Patrick M. Hausen
Dedicated Sage
- Nov 25, 2013
Hi all,
so this is my TN 12.0 hosted iSCSI target as seen from an ESXi 7.0-U1 host:
Set policy to RR and IOPS to 1:
Check if it worked:
Problem: after every reboot of the ESXi host I am back to
The VMware documentation claims things set with
Any hints?
Thanks!
Patrick
[root@esxi:~] esxcli storage nmp device list naa.6589cfc0000009ef775032adb15747f5 Device Display Name: TrueNAS iSCSI Disk (naa.6589cfc0000009ef775032adb15747f5) [...]
[root@esxi:~] esxcli storage nmp device set -P VMW_PSP_RR -d naa.6589cfc0000009ef775032adb15747f5 [root@esxi:~] esxcli storage nmp psp roundrobin deviceconfig set -I 1 -t iops -d naa.6589cfc0000009ef775032adb15747f5
Check if it worked:
[root@esxi:~] esxcli storage nmp device list naa.6589cfc0000009ef775032adb15747f5 Device Display Name: TrueNAS iSCSI Disk (naa.6589cfc0000009ef775032adb15747f5) Storage Array Type: VMW_SATP_ALUA Storage Array Type Device Config: {implicit_support=on; explicit_support=off; explicit_allow=on; alua_followover=on; action_OnRetryErrors=off; {TPG_id=1,TPG_state=AO}} Path Selection Policy: VMW_PSP_RR Path Selection Policy Device Config: {policy=iops,iops=1,bytes=10485760,useANO=0; lastPathIndex=0: NumIOsPending=0,numBytesPending=0} Path Selection Policy Device Custom Config: policy=iops;iops=1;bytes=10485760;samplingCycles=16;latencyEvalTime=180000;useANO=0; Working Paths: vmhba64:C1:T0:L0, vmhba64:C0:T0:L0 Is USB: false [...]
VMW_PSP_MRU
and only vmhba64:C1:T0:L0
as a working path.The VMware documentation claims things set with
are persistent.Any hints?
Thanks!
Patrick
