- Feb 6, 2014
What is the “hostPathValidation” setting?
With the recent release of TrueNAS SCALE "Bluefin" 22.12.1, there have been a number of reports of issues with the Kubernetes "hostPathValidation" configuration setting, and requests for clarification regarding this security measure.
The “hostPathValidation” check is designed to prevent the simultaneous sharing of a dataset over a file-level protocol (SMB/NFS) while also being presented as hostPath storage to Kubernetes. This safety check prevents a container application from having the ability to accidentally perform a change in permissions or ownership to existing data in place on a ZFS dataset, or overwrite existing extended attribute (xattr) data, such as photo metadata on MacOS.
What’s the risk?
Disabling the hostPathValidation checkbox under Apps -> Settings -> Advanced Settings allows for this “shared access” to be possible, and opens up a small possibility for data loss or corruption when used incorrectly.
For example, an application that transcodes media files might, through misconfiguration or a bug within the application itself, accidentally delete an “original-quality” copy of a file and retain the lower-resolution transcoded version. Even with snapshots in place for data protection, if the problem is not detected prior to snapshot lifetime expiry, the original file could be lost forever.
Users with complex ACL schemes or who make use of extended attributes should take caution before disabling this functionality. The same risk applies to users running CORE with Jails or Plugins accessing data directly.
A change of this manner could result in data becoming unavailable to connected clients; and unless the permissions were very simplistic (single owner/group, recursive) reverting a large-scale change would require reverting to a previous ZFS snapshot. If no such snapshot exists, recovery would not be possible without manually correcting ownership and permissions.
When was this setting implemented?
In the initial SCALE release, Angelfish 22.02, there was no hostPathValidation check. As of Bluefin 22.12.0, the hostPathValidation setting was added and enabled by default. A bypass was discovered shortly thereafter, which allowed users to present a subdirectory or nested dataset of a shared dataset as a hostPath without needing to uncheck the hostPathValidation setting - thus exposing the potential for data loss. Another bypass was to stop SMB/NFS, start the application, and then start the sharing service again.
Both of these bypass methods were unintended, as they exposed a risk of data loss while the “hostPathValidation” setting was still set. These bugs were corrected in Bluefin 22.12.1, and as such, TrueNAS SCALE Apps that were dependent on these bugs being present in order to function will no longer deploy or start unless the hostPathValidation check is removed.
What’s the future plan for this setting?
We have received significant feedback that these changes and the validation itself have caused challenges. In a future release of TrueNAS SCALE, we will be moving away from a system-wide hostPathValidation checkbox, and instead providing a warning dialog that will appear during the configuration of the hostPath storage for any TrueNAS Apps that conflict with existing SMB/NFS shares.
Users can make the decision to proceed with the hostPath configuration at that time, or cancel the change and set up access to the folder through another method.
If data must be shared between SMB and hostPath, how can these risks be mitigated?
Some applications allow for connections to SMB or NFS resources within the app container itself. This may require additional network configuration, such as a network bridge interface as described in the TrueNAS docs “Accessing NAS from a VM” as well as creating and using a user account specific to the application.
https://www.truenas.com/docs/scale/scaletutorials/virtualization/accessingnasfromvm/
Users who enable third-party catalogs, such as TrueCharts, can additionally use different container path mount methods such as connecting to an NFS export. Filesystem permissions will need to be assigned to the data for the apps user in this case.
We at iX appreciate your feedback.
What’s the risk?
