indivision
 - Jan 4, 2013
I'm trying to get as far as I can troubleshooting and learning about docker use from those platforms documentation. But, I'm a bit stuck due to not knowing how it is implemented within Scale.
For example, many available documents refer to using "kubectl" commands. But, within Scale, the command doesn't seem available in the main shell or within app shells. Is it possible to access that command? Or, is there an equivalent available and I'm using the wrong command?
I have an app installed as "ClusterIP" for networking. However, I'm not really sure how to access it. When creating the app (qbittorrent) it lists the port to be exposed for the UI. But, that port doesn't seem to work. I haven't tried it yet. But, I can likely get NodeIP to work. But, since ClusterIP is the default with docker, I'm wanting to figure out how to work with that config.
Any help would be appreciated.
