Is there a way to disable the automatic mounting process for specific storages ? I tried unchecking the "mounted" checkbox, thinking it would be permanent, but whet I restarded my jail the storage ended up being automatically mounted and the checkbox checked again. Sure I could remove the storage and add it again when needed, but I thought there would be some easier way.
Thanks
Thanks
