Devices has experienced an error resulting in data corruption...Help!
L
LeftyMcToast
Guest
Hi everyone,
New to freenas and did something really stupid. My data is on one drive and the only off device backup is a little antiquated.
I got this error: "CRITICAL: March 28, 2018, 12:02 p.m. - The volume CentralNas state is ONLINE: One or more devices has experienced an error resulting in data corruption. Applications may be affected."
zpool status -v:
pool: CentralNas
state: ONLINE
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: http://illumos.org/msg/ZFS-8000-8A
scan: scrub repaired 0 in 0 days 01:28:08 with 4 errors on Sun Mar 25 01:28:10 2018
NAME STATE READ WRITE CKSUM
CentralNas ONLINE 0 0 2
gptid/....eli ONLINE 0 0 4
/mnt/CentralNas/Videos/TV Shows/...
/mnt/CentralNas/Pictures/...
/mnt/CentralNas/Music/Ubb/...
/mnt/CentralNas/Music/250 Music/...
<0x117>:<0x1caae>
CentralNas@BUSS5:/Pictures/...
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0 days 00:00:58 with 0 errors on Sun Mar 25 03:45:59 2018
freenas-boot ONLINE 0 0 0
da0p2 ONLINE 0 0 0
What should I do to salvage my data? I can't access the hd over the network anymore...
leenux_tux
Hi everyone,
zpool status -v:
pool: CentralNas
state: ONLINE
<0x117>:<0x1caae>
pool: freenas-boot
state: ONLINE
da0p2 ONLINE 0 0 0
What should I do to salvage my data? I can't access the hd over the network any more...
You say you can't access the HD over the network, however, can you ssh to the server and list files on the HD ? If so, copy them off somewhere (rsync perhaps?) to another system or maybe connect a USB drive, configure it as a standard disk and copy there ?
Sent from my A0001 using Tapatalk
