Hello together
I do need some help, I get an error report from my freenas:
" One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected."
I've found some checksum errors on all 3 disks (3 * WD Red 3TB), what does this mean to my zfs system is it corrupted? What do I have to do know? Can the system heal itself?
I don't use ECC Ram, but I have tested the RAM with ramtest and it is fine.
Thx for your help.
Thx for your help.
[root@freenas ~]# zpool status pool: freenas-boot state: ONLINE scan: scrub repaired 0 in 0h2m with 0 errors on Mon Aug 8 03:47:06 2016 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 da0p2 ONLINE 0 0 0 errors: No known data errors pool: volume1 state: ONLINE status: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected. action: Determine if the device needs to be replaced, and clear the errors using 'zpool clear' or replace the device with 'zpool replace'. see: http://illumos.org/msg/ZFS-8000-9P scan: scrub repaired 2.87M in 2h56m with 0 errors on Sun Aug 7 02:56:09 2016 config: NAME STATE READ WRITE CKSUM volume1 ONLINE 0 0 0 raidz1-0 ONLINE 0 0 0 gptid/2a9442d5-a35e-11e4-9d35-d050995092f9 ONLINE 0 0 20 gptid/2af34812-a35e-11e4-9d35-d050995092f9 ONLINE 0 0 12 ada0 ONLINE 0 0 16 errors: No known data errors
