Back that NAS up
- Jun 27, 2022
Hi folks,
I'm confused on Bluefin's "Enable Host Path Safety Checks" as the title might imply. When install 22.12.1 I had to uncheck this option to run my given setup. I've since redone my pools and datasets, unrelated to this but with the idea that I could fix this as well, or at least so I thought.
I setup something like
tank <POOL>
-share (SMB) <DATASET>
--folder 1 (an app has access) <DATASET>
--folder 2 (an app has access) <DATASET>
But it looks like this doesn't work either? Is it not possible to enable the safety checks and have child datasets under a parent with SMB where the child is used by an app?
Thanks!
tank <POOL>
Thanks!
