MGone
- Feb 16, 2022
My 'on paper' specs have taken a bit of a tangent and I've been looking at Ryzen builds as a possibility on the X470D4U motherboard.
But I'm having a really hard time trying to find any of the rather limited ECC QVL memory.
I manged to decode the module name for the Samsung 32GB ECC 2666 DIMM (M391A4G43MB1-CTDQ) using this guide (except the 'Q' and I'm unsure how to interpret that). The rest gives me the following:
M: Memory Module
3: DIMM
91: x72 288pin ECC Unbuffered DIMM
A: DDR4 SDRAM (1.2V VDD)
4G: 4 Gang depth
4: 16Banks & POD-1.2V
3: x 8 Bit Organisation
M: 1st Generation
B: FBGA (Halogen-free & Lead-free, Flip Chip)
1: PCB Revision 1st Rev
C: Commercial Temp.(0°C ~ 85°C) & Normal Power
TD: DDR4-2666 (1333MHz @ CL=19, tRCD=19, tRP=19)
Q : no indication of what this might be, other than the label suggests Memory Buffer....maybe Q means no buffer?
I've had one source say they might be able to get sticks that have the same code but without the Q, but they were not 100% confident in that.
So my question is which bits are important to ensure compatibility?
If I find any 32GB DDR4-2666 288pin ECC 1.2v Unbuffered CL19 DIMM modules should they just work, or am I rolling the dice?
M: Memory Module
3: DIMM
4G: 4 Gang depth
M: 1st Generation
