2,chardev=charchannel1,id=channel1,name=org.qemu.guest_agent.0 \ -device usb-tablet,id=input0,bus=usb.0,port=1 \ -spice port=5900,addr=0.0.0.0,seamless-migration=on \ -device qxl-vga,id=video0,ram_size=67108864,vram_size=67108864,vram64_size_mb=0,vgamem_mb=16,max_outputs=1,xres=1024,yres=768,bus=pci.0,addr=0x2 \ -device virtio-balloon-pci,id=balloon0,bus=pci.0,addr=0x7 \ -sandbox on,obsolete=deny,elevateprivileges=deny,spawn=deny,resourcecontrol=deny \ -msg timestamp=on char device redirected to /dev/pts/0 (label charserial0)
Product:B550M Pro4
Memory:62 GiB
