Errors on 2 disks - not sure where to start
wnoble
Received this error today. Not sure where to start:
Mar 22 20:00:08 nas-5 smartd[2782]: Device: /dev/da2 [SAT], 24 Currently unreadable (pending) sectors
Mar 22 20:00:08 nas-5 smartd[2782]: Device: /dev/da4 [SAT], 16 Currently unreadable (pending) sectors
Mar 22 20:00:08 nas-5 smartd[2782]: Device: /dev/da4 [SAT], 2 Offline uncorrectable sectors
System Info:
Build: FreeNAS-9-10.1-U2
Platform: Intel Xeon CPU X5675 @ 3.07GHz
Memory: 12259MB
Volume: VMware has the disks with errors and is the production voluem (MainShare is not being used and can use the disks as needed)
It looks like da2 and da4 are having issues...
You can start by running:
smartctl -a /dev/da2
smartctl -a /dev/da4
And share the output.
wnoble
Thanks so much for the fast response. Here is the output.
[root@nas-5] ~# smartctl -a /dev/da2
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Gold
Device Model: WDC WD6002FRYZ-01WD5B0
Serial Number: K1G37GGB
LU WWN Device Id: 5 000cca 255c17924
Firmware Version: 01.01M02
User Capacity: 6,001,175,126,016 bytes [6.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Mar 23 07:28:02 2020 EDT
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 113) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 774) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0005 138 138 054 Pre-fail Offline - 100
3 Spin_Up_Time 0x0007 131 131 024 Pre-fail Always - 500 (Average 502)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 39
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 128 128 020 Pre-fail Offline - 18
9 Power_On_Hours 0x0012 096 096 000 Old_age Always - 32288
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 36
192 Power-Off_Retract_Count 0x0032 099 099 000 Old_age Always - 1377
193 Load_Cycle_Count 0x0012 099 099 000 Old_age Always - 1377
194 Temperature_Celsius 0x0002 153 153 000 Old_age Always - 39 (Min/Max 20/45)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 24
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
[root@nas-5] ~# smartctl -a /dev/da4
Serial Number: K1G35UDB
LU WWN Device Id: 5 000cca 255c172f5
Local Time is: Mon Mar 23 07:29:24 2020 EDT
been run.
command.
power-saving mode.
recommended polling time: ( 763) minutes.
3 Spin_Up_Time 0x0007 140 140 024 Pre-fail Always - 470 (Average 469)
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 1
192 Power-Off_Retract_Count 0x0032 099 099 000 Old_age Always - 1376
193 Load_Cycle_Count 0x0012 099 099 000 Old_age Always - 1376
194 Temperature_Celsius 0x0002 171 171 000 Old_age Always - 35 (Min/Max 20/40)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 1
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 16
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 2
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
For da2, this is an issue. As it's a pending operation, there is a possibility it's related to some interface errors and we don't see any other read/write/reallocate errors, so it's possible the disk is still good and we just have a cabling or controller error (maybe related to the other disk having issues?)
For da4, this is more of an issue and is clearly internal to the disk. You should consider replacing this disk.
It also seems you're not running scheduled SMART tests on either of the disks (possibly not for the others either in that case). This could mean that there are more errors not yet detected.
wnoble
Thank you so much. This is stressing me out like there is no tomorrow.
I have 2 disks coming in for Tuesday.
Can I just replace da4 and the rebuild will automatically start? I don't think the controller is hot swap.
Or better yet, can I break down the volume "MainShare" and use one of those disks by doing a "replace"?
wnoble
Ok. Got it (I think). It's been years since dealing with swapping disks. Looking at what disks are on the server, da7 is not being used at all. When I look at da4, the "replace" option is there already. And when I select "replace", da7 is available.
Logically from the guide, I should be able to simply replace da4 with da7 and all would resume with "resilvering" the array. Correct? Anything I need to look out for?
wnoble
To me da7 looks like it is a good candidate to use
[root@nas-5] ~# smartctl -a /dev/da7
Serial Number: K1G36LYB
LU WWN Device Id: 5 000cca 255c175ee
Local Time is: Mon Mar 23 09:38:29 2020 EDT
recommended polling time: ( 780) minutes.
3 Spin_Up_Time 0x0007 135 135 024 Pre-fail Always - 486 (Average 487)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 38
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 35
192 Power-Off_Retract_Count 0x0032 051 051 000 Old_age Always - 59302
193 Load_Cycle_Count 0x0012 051 051 000 Old_age Always - 59302
194 Temperature_Celsius 0x0002 150 150 000 Old_age Always - 40 (Min/Max 20/47)
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
I agree. Although the forum recommends doing burn-in on new disks first, so perhaps consider that. (search for badblocks burnin test and there's plenty of instructions on how-to if you want to do that... it will take a long time)
Also note that you haven't run any SMART tests on that disk either... you should consider setting up that scheduled task if you love your data.
The long test goes to each block, so if you want confidence in the disk, you need to do it.
https://en.wikipedia.org/wiki/S.M.A.R.T.#Self-tests
SMART drives may offer a number of self-tests:
Short Checks the electrical and mechanical performance as well as the read performance of the disk. Electrical tests might include a test of buffer RAM, a read/write circuitry test, or a test of the read/write head elements. Mechanical test includes seeking and servo on data tracks. Scans small parts of the drive's surface (area is vendor-specific and there is a time limit on the test). Checks the list of pending sectors that may have read errors, and it usually takes under two minutes.
Long/extended A longer and more thorough version of the short self-test, scanning the entire disk surface with no time limit. This test usually takes several hours, depending on the read/write speed of the drive and its size.
wnoble
Understand completely. Thank you so much for your patience with me. I am just so stressed over this I am getting sick to my stomach.
If all goes well with the long test, I should be good doing a da4 to da7 "replace"?
Is there anything I should look for or possibly any kind of error I could see upon making the change?
Once this disk has been replaced, I will certainly look more into scheduled tests. But right now, I can hardly even think straight. Thanks again through this.
Clearly the priority is to ensure the integrity of the pool now, worrying about scheduling tests after that's covered.
If you don't get any read/write errors during the long test (or any others), it's a good start (although officially not a burn-in).
Depending how critical your pool is, you can then go ahead if you're comfortable taking a small risk that the new disk will fail during or shortly after the addition to the pool. (if it's more critical, you will still want to do the badblocks testing in line with the burnin process https://github.com/Spearfoot/disk-burnin-and-testing)
During a resilver, a bunch of code is used which is common to the scrub process and resilver, so you're able to be confident that if the zpool status -v says you're good after resilvering is done, your data is in great shape.
You can run an additional scrub if it helps you sleep better.
wnoble
Long test on da7 went well without any errors. Attempted to do the replace and received the error below. I am 99% sure this disk was never used or ever used in a volume. Is it safe to force?
Only you can be sure of your own disks. If you are confident it's empty, go ahead and force it.
wnoble
Thanks. After posting, I found a thread with same issue and they forced without problems. I proceeded with a force.
wnoble
Ok. "resilvering" completed. I did get 1 chksum error.
Local Time is: Tue Mar 24 11:25:46 2020 EDT
been run.
command.
power-saving mode.
9 Power_On_Hours 0x0012 096 096 000 Old_age Always - 32314
192 Power-Off_Retract_Count 0x0032 051 051 000 Old_age Always - 59321
193 Load_Cycle_Count 0x0012 051 051 000 Old_age Always - 59321
194 Temperature_Celsius 0x0002 139 139 000 Old_age Always - 43 (Min/Max 20/47)
No Errors Logged
# 1 Extended offline Completed without error 00% 32302 -
# 2 Short offline Completed without error 00% 32290 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
wnoble
Still seeing the da2 error:
Mar 24 11:41:05 nas-5 smartd[82889]: Device: /dev/da2 [SAT], 24 Currently unreadable (pending) sectors
Should I wait and see what the happens on the next scrub? Scheduled for this weekend. I also added a short and long test in the SMART tasks.
Keep watching it, if it goes up, replace the disk.
Checksum errors can be associated with cabling (or disks which misbehave... like when they have pending operations).
Check your cables carefully. You can do a zpool clear on the pool to remove the CRC for now so you can see easily if another one arrives.
