I have Emby installed and ever since i moved to scale it has not working with a simple install.
I previously edited the yaml files and get it to deploy successfully, however now I start to see where the source of the issue is
If I install with "Enable Host Network" checked, it gets stuck on deploying and if you click on the app, it shows;
Used Ports:8096\TCP, 1900\UDP, 7359\UDP
Even though it shows as deploying, the app actually works and is accessible via 9096, but shows as stuck in deploying.
If you click on Appl Events, you see
Startup probe failed: Get "http://192.168.x.x:8096/emby/System/Ping": dial tcp 192.168.24.15:8096: connect: connection refused
(this is where i modified the yaml files before to fix, but it has to be done for every update.
I created a jira ticket, and they closed it has nothing wrong - really bad support from the charts group)
If I install with "Enable Host Network" unchecked, it gets stuck on deploying and if you click on the app, it shows;
Used Ports:9096\TCP, 8096\TCP, 1900\UDP, 7359\UDP
Even though it shows as deploying, the app does not work and is not accessible via either 8096 nor 9096.
If you click on App Events, you still see
What exactly does not "Enable Host Network" actually do?
To get emby to work;
- "Enable Host Network" needs to be checked
- you need to edit "ix-applications/releases/emby/charts/1.0.18/templates"
deployment.yaml, service-tcp.yaml and portal.tpl and replace the 8096 with 9096
- within emby, you need to set the 8096 port to 9096
It doesn't solve the
"Startup probe failed: Get "http://192.168.x.x:8096/emby/System/Ping": dial tcp 192.168.x.x:8096: connect: connection refused"
but it does fixed the deployment stuck
Really don't understand why after all this time, they can't solve this issue. obviously there is a config issue with their template
