vonion
- Feb 24, 2018
It is a setup with 9 x SM863a in RAID Z, chassis is SYS-1028U-TNRT+ drives and system are converted from a working VSAN. da2 failed twice after I finished setup today. I replaced the disk in da2 twice, once resilvering done, it starts to show checksum error again...
New to FreeNAS, please let me know if need additional info, otherwise log is below
zpool status pool: FNAS03-Z2 state: ONLINE status: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected. action: Determine if the device needs to be replaced, and clear the errors using 'zpool clear' or replace the device with 'zpool replace'. see: http://illumos.org/msg/ZFS-8000-9P scan: resilvered 299G in 0 days 02:04:20 with 0 errors on Sun Feb 25 02:58:28 2018 config: NAME STATE READ WRITE CKSUM FNAS03-Z2 ONLINE 0 0 0 raidz2-0 ONLINE 0 0 0 gptid/79a29617-19d0-11e8-957a-002590fa888d ONLINE 0 0 0 gptid/7a040ad1-19d0-11e8-957a-002590fa888d ONLINE 0 0 0 gptid/7a663ebd-19d0-11e8-957a-002590fa888d ONLINE 0 0 0 gptid/69598304-1a09-11e8-957a-002590fa888d ONLINE 0 0 13 gptid/7b4dd453-19d0-11e8-957a-002590fa888d ONLINE 0 0 0 gptid/7bb14e7d-19d0-11e8-957a-002590fa888d ONLINE 0 0 0 gptid/7c14049a-19d0-11e8-957a-002590fa888d ONLINE 0 0 0 gptid/7c77b5b5-19d0-11e8-957a-002590fa888d ONLINE 0 0 0 gptid/7cdb5e0f-19d0-11e8-957a-002590fa888d ONLINE 0 0 0 errors: No known data errors pool: freenas-boot state: ONLINE scan: none requested config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 ada0p2 ONLINE 0 0 0 errors: No known data errors
Feb 25 00:49:45 FNAS03 mpr0: (da2:mpr0:0:4:0): CAM status: CCB request completed with an error Feb 25 00:49:45 FNAS03 (da2:mpr0:0:4:0): Error 5, Periph was invalidated Feb 25 00:49:45 FNAS03 (da2:mpr0:0:4:0): READ(10). CDB: 28 00 95 f7 6c 38 00 00 08 00 Feb 25 00:49:45 FNAS03 clearing target 4 handle 0x000b Feb 25 00:49:45 FNAS03 mpr0: At enclosure level 0, slot 2, connector name ( ) Feb 25 00:49:45 FNAS03 mpr0: Unfreezing devq for target ID 4 Feb 25 00:49:45 FNAS03 (da2:mpr0:0:4:0): CAM status: CCB request completed with an error Feb 25 00:49:45 FNAS03 ZFS: vdev state changed, pool_guid=2025594203911010728 vdev_guid=14089127837580570434 Feb 25 00:49:45 FNAS03 ZFS: vdev state changed, pool_guid=2025594203911010728 vdev_guid=14089127837580570434 Feb 25 00:49:45 FNAS03 ZFS: vdev state changed, pool_guid=2025594203911010728 vdev_guid=14089127837580570434 Feb 25 00:49:45 FNAS03 (da2:mpr0:0:4:0): Error 5, Periph was invalidated Feb 25 00:49:45 FNAS03 (da2:mpr0:0:4:0): READ(10). CDB: 28 00 95 f7 6c 10 00 00 08 00 Feb 25 00:49:45 FNAS03 (da2:mpr0:0:4:0): CAM status: CCB request completed with an error Feb 25 00:49:45 FNAS03 (da2:mpr0:0:4:0): Error 5, Periph was invalidated Feb 25 00:49:45 FNAS03 (da2:mpr0:0:4:0): READ(10). CDB: 28 00 95 f7 6b f8 00 00 08 00 Feb 25 00:49:45 FNAS03 (da2:mpr0:0:4:0): CAM status: CCB request completed with an error Feb 25 00:49:45 FNAS03 (da2:mpr0:0:4:0): Error 5, Periph was invalidated Feb 25 00:49:45 FNAS03 (da2:mpr0:0:4:0): READ(10). CDB: 28 00 95 f7 6b b8 00 00 08 00 Feb 25 00:49:45 FNAS03 (da2:mpr0:0:4:0): CAM status: CCB request completed with an error Feb 25 00:49:45 FNAS03 (da2:mpr0:0:4:0): Error 5, Periph was invalidated Feb 25 00:49:45 FNAS03 (da2:mpr0:0:4:0): READ(10). CDB: 28 00 95 f7 6b 98 00 00 08 00 Feb 25 00:49:45 FNAS03 (da2:mpr0:0:4:0): CAM status: CCB request completed with an error Feb 25 00:49:45 FNAS03 (da2:mpr0:0:4:0): Error 5, Periph was invalidated Feb 25 00:49:45 FNAS03 GEOM_MIRROR: Device swap2: provider da2p1 disconnected. Feb 25 00:49:45 FNAS03 (da2:mpr0:0:4:0): Periph destroyed Feb 25 00:49:59 FNAS03 daemon[6144]: 2018/02/25 00:49:59 [WARN] agent: Check 'freenas_health' is now warning Feb 25 00:52:00 FNAS03 daemon[6144]: 2018/02/25 00:52:00 [WARN] agent: Check 'freenas_health' is now warning Feb 25 00:52:05 FNAS03 mpr0: SAS Address for SATA device = 947e9634e1c1a8d8 Feb 25 00:52:05 FNAS03 mpr0: SAS Address from SAS device page0 = 4433221102000000 Feb 25 00:52:05 FNAS03 mpr0: SAS Address from SATA device = 947e9634e1c1a8d8 Feb 25 00:52:05 FNAS03 mpr0: Found device <881<SataDev,Direct>,End Device> <6.0Gbps> handle<0x000b> enclosureHandle<0x0001> slot 2 Feb 25 00:52:05 FNAS03 mpr0: At enclosure level 0 and connector name ( ) Feb 25 00:52:05 FNAS03 da2 at mpr0 bus 0 scbus0 target 4 lun 0 Feb 25 00:52:05 FNAS03 da2: <ATA SAMSUNG MZ7KM1T9 104Q> Fixed Direct Access SPC-4 SCSI device Feb 25 00:52:05 FNAS03 da2: Serial Number S3HUNX0J601476Z Feb 25 00:52:05 FNAS03 da2: 600.000MB/s transfers Feb 25 00:52:05 FNAS03 da2: Command Queueing enabled Feb 25 00:52:05 FNAS03 da2: 1831420MB (3750748848 512 byte sectors) Feb 25 00:52:05 FNAS03 da2: quirks=0x8<4K> Feb 25 00:53:55 FNAS03 notifier: 32+0 records in Feb 25 00:53:55 FNAS03 notifier: 32+0 records out Feb 25 00:53:55 FNAS03 notifier: 33554432 bytes transferred in 0.098817 secs (339562990 bytes/sec) Feb 25 00:53:55 FNAS03 GEOM: da2: the primary GPT table is corrupt or invalid. Feb 25 00:53:55 FNAS03 GEOM: da2: using the secondary instead -- recovery strongly advised. Feb 25 00:53:55 FNAS03 notifier: dd: /dev/da2: short write on character device Feb 25 00:53:55 FNAS03 notifier: dd: /dev/da2: end of device Feb 25 00:53:55 FNAS03 notifier: 33+0 records in Feb 25 00:53:55 FNAS03 notifier: 32+1 records out Feb 25 00:53:55 FNAS03 notifier: 33906688 bytes transferred in 0.083948 secs (403901163 bytes/sec) Feb 25 00:53:56 FNAS03 notifier: gpart: arg0 'gptid/69598304-1a09-11e8-957a-002590fa888d': Invalid argument Feb 25 00:53:56 FNAS03 notifier: gpart: provider: Device not configured Feb 25 00:53:56 FNAS03 notifier: gpart: arg0 'gptid/69598304-1a09-11e8-957a-002590fa888d': Invalid argument Feb 25 00:53:56 FNAS03 ZFS: vdev state changed, pool_guid=2025594203911010728 vdev_guid=10055579806217775314 Feb 25 00:54:00 FNAS03 daemon[6144]: 2018/02/25 00:54:00 [WARN] agent: Check 'freenas_health' is now warning Feb 25 00:54:05 FNAS03 ZFS: vdev state changed, pool_guid=2025594203911010728 vdev_guid=13070446044546478261 Feb 25 00:54:05 FNAS03 ZFS: vdev state changed, pool_guid=2025594203911010728 vdev_guid=15261218018251548598 Feb 25 00:54:05 FNAS03 ZFS: vdev state changed, pool_guid=2025594203911010728 vdev_guid=13671545178972892527 Feb 25 00:54:05 FNAS03 ZFS: vdev state changed, pool_guid=2025594203911010728 vdev_guid=10055579806217775314 Feb 25 00:54:05 FNAS03 ZFS: vdev state changed, pool_guid=2025594203911010728 vdev_guid=14932043723365803802 Feb 25 00:54:05 FNAS03 ZFS: vdev state changed, pool_guid=2025594203911010728 vdev_guid=12564594350981481757 Feb 25 00:54:05 FNAS03 ZFS: vdev state changed, pool_guid=2025594203911010728 vdev_guid=5704886040987976214 Feb 25 00:54:05 FNAS03 ZFS: vdev state changed, pool_guid=2025594203911010728 vdev_guid=7707503818947279095 Feb 25 00:54:05 FNAS03 ZFS: vdev state changed, pool_guid=2025594203911010728 vdev_guid=11776749107165575220 Feb 25 00:54:09 FNAS03 GEOM_ELI: Device mirror/swap2.eli destroyed. Feb 25 00:54:09 FNAS03 GEOM_MIRROR: Device swap2: provider destroyed. Feb 25 00:54:09 FNAS03 GEOM_MIRROR: Device swap2 destroyed. Feb 25 00:54:10 FNAS03 GEOM_MIRROR: Device mirror/swap2 launched (2/2). Feb 25 00:54:10 FNAS03 GEOM_ELI: Device mirror/swap2.eli created. Feb 25 00:54:10 FNAS03 GEOM_ELI: Encryption: AES-XTS 128 Feb 25 00:54:10 FNAS03 GEOM_ELI: Crypto: hardware Feb 25 00:56:01 FNAS03 daemon[6144]: 2018/02/25 00:56:01 [WARN] agent: Check 'freenas_health' is now warning Feb 25 00:58:01 FNAS03 daemon[6144]: 2018/02/25 00:58:01 [WARN] agent: Check 'freenas_health' is now warning Feb 25 01:00:01 FNAS03 daemon[6144]: 2018/02/25 01:00:01 [WARN] agent: Check 'freenas_health' is now warning
