Error with drive in pool
Mitch2004
Hi All
I know this has probably been mentioned before hand and i have seen this issue a couple times but each scenario was slightly different or didn't quite match up with my specs so I am posting to be sure before I damage anything more.
TrueNAS specs
OS TrueNAS Scale, Bluefin running on two mirrored USB's
Hardware
Dell 720XD, with two E5-2650 V2, 4 x 16GB Samsung PC3-14900R ECC RAM,
12 x 6TB SAS Dell 7.2K in a RaidZ3
2 x 1TB SSD Samsung 870 EVO in a Mirror
History and Issue
Last night I updated from Angelfish to Bluefin, while I doing this I checked all my SAS drives via the shell console using
# fdisk -1 /dev/sd(Drive Letter)
All Drives reported back as 512 bytes as need by Bluefin, (Output below)
Disk /dev/sdn: 5.46 TiB, 6001175126016 bytes, 11721045168 sectors
Disk model: MG04SCA60EE
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: D9012A69-2086-4F9A-80B7-38EBB47551C5
Device Start End Sectors Size Type
/dev/sdn1 128 4194304 4194177 2G Linux swap
/dev/sdn2 4194432 11721045134 11716850703 5.5T Solaris /usr & Apple ZFS
This morning I powered backup TrueNAS (Powered it down once it had finished because I was not able to leave it running due to needing to change the UPS out) and I noticed that my RaidZ3 was degraded and one drive is showing up as name: 3869088571791395513 Status UNAVAIL. When I use the Replace disk feature I can see the original disk that was there " sdb " but when I go to use the replace drive or force replace drive I get the blow error
Error: [EFAULT] Unable to GPT format the disk "sdb": Warning! Read error 5; strange behavior now likely! Warning: Partition table header claims that the size of partition table entries is 0 bytes, but this program supports only 128-byte entries. Adjusting accordingly, but partition table may be garbage. Warning! Read error 5; strange behavior now likely! Warning: Partition table header claims that the size of partition table entries is 0 bytes, but this program supports only 128-byte entries. Adjusting accordingly, but partition table may be garbage. Unable to save backup partition table! Perhaps the 'e' option on the experts' menu will resolve this problem. Warning! An error was reported when writing the partition table! This error MIGHT be harmless, or the disk might be damaged! Checking it is advisable.
close
Please also note drive sdb (the one showing the error above, Has been working fine for the last 2 months, only throw that error after Bluefin upgrade
Is anyone able to point me in the right direction for getting this fixed?
first time having a drive fail in TrueNAS.
Mitch2004
Sorry about the Spelling, Just realized how bad it is,
Can you run even a short SMART selftest on the drive in question?
EDIT: You know what. Bluefin is looking like an alpha quality release.
Mitch2004
Just tried to, got the following error from within TrueNAS
Manual S.M.A.R.T. Test​
sdb​
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.79+truenas] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org Short offline self test failed [medium or hardware error (serious)]
Output when doing # fdisk -l /dev/sdb in shell
fdisk: cannot open /dev/sdb: Input/output error
That does not look good. :oops:
This happened right after you upgraded to Bluefin and rebooted?
What does the error and selftest logs reveal?
smartctl -l error /dev/sdb
smartctl -l selftest /dev/sdb
Mitch2004
Outputs are below, Same order as you listed above
root@truenas[~]# smartctl -l error /dev/sdb
Error counter log:
Errors Corrected by Total Correction Gigabytes Total
ECC rereads/ errors algorithm processed uncorrected
fast | delayed rewrites corrected invocations [10^9 bytes] errors
read: 0 0 0 0 0 4759263.049 0
write: 0 23 23 23 43 160112.333 0
verify: 0 0 0 0 0 1332293.750 0
Non-medium error count: 5507
root@truenas[~]# smartctl -l selftest /dev/sdb
SMART Self-test log
Num Test Status segment LifeTime LBA_first_err [SK ASC ASQ]
Description number (hours)
# 1 Background short Completed 80 43957 - [- - -]
# 2 Background short Completed 80 43954 - [- - -]
# 3 Background short Completed 80 43952 - [- - -]
# 4 Background short Completed 80 43936 - [- - -]
# 5 Background short Completed 80 43895 - [- - -]
# 6 Background short Completed 80 43866 - [- - -]
# 7 Background short Completed 80 43858 - [- - -]
# 8 Background short Completed 80 43842 - [- - -]
# 9 Background short Completed 80 5 - [- - -]
#10 Reserved(7) Completed 64 5 - [- - -]
Long (extended) Self-test duration: 37873 seconds [631.2 minutes]
Okay, what is going on with Bluefin and these drives?
It's really making me nervous, and I'm glad I'm sticking with Core.
Might it be interrelated with these issues / threads?
Basically, installing or upgrading to Bluefin opens up new issues with certain types of drives that might not have been present with Angelfish.
I take it you already double-checked the cables and port connections?
Mitch2004
Yes I have checked all cables and connectors, they seam to be working correctly
I tried again today replacing the drive but still no luck, I did reboot TrueNAS again and now it is throwing a DIF error (See belo for full error) on all mechanical drives
I have also noticed that the drive label I am having issues with has changed from sdb to sda, Same physical drive from what I can see just the label has changed.
Checked the drives using # fdisk -l /dev/sd(drive letter) and if I am not mistaken it is reporting them as 512 Byte sectors, I am now wondering if bluefin is just really bugged.
DIFF Error after rebooting
Disk(s): sdb, sdi, sdm, sdl, sdn, sdc, sdd, sde, sdf, sdg, sdj are formatted with Data Integrity Feature (DIF) which is unsupported.​
2022-12-19 16:45:08 (Australia/Adelaide)
Output for # fdisk -l /dev/sd(drive letter)
root@truenas[~]# fdisk -l /dev/sdi
Disk /dev/sdi: 5.46 TiB, 6001175126016 bytes, 11721045168 sectors
Disklabel type: gpt
Disk identifier: 217350DA-CB37-4E41-A998-486235AE1D67
/dev/sdi1 128 4194304 4194177 2G Linux swap
/dev/sdi2 4194432 11721045134 11716850703 5.5T Solaris /usr & Apple ZFS
Daisuke
Okay, what is going on with Bluefin and these drives? It's really making me nervous, and I'm glad I'm sticking with Core.
I explained into my troubleshooting thread the cause of these errors. Using Core does not address the root issue with your disks being badly formatted, once the kernel is updated, you will get the same warnings in Core also. Your solution is a bandaid to a real problem.
Which is a very good thing, most people never check the purchased drives on eBay etc., prior installing them into a Linux system and wonder why things go havoc.
