Hi all, real quick intro, FreeNAS newb, linux beginner at best.
Recently moved to a FreeNAS setup at the house for main data storage, and so far its been great. Got a few plugins going even and really enjoying it, however I keep getting failures and even the occasional crash from it.
I installed on a matching pair of SanDisk Cruser flash drives, day 1 went great no problems, day 2 experienced my first failure, but honestly pulling the offending drive, and replacing with a different, it fixed the problem on its own!?
So now, after 4 days of swapping back and forth between 5 different flash drives, all of which have failed at some point, I scooped up some 120gb kingston SSDs on amazon for 35 each, and until they get here tomorrow, i grabbed a 500gb ssd i had laying the office to try and stabilize this for the mean time. I have already copied some 18TB over to the array, so its quite critical at this point!
SO ON TO THE PROBLEM
I replaced an offending drive with the 500gb drive, it said it took, said it was being added, etc..
But its still giving me these errors? What should i do next to repair this? Also, what should i do when my 120s come in, to migrate over to those drives? ALSO, when i try and detach the drive listed as numbers, i just get a failure, ill post the photo below of it.
Any help is GREATLY appreciated! THANKS!
EDIT! da11 is a flash drive the ada0p2 is the 500g ssd
Once i can confirm the 500gb SSD has the OS on it tonight, ill remove all 4 flash drives i have plugged into the system and have it just run the SSD unless anyone thinks thats a bad idea?
Thanks again all!
Thanks again all!
