asdman21132
- Feb 3, 2024
I've been trying to deploy Lidarr for a while now, but It refuses to work. Nothing is running on it's web portal. I've tired deploying it previously, but then I got an SSL error and all my apps broke. After that, I had to go away from home, so I left it like that. The issue somehow fixed itself the next weekend. Now I have Nextcloud running fine and my Lidarr install disappeared. The problem: I reinstalled it and it still doesn't works. It's stuck on deploying and I get thus error after
Thanks for your help in advance!
Lidarr:
App Version: 2.1.6.3993
Chart Version: 1.2.14
TrueNAS Scale version: 23.10.1.3
Created container lidarr:
Startup probe failed: Get "http://172.16.0.78:30014/ping": dial tcp 172.16.0.78:30014: connect: connection refused
Lidarr:
