This Resource is available at:
https://forums.freenas.org/index.ph...ate-freebsd-vm-from-esxi-to-freenas-bhyve.72/
The original text is below. It may be out of date.
I moved my FreeBSD VM (v7) from ESXi 5.5.0 to bhyve under FreeNAS-11-MASTER-201709210509. Below are short instructions with my example.
p.s. You can remove vmdk, VirtualBox converted raw files and VirtualBoxJail. Now VM data lives inside ZVOLs
used material from
https://forums.freebsd.org/threads/51393/
http://justinholcomb.me/blog/2016/03/26/migration-to-freebsd-part4.html
m0nkey_ thanks for comments
- Prepare VM on ESXi. With your preferred method:
- shutdown VM
- remove all snapshots
- remove from ESXi inventory to avoid problems. Do not delete data files
- Copy ESXi VM virtual disk files. Mine had 5 virtual disks attached
-ssh root@esxihost
-scp -r /vmfs/volumes/datastore2/srv_10 root@freenas:/mnt/tank/vm
- Convert. I used jail under same FreeNAS box for this
- create a standard type jail. I named it VirtualBoxJail. Do not confuse it with legacy VirtualBox template
- add storage with a copy of ESXi virtual disks
- start this jail and install VirtualBox inside it using shell
pkg update
pkg install virtualbox-ose-nox11
- convert all vmdk hard drive files to raw image files
cd /mnt/srv_10/
VBoxManage clonehd srv_10.vmdk srv_10_bhyve_volume_1.raw --format RAW
VBoxManage clonehd srv_10_1.vmdk srv_10_bhyve_volume_2.raw --format RAW
- create ZVOLs for each VM disk same size like original + one 100 MB for EFI. We will need it to fix VM boot
- copy data from RAW files to ZVOLs repectively. I added a pipe via pv to see some progress but you can ommit that
dd if=/mnt/tank/vm/srv_10/srv_10_bhyve_volume_1.raw | pv -petr | dd of=/dev/zvol/tank/vm/srv_10_vol_1
dd if=/mnt/tank/vm/srv_10/srv_10_bhyve_volume_2.raw | pv -petr | dd of=/dev/zvol/tank/vm/srv_10_vol_2
dd if=/mnt/tank/vm/srv_10/srv_10_bhyve_volume_3.raw | pv -petr | dd of=/dev/zvol/tank/vm/srv_10_vol_3
dd if=/mnt/tank/vm/srv_10/srv_10_bhyve_volume_4.raw | pv -petr | dd of=/dev/zvol/tank/vm/srv_10_vol_4
dd if=/mnt/tank/vm/srv_10/srv_10_bhyve_volume_5.raw | pv -petr | dd of=/dev/zvol/tank/vm/srv_10_vol_5 - Assemble new bhyve VM
- create new VM
- configure nic
- add virtual CD. You will need to download and mount FreeBSD image on it to fix EFI boot
curl https://download.freebsd.org/ftp/releases/amd64/amd64/ISO-IMAGES/11.1/FreeBSD-11.1-RELEASE-amd64-disc1.iso
- add earlier created ZVOLs (EFI and all other VM disks)
- Fix EFI , mounting points and NIC names
- start VM. It should boot from attached FreeBSD iso. Start VNC session and Select Live CD. Now we will create EFI partition with image files.
- login with root. Check virtual disk names
dmesg | grep ada
- on that EFI 100 MB disk create GUID partition table
gpart create -s GPT /dev/ada0
- create a GUID Partition Table (GPT) scheme:
- Add the EFI partition with the label "EFI" aligned to 1MB:
gpart add -t efi -a 1M -l EFI /dev/ada0
- create the FAT16 filesystem for the EFI partition, with a label of FreeBSD_EFI:
newfs_msdos -F 16 -L FreeBSD_EFI /dev/ada0p1
- mount it:
mount -t msdosfs /dev/ada0p1 /mnt
- create the directory for the FreeBSD UEFI bootloader:
mkdir -p /mnt/efi/EFI/BOOT
- copy the FreeBSD UEFI first-stage bootloader into that directory with the name which firmware expects:
cp /boot/boot1.efi /mnt/efi/EFI/BOOT/BOOTX64.EFI
- unmount the filesystem:
umount /mnt
- now mount your root (/) and edit your fstab as your drive names must have changed. Alternatively you can fix nic name in rc.local
mount /dev/ada1p2 /mnt
vi /mnt/etc/fstab
vi /mnt/etc/rc.conf
umount /mnt
my changes were
da0p2 -> ada1p2
da1p1 -> ada2p1
da2p1 -> ada3p1
da3p1 -> ada4p1
da4p1 -> ada5p1
vmx0 -> vtnet0
- After all this is done remove CD from VM and reboot it. You should be good to go
used material from
