dresified
 - Dec 9, 2019
I have 4 WD drives in an extended mirrored ZFS configuration no raid. USB boot drives are working fine.
I shut the server down to replace some old noisy fans and some cable management.
While the sata cables were all unplugged my son turned on the server. I let it boot all the way up and shut it back down.
Plugged everything back in correctly and booted up.
Now none of the drives in the pool are being recognized at all.
Status for the pool is offline and unknown.
The disk status just shows the boot drives plugged in.
I have checked the power supply and cables several times.
The server can see new drives that are plugged in.
I also took one of the drives to another server to see if it could see the drive and it could not.
How can I get freenas to see the drives again? When you boot up without your pool attached does freenas set the drives to offline?
