cougarmaster
- Jul 7, 2014
Hi guy,
Been using freenas for quite sometime. Most of the services I am quite familiar with. I have several builds with large HDD and of course backups of them. I am not familiar with zfs actual workings but I have had not much problems with it in the past and most recoveries were smooth. Most of my servers are running 9.10 now.
My problem now is that I have an old
Freenas 8.3.1
Core2 duo
4GB ram
2x2TB WD Red
This system was running quite smoothly and these drives are new as the old ones which were seagate started to fail so we replaced them with these. We replaced each one with no problems. Then one day one of the WD drives failed but after checking there were no problems with the drives itself and the raid was in Degraded state. So went to replace it with the other drive in the WD it failed with gpt errors. The following was the way I did the delete of the other drive which I now regrettably did :-
1] Shutdown unplugged failed drive
2] Checked good drive data
3] Shutdown unplugged good drive plugged failed drive
4] Deleted the drive and clicked on clear data checkbox
5] Shutdown plugged good drive in
6] booted with both drives and now no pools or dataset
Is there a way to get back the pool from the good drive? Please I have no backup and I want to see if there is a small possibilty of recovering the data as the good drive however I try to zpool import the drive it says no pool available.
Tks
Eric
Freenas 8.3.1
Core2 duo
4GB ram
2x2TB WD Red
Tks
Eric
