MorMadness
- Mar 25, 2022
First off, running TrueNAS Scale 22.02.0.1 and I tried to install emby server via the truecharts app and was able to get it to work except casting to chrome within my network. this is due to my lack of total understanding of K3s. The emby server kept getting blinded to the K3 network and not my local network so while I could access the interface via the K3 port it would not cast. This may or may not be a bug, I am just not savy enough to know.
Sooooo, now on to a real problem. I then decided to install emby via the docker image and it works perfect, have no issue WHILE IT IS RUNNING, it casts fine to all my devices. The second you restart the docker or reboot the server emby is reset to default settings. Yes, any restart of the app or restart of the TrueNAS server will erase all configurations and I have to setup the emby server again. which i have backups so it only takes me about 5 mins to get it back, however it takes over an hour to rebuild all the libraries. it is really annoying that anytime you restart the app it clears, is this a bug or have I configured this incorrectly?
