tmacka88
- Jul 5, 2011
Hi, since I have setup email notifications with smart extras '-m root', I receive two daily emails one a security run output and one daily run output. In the daily run I am getting this
"status: One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected."
This is the whole email:
Removing stale files from /var/preserve:
Cleaning out old system announcements:
Backup passwd and group files:
no /var/backups/master.passwd.bak
no /var/backups/group.bak
Verifying group file syntax:
/etc/group is fine
Disk status:
Filesystem Size Used Avail Capacity Mounted on
/dev/ufs/FreeNASs1a 927M 429M 424M 50% /
devfs 1.0K 1.0K 0B 100% /dev
/dev/md0 4.3M 3.5M 420K 90% /etc
/dev/md1 732K 16K 660K 2% /mnt
/dev/md2 75M 20M 48M 30% /var
/dev/ufs/FreeNASs4 20M 667K 18M 4% /data
Volume1 3.6T 2.4T 1.2T 66% /mnt/Volume1
Last dump(s) done (Dump '>' file systems):
Checking status of zfs pools:
pool: Volume1
state: ONLINE
see: http://www.sun.com/msg/ZFS-8000-9P
scrub: none requested
NAME STATE READ WRITE CKSUM
Volume1 ONLINE 0 0 0
raidz1 ONLINE 0 0 0
gptid/29204abe-d29d-11e0-b9cd-f46d04de02ec ONLINE 0 0 2
gptid/2a07f729-d29d-11e0-b9cd-f46d04de02ec ONLINE 0 0 0
gptid/2ad9f58b-d29d-11e0-b9cd-f46d04de02ec ONLINE 0 0 0
errors: No known data errors
Checking status of ATA raid partitions:
Checking status of gmirror(8) devices:
Checking status of graid3(8) devices:
Checking status of gstripe(8) devices:
Network interface status:
Name Mtu Network Address Ipkts Ierrs Idrop Opkts Oerrs Coll
alc0* 1500 <Link#1> f4:6d:04:de:02:ec 0 0 0 0 0 0
sk0* 1500 <Link#2> 00:1b:11:0f:f1:73 0 0 0 0 0 0
em0 1500 <Link#3> 00:04:23:a8:ba:c8 27802 0 0 2169 0 0
em1 1500 <Link#4> 00:04:23:a8:ba:c8 1208712 3 0 1446663 0 0
lo0 16384 <Link#5> 1375 0 0 1375 0 0
lo0 16384 fe80:5::1 fe80:5::1 0 - - 0 - -
lo0 16384 localhost ::1 0 - - 0 - -
lo0 16384 your-net localhost 1356 - - 1375 - -
lagg0 1500 <Link#6> 00:04:23:a8:ba:c8 1236850 0 0 1448832 0 0
lagg0 1500 192.168.2.0 192.168.2.19 1191281 - - 1447625 - -
Security check:
(output mailed separately)
Checking for denied zone transfers (AXFR and IXFR):
Scrubbing of zfs pools:
skipping scrubbing of pool 'Volume1':
last scrubbing is 22 days ago, threshold is set to 30 days
Checking status of 3ware RAID controllers:
Alarms (most recent first):
+++ /var/log/3ware_raid_alarms.today 2011-09-22 03:01:24.000000000 +0930
@@ -0,0 +1 @@
-- End of daily output --
Now yesterday when I got it I though it was cause I tried testing the email function by pulling out a data cable to see if the email was sent (it didn't) so I restarted the system hoping it would get rid of the problem. Seems i did not.
In the console this is what is being displayed:
len :0, unexpected EOF
read : Connection reset by peer
error reading message header : Connection reset by peer
Some of these repeating.
Any help would be great..
Thanks
/etc/group is fine
Disk status:
pool: Volume1
state: ONLINE
raidz1 ONLINE 0 0 0
Security check:
@@ -0,0 +1 @@
Thanks
