LIGISTX
- Apr 12, 2015
Motherboard raid is actually software raid supported by drivers in windows/Linux etc and will probably not work in ESXi
I never knew that. Thanks.
Yup, very true, I found out as well.Motherboard raid is actually software raid supported by drivers in windows/Linux etc and will probably not work in ESXi
@LIGISTX You could add a true RAID card if you really want to run in a Mirror but I tried that and unless you buy good quality and compatible hardware, I'd just run a single SSD as your boot drive. Also 120GB will disappear quickly! Just letting you know from personal experience. You can have two datastores using those two SSDs and that will help out. And to be honest, just put your system together and start using it. Even with planning this project out to cover every little thing you can think of, well you will change it. Odds are you will change it several times. So long as you are aware that you will make changes, life will be good.
Following this thread. Once you get it up and running, please share and document your experiences as best you can!
FX2_5079_Focus_Stack by David, on Flickr
FX2_4791-Pano by David, on Flickr
FX1_4689_Focus_Stack by David, on Flickr
FX2_5166 by David, on Flickr
FX2_3884-HDR by David, on FlickrAnd you know that that SAS expander doesn't necessarily need to be installed in a PCIe slot right?
It could be the firmware. Check that and the logs on esxi.
Ok, it only took me about 4 hours, but I figured out how and have successfully flashed the newest firmware. 20.00.07 or whatever it was. I only took a picture of the sas2flash -list screen before I edited anything... lol. But it is the newest as far as I know from all of the research I did, and booted up into freenas bare metal, no warning and it imported just fine.It could be the firmware. Check that and the logs on esxi.
dmesg | grep mpt mpt0: <LSILogic 1030 Ultra4 Adapter> port 0x1400-0x14ff mem 0xfeba0000-0xfebbffff,0xfebc0000-0xfebdffff irq 17 at device 16.0 on pci 0 mpt0: MPI Version=1.2.0.0 cd0: Attempt to query device size failed: NOT READY, Medium not present da0 at mpt0 bus 0 scbus2 target 0 lun 0
dmesg | grep mps mps0: <Avago Technologies (LSI) SAS2008> port 0x4000-0x40ff mem 0xfd4f0000-0xfd4fffff,0xfd480000-0xfd4bffff irq 18 at device 0.0 on pci3 mps0: Firmware: 20.00.07.00, Driver: 21.01.00.00-fbsd mps0: IOCCapabilities: 1285c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,HostDisc> mps0: SAS Address for SATA device = 4f675c4ddf96b98a mps0: SAS Address for SATA device = 4f696952b9b4db86 mps0: SAS Address for SATA device = 4f696952b9a1b785 mps0: SAS Address for SATA device = 4f696154dea1ca8b mps0: SAS Address for SATA device = 4f626a5ac796d198 mps0: SAS Address for SATA device = 4f675952b9a5be72 mps0: SAS Address for SATA device = 4f68675ad498d274 mps0: SAS Address for SATA device = 4f696154deb9b888 mps0: SAS Address from SATA device = 4f675c4ddf96b98a mps0: SAS Address from SATA device = 4f696952b9b4db86 mps0: SAS Address from SATA device = 4f696952b9a1b785 mps0: SAS Address from SATA device = 4f696154dea1ca8b mps0: SAS Address from SATA device = 4f626a5ac796d198 mps0: SAS Address from SATA device = 4f675952b9a5be72 mps0: SAS Address from SATA device = 4f68675ad498d274 mps0: SAS Address from SATA device = 4f696154deb9b888 mps0: SAS Address for SATA device = 4f646a52bab5db8c mps0: SAS Address for SATA device = 4f655f4fd6b2db78 mps0: SAS Address from SATA device = 4f646a52bab5db8c mps0: SAS Address from SATA device = 4f655f4fd6b2db78 ses0 at mps0 bus 0 scbus33 target 18 lun 0 da1 at mps0 bus 0 scbus33 target 8 lun 0 da2 at mps0 bus 0 scbus33 target 9 lun 0 da3 at mps0 bus 0 scbus33 target 10 lun 0 da4 at mps0 bus 0 scbus33 target 11 lun 0 da5 at mps0 bus 0 scbus33 target 12 lun 0 da7 at mps0 bus 0 scbus33 target 14 lun 0 da8 at mps0 bus 0 scbus33 target 15 lun 0 da9 at mps0 bus 0 scbus33 target 16 lun 0 da10 at mps0 bus 0 scbus33 target 17 lun 0 da6 at mps0 bus 0 scbus33 target 13 lun 0
