I'm getting status mails every morning from my NAS, and since I'm not from tne *nix world I'm not understanding all of it. My biggest conern is that a drive is starting to fail and I won't know. How will I know?
The mail I'm getting contains this, what is what?
Removing stale files from /var/preserve: Cleaning out old system announcements: Backup passwd and group files: Verifying group file syntax: /etc/group is fine Disk status: Filesystem Size Used Avail Capacity Mounted on /dev/ufs/FreeNASs1a 927M 422M 431M 49% / devfs 1.0K 1.0K 0B 100% /dev /dev/md0 4.4M 2.4M 1.6M 60% /etc /dev/md1 686K 8.0K 624K 1% /mnt /dev/md2 75M 16M 53M 23% /var /dev/ufs/FreeNASs4 20M 1.0M 17M 5% /data panda 5.3T 2.8T 2.5T 53% /mnt/panda Last dump(s) done (Dump '>' file systems): Checking status of zfs pools: all pools are healthy Checking status of ATA raid partitions: Checking status of gmirror(8) devices: Checking status of graid3(8) devices: Checking status of gstripe(8) devices: Network interface status: Name Mtu Network Address Ipkts Ierrs Idrop Opkts Oerrs Coll re0 1500 <Link#1> 00:19:db:b3:4e:94 394811953 0 0 665720176 0 0 re0 1500 192.168.0.0 192.168.0.100 394582601 - - 665704430 - - lo0 16384 <Link#2> 231820 0 0 231820 0 0 lo0 16384 fe80:2::1 fe80:2::1 0 - - 0 - - lo0 16384 localhost ::1 0 - - 0 - - lo0 16384 your-net localhost 231774 - - 231820 - - Security check: (output mailed separately) Checking for denied zone transfers (AXFR and IXFR): Scrubbing of zfs pools: skipping scrubbing of pool 'panda': last scrubbing is 17 days ago, threshold is set to 30 days Checking status of 3ware RAID controllers: Alarms (most recent first): No new alarms. -- End of daily output --
