Ulrich Jorgensen
- Dec 1, 2016
I know it may sound simple, but I unsure which of my drives are faulty, can you assist and explain why?
Thank you
Thank you
[root@freenas02 ~]# zpool status pool: RAID10 state: DEGRADED status: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected. action: Determine if the device needs to be replaced, and clear the errors using 'zpool clear' or replace the device with 'zpool replace'. see: http://illumos.org/msg/ZFS-8000-9P scan: scrub repaired 10.0G in 4h27m with 0 errors on Sun Jan 28 04:27:06 2018 config: NAME STATE READ WRITE CKSUM RAID10 DEGRADED 0 0 0 mirror-0 ONLINE 0 0 0 gptid/322f058a-7f4e-11e6-951a-3464a99a6b68 ONLINE 0 0 0 gptid/32cd039a-7f4e-11e6-951a-3464a99a6b68 ONLINE 0 0 0 mirror-1 DEGRADED 0 0 0 gptid/336a48f2-7f4e-11e6-951a-3464a99a6b68 ONLINE 0 0 0 gptid/340588ee-7f4e-11e6-951a-3464a99a6b68 DEGRADED 0 0 104K too many errors errors: No known data errors pool: freenas-boot state: ONLINE scan: scrub repaired 0 in 0h0m with 0 errors on Sun Feb 4 03:45:24 2018 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 da0p2 ONLINE 0 0 0 errors: No known data errors
