KazuyaDarklight
- May 8, 2019
I've started backing up my server to cloud storage. At the time I thought encrypted with encrypted file names was the way to go. Obviously its the most secure, however, I started really thinking about what restoration would be like and while it will be easy enough to restore the entire backup, I'm not sure if there is a good way to prioritize sections. Ex. I have a media dataset, but maybe I want to prioritize the videos folder inside it. Is there an easy way to figure out/decrypt the file/folder name with the key/hash in hand? Or is it going to be more effort than its worth? Maybe I should restart with names unencrypted?
Thoughts? Thank you for your time.
