Error Unlocking
Hmm, so by the looks of it all of your drives are unlocked. Can you give me the output of zpool status, zpool import, and sqlite3 /data/freenas-v1.db 'select * from storage_volume;'?
Scrat_
freenas# zpool status
  pool: databank01
 state: UNAVAIL
Assertion failed: (reason == ZPOOL_STATUS_OK), file /freenas-releng/freenas/_BE/os/cddl/contrib/opensolaris/cmd/zpool/zpool_main.c, line 4973.
Abort trap (core dumped)
freenas# zpool import
freenas# sqlite3 /data/freenas-v1.db 'select * from storage_volume;'
1|databank01|9906055174888524968|1|e7da5c5c-624b-4d0e-86bb-2afec29220c8
At this point it looks like your drives are unlocked. If so, the issue may now have to do with the error message.
Assertion failed: (reason == ZPOOL_STATUS_OK), file /freenas-releng/freenas/_BE/os/cddl/contrib/opensolaris/cmd/zpool/zpool_main.c, line 4973. Abort trap (core dumped)
This is interesting and perhaps related. Have you found anything online related to this?
Scrat_
No, I haven't looked yet. I suspect whatever is at the end of this issue will be my problem and will maybe need to order a drive once I'm in to save the data.
A quick search brought up the following from 2014 https://forums.freebsd.org/threads/solved-zpool-import-assertion-failed.44359/
Not sure sure if it's related though..
Dec 4 23:10:59 freenas kernel: pid 46948 (zpool), uid 0: exited on signal 6 (core dumped) I'm seeing this in the activity pane. Hope it's a kernel issue and nothing to do with the drive. I've started smartctl -t /dev/da0 on the first drive. Supposedly done on the fifth.
If you suspect any data drives are bad you'll probably want a spare disk ready and burned in ahead of time. Perhaps worth purchasing now so it will be ready when you are?
hmm. At this point I don't really have any answers. I'm not sure if the version etc in this link is relevant to your current system. What version of FreeNAS were you on when you created the pool?
I did find this post which may be relevant as well. Specifically I wonder if somehow the second cache drive you said you had wasn't registering and is causing issues. I noticed an earlier zpool import that it complained about some additional disks being part of the pool but their configuration not being known. How did you go about importing the pool earlier? Did you use the -f flag?
The encryption and importing with a bad cache drive issues I know quite well; I think you're beyond those though. I don't know what is causing your errors exactly and while I'm happy to suggest things I might do if it were my system we are well into the realm of "I'm not sure" and all of the added risk of trying the steps I would suggest.
Scrat_
I started with FreeNAS 11.1 or 11.2. I did the import process through the web interface. I don't see anything about the cache drives anymore.
  pool: databank01
 state: UNAVAIL
How do I see what's on line 4973?
That is the source code line number I expect. You can check their github page here. Unfortunately, it isn't extremely helpful to me in figuring out your issue.
You could try clearing the zpool errors for that pool and see if the issue persists.
What is the output of zpool history databank01? That will be a lot of output I suspect; perhaps worth uploading as a file. I'm also curious what happens if you run long smart tests on all 4 of your data drives and then gave the full output of smartctl -a /dev/<device>.
You _could_ also try clearing the zpool error and running it again to see what happens.
At this point I would go into debug mode. It is interesting that it seems like as time has gone on your system has gotten more unstable with more issues. I generally would start with low hanging fruit such as the results of smartctl -a <disk> where the disk will likely be something like /dev/da1 or /dev/ada1. The output of that for every test may show issues with a disk causing the errors. Alternatively, if you haven't run smart tests in a while you may want to run a long smart test with smartcl -t long /dev/<disk> and then check the results with smartctl -a <disk>. The results may not say "error" anywhere but there may be issues nonetheless.
This may also be related to the problem. It looks like you're on `11.2-STABLE` now but the pool was made in some earlier version? I am not super familiar with issues or their solutions for pools made in earlier versions and then used in later versions of zfs or freenas.
Scrat_
Attached are the results for da0 to da3. Feedback was very quick. Running long test on da0 at the moment. I will be posting fresh results after the four drives are done. As far as setup time, it wouldn't surprise me if I started off at 11.1.. I hope that's not bad. Hahaha
** Merry Christmas! **
  • drive-issues.txt
Scrat_
Well, for some reason the interface hangs.. or there's a quiet error somewhere, but i couldn't fish the results. Had to reboot and start over. Is it possible to get another drive in the mix to save it, or am I past that point? Is it possible to take my drives somewhere and do some extreme recovery.. just incase whatever happens here has no success?
Scrat_
Update: FreeNAS keeps blanking out on me during the tests.
Are my thumb drives going also?
freenas# smartctl -a /dev/da3
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Seagate IronWolf
Device Model:     ST4000VN008-2DR166
Serial Number:    ZDH16CMP
LU WWN Device Id: 5 000c50 0a28b45ca
Firmware Version: SC60
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Rotation Rate:    5980 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sat Jan 11 21:20:54 2020 CST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  591) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 627) minutes.
Conveyance self-test routine
SCT capabilities:              (0x50bd) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   082   064   044    Pre-fail  Always       -       175198911
  3 Spin_Up_Time            0x0003   093   093   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       67
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   092   060   045    Pre-fail  Always       -       1711930676
  9 Power_On_Hours          0x0032   089   089   000    Old_age   Always       -       9970 (118 57 0)
10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       67
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   072   067   040    Old_age   Always       -       28 (Min/Max 17/32)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       75
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       151
194 Temperature_Celsius     0x0022   028   040   000    Old_age   Always       -       28 (0 16 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       9965 (171 155 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       23258152979
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       151898858283
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error       00%      9932         -
# 2  Extended offline    Completed without error       00%      8557         -
# 3  Extended offline    Completed without error       00%      7876         -
# 4  Extended offline    Completed without error       00%      7200         -
# 5  Extended offline    Completed without error       00%      6505         -
# 6  Extended offline    Completed without error       00%      5761         -
# 7  Extended offline    Completed without error       00%      5041         -
# 8  Extended offline    Completed without error       00%      4299         -
freenas# smartctl -a /dev/da2
Serial Number:    ZGY002G6
LU WWN Device Id: 5 000c50 0a296b8c5
Local Time is:    Sat Jan 11 21:21:02 2020 CST
                                        been run.
data collection:                (  581) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 630) minutes.
  1 Raw_Read_Error_Rate     0x000f   072   064   044    Pre-fail  Always       -       17324646
  7 Seek_Error_Rate         0x000f   091   060   045    Pre-fail  Always       -       1171331412
  9 Power_On_Hours          0x0032   089   089   000    Old_age   Always       -       9970 (43 67 0)
190 Airflow_Temperature_Cel 0x0022   072   067   040    Old_age   Always       -       28 (Min/Max 16/30)
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       170
194 Temperature_Celsius     0x0022   028   040   000    Old_age   Always       -       28 (0 15 0 0 0)
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       9966 (185 33 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       24248349203
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       153251206491
No Errors Logged
# 1  Extended offline    Completed without error       00%      9885         -
# 7  Extended offline    Completed without error       00%      5040         -
freenas# smartctl -a /dev/da1
Serial Number:    ZGY0025Z
LU WWN Device Id: 5 000c50 0a296c3ef
Local Time is:    Sat Jan 11 21:21:09 2020 CST
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 634) minutes.
  1 Raw_Read_Error_Rate     0x000f   080   064   044    Pre-fail  Always       -       106801716
  7 Seek_Error_Rate         0x000f   092   060   045    Pre-fail  Always       -       1460840282
  9 Power_On_Hours          0x0032   089   089   000    Old_age   Always       -       9968 (127 236 0)
190 Airflow_Temperature_Cel 0x0022   072   067   040    Old_age   Always       -       28 (Min/Max 17/31)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       67
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       152
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       9964 (0 25 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       23267555603
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       147864732336
No Errors Logged
# 1  Extended offline    Completed without error       00%      9866         -
# 2  Extended offline    Completed without error       00%      9713         -
# 3  Extended offline    Completed without error       00%      8557         -
# 4  Extended offline    Completed without error       00%      7876         -
# 5  Extended offline    Completed without error       00%      7200         -
# 6  Extended offline    Completed without error       00%      6505         -
# 7  Extended offline    Completed without error       00%      5761         -
# 8  Extended offline    Completed without error       00%      5041         -
# 9  Extended offline    Completed without error       00%      4299         -
freenas# smartctl -a /dev/da0
Serial Number:    ZDH16L77
LU WWN Device Id: 5 000c50 0a2806a4d
Local Time is:    Sat Jan 11 21:21:26 2020 CST
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 625) minutes.
  1 Raw_Read_Error_Rate     0x000f   082   064   044    Pre-fail  Always       -       166702201
  7 Seek_Error_Rate         0x000f   088   060   045    Pre-fail  Always       -       9810077499
  9 Power_On_Hours          0x0032   089   089   000    Old_age   Always       -       9968 (172 124 0)
190 Airflow_Temperature_Cel 0x0022   074   068   040    Old_age   Always       -       26 (Min/Max 15/29)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       65
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       163
194 Temperature_Celsius     0x0022   026   040   000    Old_age   Always       -       26 (0 14 0 0 0)
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       9965 (39 249 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       24240599139
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       151076176814
No Errors Logged
# 1  Short offline       Completed without error       00%      9828         -
# 2  Extended offline    Completed without error       00%      9808         -
# 3  Extended offline    Completed without error       00%      9687         -
# 4  Extended offline    Completed without error       00%      9616         -
# 5  Extended offline    Completed without error       00%      9506         -
# 6  Extended offline    Completed without error       00%      8557         -
# 7  Extended offline    Completed without error       00%      7876         -
# 8  Extended offline    Completed without error       00%      7200         -
# 9  Extended offline    Completed without error       00%      6505         -
#10  Extended offline    Completed without error       00%      5761         -
#11  Extended offline    Completed without error       00%      5040         -
#12  Extended offline    Completed without error       00%      4299         -
Why does it seem fishy?
Scrat_
I got this while deciding to see if the system could still recognize my pool sine it doesn't register under storage, and I got this:
  pool: databank01
 state: UNAVAIL
