espHome Install error py38-pillow
a900
FreeBSD 13.1-RELEASE n245376-eba770b30ff TRUENAS amd64
Motherboard: Gigabyte GA-78LMT-USB rev 5
CPU: AMD FX(tm)-6350 Six-Core Processor
real memory = 12884901888 (12288 MB)
avail memory = 11886403584 (11335 MB)
ahci0: <AMD SB7x0/SB8x0/SB9x0 AHCI SATA controller>
2 x western digital red plus 4TB drives. mirror
re0: <Realtek PCIe GbE
re0: version:1.96.04
Ive been trying to install ESP Home and getting the following error:
Error: esp had a failure Exception: RuntimeError Message: pkg error: - py38-pillow : Refusing to fetch artifact and run post_install.sh! Partial plugin destroyed
I have previously had it installed and working on this Truenas setup. For whatever reason the plugin was removed. but now i need it again it wont install.
tprelog
The plugin was broke. Even if you manage to get ESPHome installed, only the WebUI was working. There are errors compiling new firmware for both esp32 and esp8266 devices for some time now.
I'm not sure about the error you're seeing but I can say that py38-pillow is an optional dependency for installation.
If you absolutely must have ESPhome installed in a jail on CORE, I can help you get it installed but unless you can build custom ports for the missing platformio libraries it will be pretty useless IMO. To be clear, there are ports on github for the missing libraries in question, however they do not build the correct versions ESPHome is looking for. By custom port, I mean maintaining a port that builds with versions matching the ESPHome requirements.
