Downgrade Help
lanky8804
I'll start by saying sorry as im sure this has been answered before but i cannot find any clear guide.
I have just upgraded to 9.2.1.6 which is causing lots of issues, i would like to downgrade to 9.2.1.5.
I have my config from 9.2.1.5 and i have the img file and key.
What i am really concerned about is loosing my data.
Am i right in thinking that you install the image file onto your USB. Plug in, boot up then upload config file and everything will work? (jails, data, plugins??)
You are correct. You can roll back to 9.2.1.5 just like you think you can. ;)
diedrichg
What about a pool import and no config backup from, say, 9.2.1.6 to 9.2.1.3?
You could do that too.
