Deleting DataStores Problems
RodrigoLopes
Hello there once again,
I'm in need of help.
I was trying to delete a DataStore so that i can't change the space that it is using but i keep getting an error.
Already deleted the SMB share.
Could you please advise.
D
dlavigne
Guest
Anything in /var/log/messages when you reproduce that error?
RodrigoLopes
RodrigoLopes
Try using more /var/log/messages
I manage to get the output but it is huge...
root@FreeNas:~ # more /var/log/messages
Jan 30 17:40:22 FreeNas newsyslog[1935]: logfile first created
Jan 30 17:40:38 FreeNas syslog-ng[1955]: syslog-ng starting up; version='3.14.1'
Jan 30 17:40:38 FreeNas Copyright (c) 1992-2018 The FreeBSD Project.
Jan 30 17:40:38 FreeNas Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
Jan 30 17:40:38 FreeNas The Regents of the University of California. All rights reserved.
Jan 30 17:40:38 FreeNas FreeBSD is a registered trademark of The FreeBSD Foundation.
Jan 30 17:40:38 FreeNas FreeBSD 11.2-STABLE #0 r325575+fc3d65faae6(HEAD): Thu Dec 20 16:12:30 EST 2018
Jan 30 17:40:38 FreeNas root@nemesis.tn.ixsystems.com:/freenas-releng-final/freenas/_BE/objs/freenas-releng-final/freenas/_BE/os/sys/FreeNAS.amd64 amd64
Jan 30 17:40:38 FreeNas FreeBSD clang version 6.0.0 (tags/RELEASE_600/final 326565) (based on LLVM 6.0.0)
Jan 30 17:40:38 FreeNas VT(vga): resolution 640x480
Jan 30 17:40:38 FreeNas CPU: Intel(R) Core(TM) i3 CPU 530 @ 2.93GHz (2926.06-MHz K8-class CPU)
Jan 30 17:40:38 FreeNas Origin="GenuineIntel" Id=0x20652 Family=0x6 Model=0x25 Stepping=2
Jan 30 17:40:38 FreeNas Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
Jan 30 17:40:38 FreeNas Features2=0x98e3bd<SSE3,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,SSE4.1,SSE4.2,POPCNT>
Jan 30 17:40:38 FreeNas AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM>
Jan 30 17:40:38 FreeNas AMD Features2=0x1<LAHF>
Jan 30 17:40:38 FreeNas VT-x: PAT,HLT,MTF,PAUSE,EPT,UG,VPID
Jan 30 17:40:38 FreeNas TSC: P-state invariant, performance statistics
Jan 30 17:40:38 FreeNas real memory = 4294967296 (4096 MB)
Jan 30 17:40:38 FreeNas avail memory = 3942735872 (3760 MB)
Jan 30 17:40:38 FreeNas Event timer "LAPIC" quality 600
Jan 30 17:40:38 FreeNas ACPI APIC Table: <ACRSYS APIC0935>
Jan 30 17:40:38 FreeNas FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
Jan 30 17:40:38 FreeNas FreeBSD/SMP: 1 package(s) x 2 core(s) x 2 hardware threads
Jan 30 17:40:38 FreeNas WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
Jan 30 17:40:38 FreeNas Firmware Warning (ACPI): 32/64X length mismatch in FADT/Gpe0Block: 128/64 (20171214/tbfadt-748)
Jan 30 17:40:38 FreeNas ioapic0: Changing APIC ID to 6
Jan 30 17:40:38 FreeNas ioapic0 <Version 2.0> irqs 0-23 on motherboard
Jan 30 17:40:38 FreeNas SMP: AP CPU #1 Launched!
Jan 30 17:40:38 FreeNas SMP: AP CPU #2 Launched!
Jan 30 17:40:38 FreeNas SMP: AP CPU #3 Launched!
Jan 30 17:40:38 FreeNas Timecounter "TSC-low" frequency 1463031234 Hz quality 1000
Jan 30 17:40:38 FreeNas random: entropy device external interface
Jan 30 17:40:38 FreeNas kbd1 at kbdmux0
Jan 30 17:40:38 FreeNas nexus0
Jan 30 17:40:38 FreeNas vtvga0: <VT VGA driver> on motherboard
Jan 30 17:40:38 FreeNas cryptosoft0: <software crypto> on motherboard
Jan 30 17:40:38 FreeNas aesni0: No AESNI support.
Jan 30 17:40:38 FreeNas padlock0: No ACE support.
Jan 30 17:40:38 FreeNas acpi0: <ACRSYS ACRPRDCT> on motherboard
Jan 30 17:40:38 FreeNas acpi0: Power Button (fixed)
Jan 30 17:40:38 FreeNas cpu0: <ACPI CPU> on acpi0
Jan 30 17:40:38 FreeNas cpu1: <ACPI CPU> on acpi0
Jan 30 17:40:38 FreeNas cpu2: <ACPI CPU> on acpi0
Jan 30 17:40:38 FreeNas cpu3: <ACPI CPU> on acpi0
Jan 30 17:40:38 FreeNas attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0
Jan 30 17:40:38 FreeNas Timecounter "i8254" frequency 1193182 Hz quality 0
Jan 30 17:40:38 FreeNas Event timer "i8254" frequency 1193182 Hz quality 100
Jan 30 17:40:38 FreeNas atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
Jan 30 17:40:38 FreeNas atrtc0: registered as a time-of-day clock, resolution 1.000000s
Jan 30 17:40:38 FreeNas Event timer "RTC" frequency 32768 Hz quality 0
Jan 30 17:40:38 FreeNas hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Jan 30 17:40:38 FreeNas Timecounter "HPET" frequency 14318180 Hz quality 950
Jan 30 17:40:38 FreeNas Event timer "HPET" frequency 14318180 Hz quality 550
Jan 30 17:40:38 FreeNas Event timer "HPET1" frequency 14318180 Hz quality 440
Jan 30 17:40:38 FreeNas Event timer "HPET2" frequency 14318180 Hz quality 440
Jan 30 17:40:38 FreeNas Event timer "HPET3" frequency 14318180 Hz quality 440
Jan 30 17:40:38 FreeNas Event timer "HPET4" frequency 14318180 Hz quality 440
Jan 30 17:40:38 FreeNas Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
Jan 30 17:40:38 FreeNas acpi_timer0: <24-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0
Jan 30 17:40:38 FreeNas pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
Jan 30 17:40:38 FreeNas pcib0: _OSC returned error 0x10
Jan 30 17:40:38 FreeNas pci0: <ACPI PCI bus> on pcib0
Jan 30 17:40:38 FreeNas pcib1: <ACPI PCI-PCI bridge> irq 16 at device 1.0 on pci0
Jan 30 17:40:38 FreeNas pci1: <ACPI PCI bus> on pcib1
Jan 30 17:40:38 FreeNas vgapci0: <VGA-compatible display> port 0xdc00-0xdc7f mem 0xfa000000-0xfaffffff,0xd0000000-0xdfffffff,0xce000000-0xcfffffff irq 16 at device 0.0 on pci1
Jan 30 17:40:38 FreeNas vgapci0: Boot video device
Jan 30 17:40:38 FreeNas pci1: <multimedia, HDA> at device 0.1 (no driver attached)
Jan 30 17:40:38 FreeNas pci0: <simple comms> at device 22.0 (no driver attached)
Jan 30 17:40:38 FreeNas em0: <Intel(R) PRO/1000 Network Connection 7.6.1-k> port 0xcc00-0xcc1f mem 0xf9fc0000-0xf9fdffff,0xf9ffc000-0xf9ffcfff irq 20 at device 25.0 on pci0
Jan 30 17:40:38 FreeNas em0: Using an MSI interrupt
Jan 30 17:40:38 FreeNas em0: Ethernet address: 90:fb:a6:46:4c:11
Jan 30 17:40:38 FreeNas ehci0: <Intel PCH USB 2.0 controller USB-B> mem 0xf9ffa000-0xf9ffa3ff irq 16 at device 26.0 on pci0
Jan 30 17:40:38 FreeNas usbus0: EHCI version 1.0
Jan 30 17:40:38 FreeNas usbus0 on ehci0
Jan 30 17:40:38 FreeNas usbus0: 480Mbps High Speed USB v2.0
Jan 30 17:40:38 FreeNas pci0: <multimedia, HDA> at device 27.0 (no driver attached)
Jan 30 17:40:38 FreeNas pcib2: <ACPI PCI-PCI bridge> irq 17 at device 28.0 on pci0
Jan 30 17:40:38 FreeNas pcib2: [GIANT-LOCKED]
Jan 30 17:40:38 FreeNas pcib3: <ACPI PCI-PCI bridge> irq 16 at device 28.1 on pci0
Jan 30 17:40:38 FreeNas pcib3: [GIANT-LOCKED]
Jan 30 17:40:38 FreeNas pcib4: <ACPI PCI-PCI bridge> irq 18 at device 28.2 on pci0
Jan 30 17:40:38 FreeNas pcib4: [GIANT-LOCKED]
Jan 30 17:40:38 FreeNas pcib5: <ACPI PCI-PCI bridge> irq 19 at device 28.3 on pci0
Jan 30 17:40:38 FreeNas pcib5: [GIANT-LOCKED]
Jan 30 17:40:38 FreeNas pcib6: <ACPI PCI-PCI bridge> irq 17 at device 28.4 on pci0
Jan 30 17:40:38 FreeNas pcib6: [GIANT-LOCKED]
Jan 30 17:40:38 FreeNas pci2: <ACPI PCI bus> on pcib6
Jan 30 17:40:38 FreeNas pci2: <serial bus, FireWire> at device 0.0 (no driver attached)
Jan 30 17:40:38 FreeNas pcib7: <ACPI PCI-PCI bridge> irq 18 at device 28.6 on pci0
Jan 30 17:40:38 FreeNas pcib7: [GIANT-LOCKED]
Jan 30 17:40:38 FreeNas pcib8: <ACPI PCI-PCI bridge> irq 19 at device 28.7 on pci0
Jan 30 17:40:38 FreeNas pcib8: [GIANT-LOCKED]
Jan 30 17:40:38 FreeNas ehci1: <Intel PCH USB 2.0 controller USB-A> mem 0xf9ff8000-0xf9ff83ff irq 23 at device 29.0 on pci0
Jan 30 17:40:38 FreeNas usbus1: EHCI version 1.0
Jan 30 17:40:38 FreeNas usbus1 on ehci1
Jan 30 17:40:38 FreeNas usbus1: 480Mbps High Speed USB v2.0
Jan 30 17:40:38 FreeNas pcib9: <ACPI PCI-PCI bridge> at device 30.0 on pci0
Jan 30 17:40:38 FreeNas pci3: <ACPI PCI bus> on pcib9
Jan 30 17:40:38 FreeNas isab0: <PCI-ISA bridge> at device 31.0 on pci0
Jan 30 17:40:38 FreeNas isa0: <ISA bus> on isab0
Jan 30 17:40:38 FreeNas ahci0: <Intel Ibex Peak AHCI SATA controller> port 0xc880-0xc887,0xc800-0xc803,0xc480-0xc487,0xc400-0xc403,0xc080-0xc09f mem 0xf9ff2000-0xf9ff27ff irq 19 at device 31.2 on pci0
Jan 30 17:40:38 FreeNas ahci0: AHCI v1.30 with 6 3Gbps ports, Port Multiplier not supported
Jan 30 17:40:38 FreeNas ahcich0: <AHCI channel> at channel 0 on ahci0
Jan 30 17:40:38 FreeNas ahcich1: <AHCI channel> at channel 1 on ahci0
Jan 30 17:40:38 FreeNas ahcich2: <AHCI channel> at channel 2 on ahci0
Jan 30 17:40:38 FreeNas ahcich3: <AHCI channel> at channel 3 on ahci0
Jan 30 17:40:38 FreeNas ahcich4: <AHCI channel> at channel 4 on ahci0
Jan 30 17:40:38 FreeNas ahcich5: <AHCI channel> at channel 5 on ahci0
Jan 30 17:40:38 FreeNas acpi_button0: <Power Button> on acpi0
Jan 30 17:40:38 FreeNas atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
Jan 30 17:40:38 FreeNas atkbd0: <AT Keyboard> irq 1 on atkbdc0
Jan 30 17:40:38 FreeNas kbd0 at atkbd0
Jan 30 17:40:38 FreeNas atkbd0: [GIANT-LOCKED]
Jan 30 17:40:38 FreeNas ichwd0: <Intel H57 watchdog timer> on isa0
Jan 30 17:40:38 FreeNas coretemp0: <CPU On-Die Thermal Sensors> on cpu0
Jan 30 17:40:38 FreeNas est0: <Enhanced SpeedStep Frequency Control> on cpu0
Jan 30 17:40:38 FreeNas coretemp1: <CPU On-Die Thermal Sensors> on cpu1
Jan 30 17:40:38 FreeNas est1: <Enhanced SpeedStep Frequency Control> on cpu1
Jan 30 17:40:38 FreeNas coretemp2: <CPU On-Die Thermal Sensors> on cpu2
Jan 30 17:40:38 FreeNas est2: <Enhanced SpeedStep Frequency Control> on cpu2
Jan 30 17:40:38 FreeNas coretemp3: <CPU On-Die Thermal Sensors> on cpu3
Jan 30 17:40:38 FreeNas est3: <Enhanced SpeedStep Frequency Control> on cpu3
Jan 30 17:40:38 FreeNas ZFS NOTICE: Prefetch is disabled by default if less than 4GB of RAM is present;
Jan 30 17:40:38 FreeNas to enable, add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf.
Jan 30 17:40:38 FreeNas ZFS filesystem version: 5
Jan 30 17:40:38 FreeNas ZFS storage pool version: features support (5000)
Jan 30 17:40:38 FreeNas Timecounters tick every 1.000 msec
Jan 30 17:40:38 FreeNas freenas_sysctl: adding account.
Jan 30 17:40:38 FreeNas freenas_sysctl: adding directoryservice.
Jan 30 17:40:38 FreeNas freenas_sysctl: adding middlewared.
Jan 30 17:40:38 FreeNas freenas_sysctl: adding network.
Jan 30 17:40:38 FreeNas freenas_sysctl: adding services.
Jan 30 17:40:38 FreeNas ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
Jan 30 17:40:38 FreeNas ugen0.1: <Intel EHCI root HUB> at usbus0
Jan 30 17:40:38 FreeNas ugen1.1: <Intel EHCI root HUB> at usbus1
Jan 30 17:40:38 FreeNas uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
Jan 30 17:40:38 FreeNas uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
Jan 30 17:40:38 FreeNas uhub0: 2 ports with 2 removable, self powered
Jan 30 17:40:38 FreeNas uhub1: 2 ports with 2 removable, self powered
Jan 30 17:40:38 FreeNas ugen0.2: <vendor 0x8087 product 0x0020> at usbus0
Jan 30 17:40:38 FreeNas uhub2 on uhub0
Jan 30 17:40:38 FreeNas uhub2: <vendor 0x8087 product 0x0020, class 9/0, rev 2.00/0.00, addr 2> on usbus0
Jan 30 17:40:38 FreeNas ugen1.2: <vendor 0x8087 product 0x0020> at usbus1
Jan 30 17:40:38 FreeNas uhub3 on uhub1
Jan 30 17:40:38 FreeNas uhub3: <vendor 0x8087 product 0x0020, class 9/0, rev 2.00/0.00, addr 2> on usbus1
Jan 30 17:40:38 FreeNas uhub2: 6 ports with 6 removable, self powered
Jan 30 17:40:38 FreeNas uhub3: 8 ports with 8 removable, self powered
Jan 30 17:40:38 FreeNas ugen0.3: <USB DISK 2.0> at usbus0
Jan 30 17:40:38 FreeNas umass0 on uhub2
Jan 30 17:40:38 FreeNas umass0: <USB DISK 2.0, class 0/0, rev 2.00/11.00, addr 3> on usbus0
Jan 30 17:40:38 FreeNas umass0: SCSI over Bulk-Only; quirks = 0x4000
Jan 30 17:40:38 FreeNas umass0:7:0: Attached to scbus7
Jan 30 17:40:38 FreeNas ugen0.4: <Generic USB2.0-CRW> at usbus0
Jan 30 17:40:38 FreeNas umass1 on uhub2
Jan 30 17:40:38 FreeNas umass1: <Bulk-In, Bulk-Out, Interface> on usbus0
Jan 30 17:40:38 FreeNas umass1: SCSI over Bulk-Only; quirks = 0x4000
Jan 30 17:40:38 FreeNas umass1:8:1: Attached to scbus8
Jan 30 17:40:38 FreeNas ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
Jan 30 17:40:38 FreeNas ada0: <WDC WD10EADS-22M2B0 01.00A01> ATA8-ACS SATA 2.x device
Jan 30 17:40:38 FreeNas ada0: Serial Number WD-WCAV56912762
Jan 30 17:40:38 FreeNas ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
Jan 30 17:40:38 FreeNas ada0: Command Queueing enabled
Jan 30 17:40:38 FreeNas ada0: 953869MB (1953525168 512 byte sectors)
Jan 30 17:40:38 FreeNas ada1 at ahcich1 bus 0 scbus1 target 0 lun 0
Jan 30 17:40:38 FreeNas ada1: <ST9500325AS 0003SDM1> ATA8-ACS SATA 2.x device
Jan 30 17:40:38 FreeNas ada1: Serial Number 6VEDT4J9
Jan 30 17:40:38 FreeNas ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
Jan 30 17:40:38 FreeNas ada1: Command Queueing enabled
Jan 30 17:40:38 FreeNas ada1: 476940MB (976773168 512 byte sectors)
Jan 30 17:40:38 FreeNas da0 at umass-sim0 bus 0 scbus7 target 0 lun 0
Jan 30 17:40:38 FreeNas da0: <USB DISK 2.0 1100> Removable Direct Access SCSI device
Jan 30 17:40:38 FreeNas da0: Serial Number 026511051008563106000050
Jan 30 17:40:38 FreeNas da0: 40.000MB/s transfers
Jan 30 17:40:38 FreeNas da0: 7728MB (15826944 512 byte sectors)
Jan 30 17:40:38 FreeNas da0: quirks=0x2<NO_6_BYTE>
Jan 30 17:40:38 FreeNas random: unblocking device.
Jan 30 17:40:38 FreeNas da1 at umass-sim1 bus 1 scbus8 target 0 lun 0
Jan 30 17:40:38 FreeNas da1: <Generic- Compact Flash 1.00> Removable Direct Access SCSI device
Jan 30 17:40:38 FreeNas da1: Serial Number 20060413092100000
Jan 30 17:40:38 FreeNas da1: 40.000MB/s transfers
Jan 30 17:40:38 FreeNas da1: Attempt to query device size failed: NOT READY, Medium not present
Jan 30 17:40:38 FreeNas da1: quirks=0x2<NO_6_BYTE>
Jan 30 17:40:38 FreeNas da2 at umass-sim1 bus 1 scbus8 target 0 lun 1
Jan 30 17:40:38 FreeNas da2: <Generic- SM/xD-Picture 1.00> Removable Direct Access SCSI device
Jan 30 17:40:38 FreeNas da2: Serial Number 20060413092100000
Jan 30 17:40:38 FreeNas da2: 40.000MB/s transfers
Jan 30 17:40:38 FreeNas da2: Attempt to query device size failed: NOT READY, Medium not present
Jan 30 17:40:38 FreeNas da2: quirks=0x2<NO_6_BYTE>
Jan 30 17:40:38 FreeNas da3 at umass-sim1 bus 1 scbus8 target 0 lun 2
Jan 30 17:40:38 FreeNas da3: <Generic- SD/MMC 1.00> Removable Direct Access SCSI device
Jan 30 17:40:38 FreeNas da3: Serial Number 20060413092100000
Jan 30 17:40:38 FreeNas da3: 40.000MB/s transfers
Jan 30 17:40:38 FreeNas da3: Attempt to query device size failed: NOT READY, Medium not present
Jan 30 17:40:38 FreeNas da3: quirks=0x2<NO_6_BYTE>
Jan 30 17:40:38 FreeNas da4 at umass-sim1 bus 1 scbus8 target 0 lun 3
Jan 30 17:40:38 FreeNas da4: <Generic- MS/MS-Pro 1.00> Removable Direct Access SCSI device
Jan 30 17:40:38 FreeNas da4: Serial Number 20060413092100000
Jan 30 17:40:38 FreeNas da4: 40.000MB/s transfers
Jan 30 17:40:38 FreeNas da4: Attempt to query device size failed: NOT READY, Medium not present
Jan 30 17:40:38 FreeNas da4: quirks=0x2<NO_6_BYTE>
Jan 30 17:40:38 FreeNas Trying to mount root from zfs:freenas-boot/ROOT/11.2-RELEASE-U1 []...
Jan 30 17:40:38 FreeNas kernel: em0: link state changed to UP
Jan 30 17:40:38 FreeNas GEOM_MIRROR: Device mirror/swap0 launched (2/2).
Jan 30 17:40:38 FreeNas GEOM_ELI: Device mirror/swap0.eli created.
Jan 30 17:40:38 FreeNas GEOM_ELI: Encryption: AES-XTS 128
Jan 30 17:40:38 FreeNas GEOM_ELI: Crypto: software
Jan 30 17:40:38 FreeNas hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> IAP/4/48/0x3ff<INT,USR,SYS,EDG,THR,REA,WRI,INV,QUA,PRC> IAF/3/48/0x67<INT,USR,SYS,REA,WRI> UCP/8/48/0x3f8<EDG,THR,REA,WRI,INV,QUA,PRC> UCF/1/48/0x60<REA,WRI>
Jan 30 17:40:38 FreeNas kernel: em0: link state changed to DOWN
Jan 30 17:40:55 FreeNas ntpd[2437]: ntpd 4.2.8p11-a (1): Starting
Jan 30 17:41:55 FreeNas root: /etc/rc: WARNING: failed precmd routine for minio
Jan 31 00:00:00 FreeNas syslog-ng[1955]: Configuration reload request received, reloading configuration;
Jan 31 00:00:00 FreeNas syslog-ng[1955]: Configuration reload finished;
Feb 1 00:00:00 FreeNas syslog-ng[1955]: Configuration reload request received, reloading configuration;
Feb 1 00:00:00 FreeNas syslog-ng[1955]: Configuration reload finished;
Feb 2 00:00:00 FreeNas syslog-ng[1955]: Configuration reload request received, reloading configuration;
Feb 2 00:00:00 FreeNas syslog-ng[1955]: Configuration reload finished;
Feb 2 15:56:45 FreeNas uwsgi: [sentry.errors:674] Sentry responded with an API error: RateLimited(None)
Feb 2 15:56:45 FreeNas uwsgi: [sentry.errors.uncaught:702] ['timeout: timed out', ' File "django/core/handlers/exception.py", line 42, in inner', ' File "django/core/handlers/base.py", line 244, in _legacy_get_response', ' File "freenasUI/freeadmin/middleware.py", line 296, in process_request', ' File "freenasUI/middleware/auth.py", line 8, in authenticate', ' File "freenasUI/middleware/client.py", line 20, in __enter__', ' File "middlewared/client/client.py", line 320, in __init__', ' File "middlewared/client/client.py", line 313, in __init__', ' File "middlewared/client/client.py", line 170, in connect', ' File "ws4py/client/__init__.py", line 215, in connect']
Feb 2 15:56:56 FreeNas uwsgi: [sentry.errors:674] Sentry responded with an API error: RateLimited(None)
Feb 2 15:56:56 FreeNas uwsgi: [sentry.errors.uncaught:702] ['timeout: timed out', ' File "django/core/handlers/exception.py", line 42, in inner', ' File "django/core/handlers/base.py", line 244, in _legacy_get_response', ' File "freenasUI/freeadmin/middleware.py", line 296, in process_request', ' File "freenasUI/middleware/auth.py", line 8, in authenticate', ' File "freenasUI/middleware/client.py", line 20, in __enter__', ' File "middlewared/client/client.py", line 320, in __init__', ' File "middlewared/client/client.py", line 313, in __init__', ' File "middlewared/client/client.py", line 170, in connect', ' File "ws4py/client/__init__.py", line 215, in connect']
Feb 2 15:57:07 FreeNas uwsgi: [sentry.errors:674] Sentry responded with an API error: RateLimited(None)
Feb 2 15:57:07 FreeNas uwsgi: [sentry.errors.uncaught:702] ['timeout: timed out', ' File "django/core/handlers/exception.py", line 42, in inner', ' File "django/core/handlers/base.py", line 244, in _legacy_get_response', ' File "freenasUI/freeadmin/middleware.py", line 296, in process_request', ' File "freenasUI/middleware/auth.py", line 8, in authenticate', ' File "freenasUI/middleware/client.py", line 20, in __enter__', ' File "middlewared/client/client.py", line 320, in __init__', ' File "middlewared/client/client.py", line 313, in __init__', ' File "middlewared/client/client.py", line 170, in connect', ' File "ws4py/client/__init__.py", line 215, in connect']
Feb 2 16:46:42 FreeNas sshd[21765]: error: Received disconnect from 192.168.1.133 port 55828:13: Unable to authenticate [preauth]
Feb 2 16:50:05 FreeNas smbd: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1
Feb 2 16:51:36 FreeNas proftpd[22849]: 127.0.0.1 - ProFTPD 1.3.6 (stable) (built Thu Dec 20 2018 21:26:19 UTC) standalone mode STARTUP
Feb 2 16:51:42 FreeNas inadyn[22896]: In-a-dyn version 2.2 -- Dynamic DNS update client.
Feb 2 16:51:43 FreeNas inadyn[22896]: Guessing DDNS plugin 'default@dyndns.org' from 'dyndns'
Feb 2 16:51:43 FreeNas inadyn[22896]: Failed resolving hostname : hostname nor servname provided, or not known
Feb 2 16:51:46 FreeNas inadyn[22896]: Update forced for alias , new IP# 89.114.254.40
Feb 2 16:51:47 FreeNas inadyn[22896]: Fatal error in DDNS server response:
Feb 2 16:51:47 FreeNas inadyn[22896]: [404 Not Found] 404
Feb 2 16:51:47 FreeNas inadyn[22896]: Error response from DDNS server, ignoring ...
Feb 2 16:52:06 FreeNas inadyn[22896]: STOP command received, exiting.
Feb 2 16:52:25 FreeNas nfsd: can't register svc name
Feb 2 16:53:29 FreeNas proftpd[22849]: 127.0.0.1 - ProFTPD killed (signal 15)
Feb 2 16:53:29 FreeNas proftpd[22849]: 127.0.0.1 - ProFTPD 1.3.6 standalone mode SHUTDOWN
Feb 2 16:53:29 FreeNas proftpd[23847]: 127.0.0.1 - ProFTPD 1.3.6 (stable) (built Thu Dec 20 2018 21:26:19 UTC) standalone mode STARTUP
Feb 2 16:54:27 FreeNas /middlewared[227]: ECDSA Fingerprint of the SSH KEY: SHA256:yJXrYygU6r8cuknu/HJ3Z3ra1n6t5Vvsm/Zuz660dvA
Feb 3 00:00:00 FreeNas syslog-ng[1955]: Configuration reload request received, reloading configuration;
Feb 3 00:00:00 FreeNas syslog-ng[1955]: Configuration reload finished;
Feb 3 03:45:00 FreeNas ZFS: vdev state changed, pool_guid=10842608450855189412 vdev_guid=11384062770062622520
Feb 4 00:00:00 FreeNas syslog-ng[1955]: Configuration reload request received, reloading configuration;
Feb 4 00:00:00 FreeNas syslog-ng[1955]: Configuration reload finished;
Apollo
Normally, a dataset cannot be deleted when it is already used by one of the services, such as shares.
Make sure no shares are making use of it.
RodrigoLopes
I already removed all shares that were using the Dataset, i didn't stop the service cause i'm using it to different shares.
RodrigoLopes
Ok i managed to do it, i had to reboot freenas.
Now when i created the new Dataset i didn't manage to set group premissions (more than one group) on it did it change from FreeNas 9 to 11.2?
Can you help me?
Apollo
I believe, only the user interface is different, but the underlying process should still be the same.
If you have trouble doing it under the new GUI, you can still open the GUI from the legacy interface. Maybe you will get a better hang of the issue then.
RodrigoLopes
That solved it thanks for the assist :D
In the old GUI you had all groups displayed and you could move the ones you wanted now it only shows you one option.
I will be changing my user and group "system"
