mount fdescfs in Jail for Bash
Chillons
Hi
I recently installed Bash in a Jail. Bash requires fdescfs for full functionality. The following note gets displayed:
Message from bash-4.3.42_1:
bash requires fdescfs(5) mounted on /dev/fd
If you have not done it yet, please do the following:
    mount -t fdescfs fdesc /dev/fd
To make it permanent, you need the following lines in /etc/fstab:
    fdesc    /dev/fd        fdescfs        rw    0    0
If I try to mount it in a jail i get a permission denied error.
root@jail:/ # mount -t fdescfs fdesc /dev/fd
mount: fdesc: Operation not permitted
I found this link, but it does not explain where the line "jail_jboss6_fdescfs_enable="YES" # mount fdescfs in the jail" should be put.
How to provide fdescfs to a jail? Where should this be put to make it permanently?
D
dlavigne
Guest
Looks like an rc.conf tunable on the FreeNAS system. No idea whether or not it will work or not though.
