Hello everyone !
It's been a while that I'm thinking about upgrading my current NAS, which is an old 2 bay Synology.
I was happy with it until now, but I'll recycle it to handle data from my cameras.
I initially thought about purchasing another Synology, the ds923+.
Atfer lots of research, it started to feel a bit underpowered for the price.
I already knew TrueNAS (FreeNAS) but never really used it for "important" data.
So I started to read a lot of posts here, and the hardware recommendation, and came up with the following ideas, for which I'd like to get your opinion :
Motherboard: ASRock Rack X570D4U
CPU: Ryzen 5 pro 4650g, maybe Ryzen 5 3600X
Memory: 32Gb ddr4 ECC unbuffered udimm (still trying to find some available from the QVL)
HDD boot: 1x SSD
HDD data: 2x 8Tb (leaving room to upgrade to another 2x 8Tb when time comes)
Power unit: not sure, probably a gold 500w ?
I don't need a lot of power, so I could probably downsize a bit the CPU, but I was not sure about ECC.
From the specs, I see that pro models with graphics should be fine, that's why I initiallty chose the 4650g, but it's maybe overkill.
I'd like to keep a low wattage if possible.
Thanks already !
David
HDD boot: 1x SSD
Thanks already !
David
