DELL Perc VS raidZ
webstyler
Hello
We have DELL 2950 with PERC 6 on board
We would like to manage Raid throught PERC by raid5, instead on RaidZ
This could be generate problems with FREENAS (v. 9.10) ?
Thanks
Dice
Yes.
Check the cyberjocks newbie guide and hardware recommendations (stickie threads). They provide you with a lot of insight in system design (and answers your current question and numerous other 'need to know' aspects of taking the plunge into freenas. It is not that simple.
joeschmuck
Old Man
If you want to use the PERC card as a RAID5, do not use FreeNAS as the software. There are other software options but for what you want, FreeNAS is not what you should use, unless you don't mind your data disappearing one day. FreeNAS is designed to run using the ZFS software RAID and this also makes it portable, meaning that you can take your hard drives to any other piece of computer hardware, plug in the drives, and boot FreeNAS and have access to your data. You don't need a specific RAID card to get your data back.
pirateghost
Unintelligible Geek
The answer to this is literally in the documentation and FreeNAS website....
pirateghost
Unintelligible Geek
maglin
You really should look at the different schemes for array management and see what is better for your environment.
Most of the time ZFS is preferred as your array has better redundancy options along with not being handcuffed to specific hardware. I think hardware raid is dead for the most part. But there are probably situations that requires it I don't know about.
Mirfster
In any case, ditch the PERC 6. It can't drive space over 2.2 TB, so if you attached a 8 TB drive it would only show you 2.2 TB.
But as others have said HW Raid and FreeNas are a big "no no".
webstyler
Thanks guys
PERC6 haven't mode "direct" so the only way I have found is to create 1 virtual group and virtual disk for any single HD..
Mirfster
Yes, but this is highly UN-Recommended.... You are not wanting to do this and will be sorry if you proceed down that line...
