kpieckiel
- Nov 27, 2020
Greetings!
I'm trying to determine if I need to replace a hard drive. My knee-jerk reaction is 'yes', but your advice would be appreciated.
I have a a warning on one of my pools, and it appears that one of my drives in that pool has some read errors.
I checked the SMART status, and the drive reports that it's healthy...
...despite the error log showing some errors.
So is my drive failing, or is this transient? Here is the drive information.
Thank you for your guidance,
Kevin
=== START OF READ SMART DATA SECTION === SMART Health Status: OK
Error counter log: Errors Corrected by Total Correction Gigabytes Total ECC rereads/ errors algorithm processed uncorrected fast | delayed rewrites corrected invocations [10^9 bytes] errors read: 3028206483 234 0 3028206717 239 94456.174 5 write: 0 0 0 0 0 15022.415 0 Non-medium error count: 4
=== START OF INFORMATION SECTION === Vendor: SEAGATE Product: ST4000NM0023 Revision: 0004 Compliance: SPC-4 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Logical block size: 512 bytes LU is fully provisioned Rotation Rate: 7200 rpm Form Factor: 3.5 inches Logical Unit id: 0x5000c5008f5ca9a7 Serial number: <redacted> Device type: disk Transport protocol: SAS (SPL-3) Local Time is: Fri Nov 27 05:08:01 2020 EST SMART support is: Available - device has SMART capability. SMART support is: Enabled Temperature Warning: Enabled
Kevin
