I'm running TrueNAS-12.0-U4, and I'm having trouble replacing a failing drive on my system. The drive hadn't failed yet, but was starting to show current_pending_sector warnings. I offlined the drive from the Pool Status page, shut down the server, replaced the drive with a new higher capacity drive. I ran some burn in tests following the recommendations on https://www.truenas.com/community/resources/hard-drive-burn-in-testing.92/. After the tests finished, I tried using the replace option on the Pool Status page. I get the following error message:
What can I do to get this new drive added into the pool? Thanks in advance.
The output of `zpool status -v shepard_media` isError: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/zfs.py", line 277, in replace
target.replace(newvdev)
File "libzfs.pyx", line 391, in libzfs.ZFS.__exit__
File "libzfs.pyx", line 2060, in libzfs.ZFSVdev.replace
libzfs.ZFSException: already in replacing/spare config; wait for completion or use 'zpool detach'
File "/usr/local/lib/python3.9/concurrent/futures/process.py", line 243, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 94, in main_worker
res = MIDDLEWARE._run(*call_args)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 45, in _run
return self._call(name, serviceobj, methodobj, args, job=job)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 39, in _call
return methodobj(*params)
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 977, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/zfs.py", line 279, in replace
raise CallError(str(e), e.code)
middlewared.service_exception.CallError: [EZFS_BADTARGET] already in replacing/spare config; wait for completion or use 'zpool detach'
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 367, in run
await self.future
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 403, in __run_body
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 973, in nf
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool_/replace_disk.py", line 122, in replace
raise e
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool_/replace_disk.py", line 102, in replace
await self.middleware.call(
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1241, in call
return await self._call(
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1206, in _call
return await self._call_worker(name, *prepared_call.args)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1212, in _call_worker
return await self.run_in_proc(main_worker, name, args, job)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1139, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1113, in run_in_executor
pool: shepard_media
state: DEGRADED
status: One or more devices has been taken offline by the administrator.
Sufficient replicas exist for the pool to continue functioning in a
degraded state.
action: Online the device using 'zpool online' or replace the device with
'zpool replace'.
scan: scrub repaired 1M in 02:05:37 with 0 errors on Sun Jul 18 02:05:37 2021
NAME STATE READ WRITE CKSUM
shepard_media DEGRADED 0 0 0
raidz2-0 DEGRADED 0 0 0
gptid/2781e554-9730-11e6-bed5-4ccc6a0b9724 ONLINE 0 0 0
gptid/284bc412-9730-11e6-bed5-4ccc6a0b9724 ONLINE 0 0 0
gptid/29176154-9730-11e6-bed5-4ccc6a0b9724 ONLINE 0 0 0
gptid/29ec2715-9730-11e6-bed5-4ccc6a0b9724 ONLINE 0 0 0
gptid/2ac32abc-9730-11e6-bed5-4ccc6a0b9724 ONLINE 0 0 0
gptid/2b963e0f-9730-11e6-bed5-4ccc6a0b9724 OFFLINE 0 0 0
errors: No known data errors
