SOLVED ...error resulting in data corruption. Applications may be affected.
dnilgreb
I am running a FReeNAS 9.10.2-U6, with 32GB RAM (non-ECC).
So, I got this error:
The volume volume1 (ZFS) state is ONLINE: One or more devices has experienced an error resulting in data corruption. Applications may be affected.
So i ran zpool status -v and got this output:
[root@NAS01] ~# zpool status -v
  pool: freenas-boot
 state: ONLINE
  scan: scrub repaired 0 in 0h1m with 0 errors on Thu Aug  3 03:46:56 2017
		NAME		STATE	 READ WRITE CKSUM
		freenas-boot  ONLINE	   0	 0	 0
		  da1p2	 ONLINE	   0	 0	 0
errors: No known data errors
  pool: volume1
 state: ONLINE
action: Restore the file in question if possible.  Otherwise restore the
		entire pool from backup.
   see: http://illumos.org/msg/ZFS-8000-8A
  scan: scrub repaired 96K in 6h0m with 3 errors on Sun Aug 27 06:00:11 2017
		volume1										 ONLINE	   0	 0	 3
		  raidz2-0									  ONLINE	   0	 0	 6
			gptid/5f2b7283-9739-11e4-8b4e-5404a697b96e  ONLINE	   0	 0	 1
			gptid/07895578-cce5-11e4-9dde-5404a697b96e  ONLINE	   0	 0	 1
			gptid/6070d53b-9739-11e4-8b4e-5404a697b96e  ONLINE	   0	 0	 1
			gptid/614a8b8d-9739-11e4-8b4e-5404a697b96e  ONLINE	   0	 0	 1
			gptid/6221dcba-9739-11e4-8b4e-5404a697b96e  ONLINE	   0	 0	 1
			gptid/62fd2bc2-9739-11e4-8b4e-5404a697b96e  ONLINE	   0	 0	 0
		/mnt/volume1/Backup/Time-Machine/MacBookAir.sparsebundle/bands/16145
		/mnt/volume1/Backup/Time-Machine/MacBookAir.sparsebundle/bands/16815
I should probably delete the reported files, but how can I determine if a drive is failing, and if so,m which one?
styno
Could be the memory or less likely all of the disks. Full memcheck and smart analysis would be a good starting point.
Stux
Almost more likely it's a memory error that caused the corruption. If there is any.
I'd suggest rescrubbing after testing your memory. It might go away.
dnilgreb
Thanks for the response. How do I test the memory in the best way? Do I have to create a memtest86 stick, or is there a way to do this inside FreeNAS?
Isn´t there a risk involved in running a scrub if you have corrupt data/disks?
Smart analysis, is that simply running a long smart test, or something different?
styno
Yes, create a memtest86 stick and let it do it's work. Scrubs are there to detect and fix corruption within the zfs ecosystem (and thus countering drive errors as well).
It is important to run them only *after* you make sure that the memory is not faulty, this is why ECC is recommended.
Smart analysis would involve scheduled periodic short & long tests as well as investigating smartctl outputs from every drive.
But again, this most likely is caused by a faulty memory stick so check that first.
dnilgreb
OK. But if I run the memtest, I need to run it for a long time, right? Maybe a week or two?
I´ll create a stick tomorrow when I´m at work, but what can I do in the meantime? I am running a long SMART test the first of every month, and a short one every day at 6am. Can the output from that be useful?
I´ll be happy to post output, but what to post?
The output of smartctl -a /dev/ada0 is huge, is there something in particular that´s interesting, or shuold I post the whole thing? Or maybe something different entirely?
styno
You can start with smartctl -A /dev/yourdrives
dnilgreb
Here is smartctl -A /dev/ada0. Should I post for all drives?
[root@NAS01] ~# smartctl -A /dev/ada0
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x002f   200   200   051	Pre-fail  Always	   -	   0
  3 Spin_Up_Time			0x0027   174   172   021	Pre-fail  Always	   -	   8275
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   68
  5 Reallocated_Sector_Ct   0x0033   200   200   140	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x002e   100   253   000	Old_age   Always	   -	   0
  9 Power_On_Hours		  0x0032   059   059   000	Old_age   Always	   -	   30186
 10 Spin_Retry_Count		0x0032   100   253   000	Old_age   Always	   -	   0
 11 Calibration_Retry_Count 0x0032   100   253   000	Old_age   Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   68
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   27
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   1917
194 Temperature_Celsius	 0x0022   108   101   000	Old_age   Always	   -	   44
196 Reallocated_Event_Count 0x0032   200   200   000	Old_age   Always	   -	   0
197 Current_Pending_Sector  0x0032   200   200   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0030   100   253   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   0
200 Multi_Zone_Error_Rate   0x0008   200   200   000	Old_age   Offline	  -	   0
Yes, but with the -a in lowercase: smartctl -a /dev/ada0 etc.
dnilgreb
Ok. Here goes:
1:
[root@NAS01] ~# smartctl -a /dev/ada0
Model Family:	 Western Digital Red
Device Model:	 WDC WD40EFRX-68WT0N0
Serial Number:	WD-WCC4E0898115
LU WWN Device Id: 5 0014ee 25f0fc553
Firmware Version: 80.00A80
User Capacity:	4,000,787,030,016 bytes [4.00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Rotation Rate:	5400 rpm
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:	Sun Aug 27 13:59:48 2017 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
										was never started.
Self-test execution status:	  (   0) The previous self-test routine completed
										been run.
data collection:				(54300) seconds.
capabilities:					(0x7b) SMART execute Offline immediate.
										command.
										Self-test supported.
SMART capabilities:			(0x0003) Saves SMART data before entering
										power-saving mode.
Error logging capability:		(0x01) Error logging supported.
Short self-test routine
recommended polling time:		(   2) minutes.
Extended self-test routine
recommended polling time:		( 543) minutes.
Conveyance self-test routine
recommended polling time:		(   5) minutes.
SCT capabilities:			  (0x703d) SCT Status supported.
										SCT Data Table supported.
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline	   Completed without error	   00%	 24980		 -
# 2  Short offline	   Completed without error	   00%	 24814		 -
# 3  Short offline	   Completed without error	   00%	 24646		 -
# 4  Extended offline	Completed without error	   00%	 24483		 -
# 5  Short offline	   Completed without error	   00%	 24310		 -
# 6  Short offline	   Completed without error	   00%	 24142		 -
# 7  Short offline	   Completed without error	   00%	 23975		 -
# 8  Short offline	   Completed without error	   00%	 23807		 -
# 9  Extended offline	Completed without error	   00%	 23740		 -
#10  Short offline	   Completed without error	   00%	 23639		 -
#11  Short offline	   Completed without error	   00%	 23471		 -
#12  Short offline	   Completed without error	   00%	 23303		 -
#13  Short offline	   Completed without error	   00%	 23136		 -
#14  Extended offline	Completed without error	   00%	 23021		 -
#15  Short offline	   Completed without error	   00%	 22968		 -
#16  Short offline	   Completed without error	   00%	 22799		 -
#17  Short offline	   Completed without error	   00%	 22631		 -
#18  Short offline	   Completed without error	   00%	 22463		 -
#19  Short offline	   Completed without error	   00%	 22295		 -
#20  Extended offline	Completed without error	   00%	 22277		 -
#21  Short offline	   Completed without error	   00%	 22128		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
2:
[root@NAS01] ~# smartctl -a /dev/ada1
Serial Number:	WD-WCC4E7TEH493
LU WWN Device Id: 5 0014ee 2611a3018
Firmware Version: 82.00A82
Local Time is:	Sun Aug 27 14:01:17 2017 CEST
										was never started.
										been run.
data collection:				(51540) seconds.
										command.
										power-saving mode.
recommended polling time:		( 515) minutes.
  3 Spin_Up_Time			0x0027   180   177   021	Pre-fail  Always	   -	   8000
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   56
  9 Power_On_Hours		  0x0032   072   072   000	Old_age   Always	   -	   21080
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   56
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   26
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   231
194 Temperature_Celsius	 0x0022   106   098   000	Old_age   Always	   -	   46
200 Multi_Zone_Error_Rate   0x0008   100   253   000	Old_age   Offline	  -	   0
No Errors Logged
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
3:
[root@NAS01] ~# smartctl -a /dev/ada2
Serial Number:	WD-WCC4EHRKCHEZ
LU WWN Device Id: 5 0014ee 26054b502
Local Time is:	Sun Aug 27 14:01:48 2017 CEST
										was never started.
										been run.
data collection:				(52320) seconds.
										command.
										power-saving mode.
recommended polling time:		( 523) minutes.
  3 Spin_Up_Time			0x0027   177   175   021	Pre-fail  Always	   -	   8133
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   60
  9 Power_On_Hours		  0x0032   069   069   000	Old_age   Always	   -	   22782
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   60
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   25
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   248
No Errors Logged
# 1  Short offline	   Completed without error	   00%	 22774		 -
# 2  Short offline	   Completed without error	   00%	 22607		 -
# 3  Short offline	   Completed without error	   00%	 22439		 -
# 4  Short offline	   Completed without error	   00%	 22271		 -
# 5  Extended offline	Completed without error	   00%	 22156		 -
# 6  Short offline	   Completed without error	   00%	 22103		 -
# 7  Short offline	   Completed without error	   00%	 21935		 -
# 8  Short offline	   Completed without error	   00%	 21768		 -
# 9  Short offline	   Completed without error	   00%	 21600		 -
#10  Short offline	   Completed without error	   00%	 21433		 -
#11  Extended offline	Completed without error	   00%	 21414		 -
#12  Short offline	   Completed without error	   00%	 21265		 -
#13  Short offline	   Completed without error	   00%	 21097		 -
#14  Short offline	   Completed without error	   00%	 20929		 -
#15  Short offline	   Completed without error	   00%	 20761		 -
#16  Extended offline	Completed without error	   00%	 20694		 -
#17  Short offline	   Completed without error	   00%	 20593		 -
#18  Short offline	   Completed without error	   00%	 20426		 -
#19  Short offline	   Completed without error	   00%	 20258		 -
#20  Short offline	   Completed without error	   00%	 20090		 -
#21  Extended offline	Completed without error	   00%	 19951		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
dnilgreb
4:
[root@NAS01] ~# smartctl -a /dev/ada3
Serial Number:	WD-WCC4EHRKCCTL
LU WWN Device Id: 5 0014ee 20aff63df
Local Time is:	Sun Aug 27 14:02:29 2017 CEST
										was never started.
										been run.
data collection:				(50880) seconds.
										command.
										power-saving mode.
recommended polling time:		( 509) minutes.
  3 Spin_Up_Time			0x0027   179   178   021	Pre-fail  Always	   -	   8050
  9 Power_On_Hours		  0x0032   069   069   000	Old_age   Always	   -	   22783
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   246
194 Temperature_Celsius	 0x0022   110   103   000	Old_age   Always	   -	   42
No Errors Logged
# 1  Short offline	   Completed without error	   00%	 22775		 -
# 6  Short offline	   Completed without error	   00%	 22104		 -
# 7  Short offline	   Completed without error	   00%	 21936		 -
#14  Short offline	   Completed without error	   00%	 20930		 -
#15  Short offline	   Completed without error	   00%	 20762		 -
#17  Short offline	   Completed without error	   00%	 20594		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
5:
[root@NAS01] ~# smartctl -a /dev/ada4
Serial Number:	WD-WCC4E7KA75KH
LU WWN Device Id: 5 0014ee 2b5b52c0d
Local Time is:	Sun Aug 27 14:03:10 2017 CEST
										was never started.
										been run.
data collection:				(55260) seconds.
										command.
										power-saving mode.
recommended polling time:		( 552) minutes.
  3 Spin_Up_Time			0x0027   175   174   021	Pre-fail  Always	   -	   8208
194 Temperature_Celsius	 0x0022   105   097   000	Old_age   Always	   -	   47
No Errors Logged
# 4  Short offline	   Completed without error	   00%	 22272		 -
# 5  Extended offline	Completed without error	   00%	 22157		 -
#11  Extended offline	Completed without error	   00%	 21415		 -
#16  Extended offline	Completed without error	   00%	 20695		 -
#20  Short offline	   Completed without error	   00%	 20091		 -
#21  Extended offline	Completed without error	   00%	 19952		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
6:
[root@NAS01] ~# smartctl -a /dev/ada5
Serial Number:	WD-WCC4ECAVN2NJ
LU WWN Device Id: 5 0014ee 20aff73da
Local Time is:	Sun Aug 27 14:04:02 2017 CEST
										was never started.
										been run.
data collection:				(51840) seconds.
										command.
										power-saving mode.
recommended polling time:		( 518) minutes.
  3 Spin_Up_Time			0x0027   180   179   021	Pre-fail  Always	   -	   8000
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   59
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   59
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   244
No Errors Logged
# 1  Short offline	   Completed without error	   00%	 17577		 -
# 2  Short offline	   Completed without error	   00%	 17410		 -
# 3  Short offline	   Completed without error	   00%	 17242		 -
# 4  Extended offline	Completed without error	   00%	 17079		 -
# 5  Short offline	   Completed without error	   00%	 16907		 -
# 6  Short offline	   Completed without error	   00%	 16739		 -
# 7  Short offline	   Completed without error	   00%	 16571		 -
# 8  Short offline	   Completed without error	   00%	 16403		 -
# 9  Extended offline	Completed without error	   00%	 16336		 -
#10  Short offline	   Completed without error	   00%	 16236		 -
#11  Short offline	   Completed without error	   00%	 16068		 -
#12  Short offline	   Completed without error	   00%	 15900		 -
#13  Short offline	   Completed without error	   00%	 15732		 -
#14  Extended offline	Completed without error	   00%	 15617		 -
#15  Short offline	   Completed without error	   00%	 15564		 -
#16  Short offline	   Completed without error	   00%	 15395		 -
#17  Short offline	   Completed without error	   00%	 15228		 -
#18  Short offline	   Completed without error	   00%	 15060		 -
#19  Short offline	   Completed without error	   00%	 14892		 -
#20  Extended offline	Completed without error	   00%	 14873		 -
#21  Short offline	   Completed without error	   00%	 14724		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
Jailer
Not strong, but bad
Overnight should be sufficient to show a problem if it exists.
Your drives look ok other than you don't have smart tests enabled for ada1.
Please provide a complete list of your hardware for proper troubleshooting.
dnilgreb
Interesting that SMART isn´t enabled for ada1. It is in the FreeNAS GUI. How can I enable it, and how can I make sure it is enabled?
On a side note, I talked to a frien of mine today, and he is having the exact same problem I am. As me, he is running FreeNAS 9.10.2-U6 and WD Red disks.
He upgraded to U6 from U5 about a week before I did, and the problem happened to him a week before I had it. Is there ANY chance that the U6 upgrade i causing it?
And if so, where to go? Revert to U5 or onward to 11?
Will get the memtest going asap.
dnilgreb
OK, so I ran memtest. For all of 90 seconds. That gave me 5031 errors. I guess I am getting some new RAM. Is that the solution, or could it be something else? Some other tests to run before running to the store?
Stux
You need to trouble shoot your ram a bit more.
Try to work out which slot or dimm is defective.
dnilgreb
Of course. Why didn´t I think of that? I´ll try to get that done tonight.
I am curious about this, though:
Since the GUI says it´s enabled for all drives, how can I ensure that I get SMART enabled for all drives?
Jailer
Not strong, but bad
Highlight them all and click save again.
dnilgreb
I´m very sorry, but I don´t understand what you mean by this. What do you want me to do?
dnilgreb
Got it!
Will take a look when I have FreNAS up and running again.
I´ve run memtest on all 4 of my sticks individually now, and found the bad one. All three remaining ones are running since last night, and when I left home this morning it had reached 7 hours with 0 errors. So that´s promising.
What is the best/correct procedure once I get a new memory stick? I thought I´ll insert it, and run memtest for a day or so. Then what?
I guess I am deleting the files reported as corrupt. Can I do something to make sure everything is in order before i scrub the volume?
After scrubbing, it should be safe to clear the errors, correct?
