Degraded volume, resilvering error, 'positive' checksum
Quass1m
Hello
I am new FreeNAS user. My setup consists of:
FreeNAS-9.10.1-U4 (ec9a7d3) on 8GB USB 2.0 Flash Drive
GIGABYTE GA-H55M-UD2H
Intel i5-650
4x 4GB Crucial Battlix 1600MHz non-ECC memory
5 Hard drives: 2x 1TB (temporary) and 3x3TB in a RAID-Z2
Initially everything was fine except for 1 faulty 3TB Toshiba HDD with bad sectors which I switched for 3TB WD Blue. After powering up I could see that 2 other of my drives have become 'Degraded'. Still, I tried to resilver the pool with the new drive which resulted in "Status:Completed, Errors 7". The 'zpool status -v' informs me that several syslog files are corrupted. The resilvering also seems not to work. I can still see the old drive id with the status 'UNAVAIL'. The replacement 3TB WD Blue drive shows up as ada4 with status 'ONLINE' but the resilvering process automatically starts again after each system reboot - always with the same error result. Apart from that the volume shows non-zero Checksum values which continue to rise (right now my volume Main is at 10.5K and raidz2-0 at 20.9K) .
Could anyone help me deal with this problem?
  pool: Main
 state: DEGRADED
	corruption.  Applications may be affected.
action: Restore the file in question if possible.  Otherwise restore the
	entire pool from backup.
   see: http://illumos.org/msg/ZFS-8000-8A
  scan: resilvered 725G in 5h6m with 7 errors on Sat Nov 26 00:31:46 2016
	NAME											  STATE	 READ WRITE CKSUM
	Main											  DEGRADED	 0	 0 10.5K
	  raidz2-0										DEGRADED	 0	 0 20.9K
		replacing-0								   DEGRADED	 0	 0	 0
		  16529643675148983459						UNAVAIL	  0	 0	 0  was /dev/gptid/23461eee-ae59-11e6-8c2b-1c6f65864cd9
		  gptid/5d5d1713-b300-11e6-b670-1c6f65864cd9  ONLINE	   0	 0	 0
		gptid/249991f3-ae59-11e6-8c2b-1c6f65864cd9	ONLINE	   0	 0	 0
		gptid/259cf0ad-ae59-11e6-8c2b-1c6f65864cd9	DEGRADED	 0	 0	 0  too many errors
		gptid/2660a415-ae59-11e6-8c2b-1c6f65864cd9	DEGRADED	 0	 0	 0  too many errors
		gptid/275a4a89-ae59-11e6-8c2b-1c6f65864cd9	ONLINE	   0	 0	 0
		/var/db/system/syslog-a75e42d926e4418a8e21357ce29c963c/log/userlog
		/var/db/system/syslog-a75e42d926e4418a8e21357ce29c963c/log/messages
		/var/db/system/syslog-a75e42d926e4418a8e21357ce29c963c/log/cron
		/var/db/system/syslog-a75e42d926e4418a8e21357ce29c963c/log/daemon.log
		/var/db/system/syslog-a75e42d926e4418a8e21357ce29c963c/log/debug.log
		/var/db/system/syslog-a75e42d926e4418a8e21357ce29c963c/log/mdnsresponder.log
		/var/db/system/syslog-a75e42d926e4418a8e21357ce29c963c/log/nginx-access.log
  pool: freenas-boot
 state: ONLINE
  scan: scrub repaired 0 in 0h4m with 0 errors on Sun Nov 20 03:49:49 2016
	freenas-boot								  ONLINE	   0	 0	 0
	  gptid/dcab6123-0844-11df-95ab-1c6f65864cd9  ONLINE	   0	 0	 0
errors: No known data errors
  • zpool_status.txt
  • ada1.txt
  • ada4.txt
Robert Trevellyan
Pony Wrangler
Looks like you'd be best off saving whatever data you can recover and then starting over with more suitable hardware.
ada4 is probably no good.
