AndrewParsons
- Jun 14, 2016
Hello Community,
First let me thank you for helping me out in the past from building my first freenas setup trouble shooting it.
Below is what I am running before I get into details on what I did and if their is any way I can fix this besides backing up and rebuilding the pool.
System:
- FreeNAS-11.3-U3.2 main pool is running in raidz1
- Processor (Intel Xeon E3-1230V3 Haswell, 3.3GHz, 8MB L3 Cache LGA 1150, 80W Quad-Core Server Processor BX80646E31230V3)
- Motherboard (Supermicro X10SL7-F uATX DDR3 1600 LGA 1150)
-Crucial 32GB Kit (8GBx4) DDR3/DDR3L-1600MT/s (PC3-12800) DR x8 ECC UDIMM Server Memory CT2KIT102472BD160B/CT2CP102472BD160B Unbufferd)
- Hard Drives x6 (HGST Deskstar NAS 3.5-Inch 4TB 7200RPM SATA III 64MB Cache Internal Hard Drive Kit (0S03664)
- Computer Case (Antec One Computer Case)
- Power Supply (EVGA SuperNOVA 750 G1 80+ GOLD, 750W Fully Modular 10 Year Warranty Power Supply 120-G1-0750-XR)
- SSD for ZFS (Kingston Digital 120GB UV400 SSD C2C 2.5" SUV400S37/120G)
So I was replacing some failing case fans in the server. When completed I fired back up the server and all was good, or so I thought, I guess I was running it in a degraded I must have damaged one of the sata cables because the next day I was getting
See the picture for more deails on the error.
I then replaced the Sata cable on ada3 and all was well in the world. Once I booted back into freenas the pool automatically began to resilver the drive I had broke the sata cable on.
Stupidly during this time and a bit before I was doing some pretty heavy file transfers. I completely drew a blank that I was resilvering.
I was even monitoring the resilver process and all was working well till checked back in on with zpool status | more
So then I did
Yes I did buy Game of Thrones 4k on the 4th when I was released, just saying.
So I know the drive is not failing or so I think.
What is my best course of action? Is there anything else you need from me?
Any help would be much appreciated.
With much respect,
Andrew
System:
(ada3ahcich5:0:0:0): CAM status: ATA status Error
root@freenas:~ # zpool status | more pool: freenas-boot state: ONLINE scan: scrub repaired 0 in 0 days 00:01:21 with 0 errors on Sun Nov 8 03:46:21 2020 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 gptid/4062447f-39d5-11e6-b6f5-0cc47aaa6350 ONLINE 0 0 0 errors: No known data errors pool: jailvolume state: ONLINE status: Some supported features are not enabled on the pool. The pool can still be used, but some features are unavailable. action: Enable all features using 'zpool upgrade'. Once this is done, the pool may no longer be accessible by software that does not support the features. See zpool-features(7) for details. scan: scrub repaired 0 in 0 days 00:02:23 with 0 errors on Sun Oct 11 00:02:23 2020 config: NAME STATE READ WRITE CKSUM jailvolume ONLINE 0 0 0 gptid/6e52b29a-3a8c-11e6-b068-0cc47aaa6350 ONLINE 0 0 0 gptid/6e6a1f11-3a8c-11e6-b068-0cc47aaa6350 ONLINE 0 0 0 errors: No known data errors pool: mediavolume state: DEGRADED status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: http://illumos.org/msg/ZFS-8000-8A scan: resilvered 63.1G in 0 days 01:07:54 with 0 errors on Tue Nov 10 13:28:34 2020 config: NAME STATE READ WRITE CKSUM mediavolume DEGRADED 0 0 0 raidz1-0 DEGRADED 0 0 0 gptid/0eee7657-3a8c-11e6-b068-0cc47aaa6350 ONLINE 0 0 0 gptid/0f4ba8db-3a8c-11e6-b068-0cc47aaa6350 ONLINE 0 0 0 gptid/dff0074e-3381-11e7-b363-0cc47aaa6350 ONLINE 0 0 0 gptid/10135bd5-3a8c-11e6-b068-0cc47aaa6350 ONLINE 0 0 0 gptid/c313f53c-bb99-11e8-8f76-0cc47aaa6350 ONLINE 0 0 0 gptid/10da2a03-3a8c-11e6-b068-0cc47aaa6350 DEGRADED 0 0 2.20M too many errors gptid/113daac7-3a8c-11e6-b068-0cc47aaa6350 ONLINE 0 0 0 gptid/11a059d7-3a8c-11e6-b068-0cc47aaa6350 ONLINE 0 0 0 gptid/12053b6c-3a8c-11e6-b068-0cc47aaa6350 ONLINE 0 0 0 errors: 1209 data errors, use '-v' for a list
So then I did
root@freenas:~ # zpool status -v pool: freenas-boot state: ONLINE scan: scrub repaired 0 in 0 days 00:01:21 with 0 errors on Sun Nov 8 03:46:21 2020 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 gptid/4062447f-39d5-11e6-b6f5-0cc47aaa6350 ONLINE 0 0 0 errors: No known data errors pool: jailvolume state: ONLINE status: Some supported features are not enabled on the pool. The pool can still be used, but some features are unavailable. action: Enable all features using 'zpool upgrade'. Once this is done, the pool may no longer be accessible by software that does not support the features. See zpool-features(7) for details. scan: scrub repaired 0 in 0 days 00:02:23 with 0 errors on Sun Oct 11 00:02:23 2020 config: NAME STATE READ WRITE CKSUM jailvolume ONLINE 0 0 0 gptid/6e52b29a-3a8c-11e6-b068-0cc47aaa6350 ONLINE 0 0 0 gptid/6e6a1f11-3a8c-11e6-b068-0cc47aaa6350 ONLINE 0 0 0 errors: No known data errors pool: mediavolume state: DEGRADED status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: http://illumos.org/msg/ZFS-8000-8A scan: resilvered 63.1G in 0 days 01:07:54 with 0 errors on Tue Nov 10 13:28:34 2020 config: NAME STATE READ WRITE CKSUM mediavolume DEGRADED 0 0 0 raidz1-0 DEGRADED 0 0 0 gptid/0eee7657-3a8c-11e6-b068-0cc47aaa6350 ONLINE 0 0 0 gptid/0f4ba8db-3a8c-11e6-b068-0cc47aaa6350 ONLINE 0 0 0 gptid/dff0074e-3381-11e7-b363-0cc47aaa6350 ONLINE 0 0 0 gptid/10135bd5-3a8c-11e6-b068-0cc47aaa6350 ONLINE 0 0 0 gptid/c313f53c-bb99-11e8-8f76-0cc47aaa6350 ONLINE 0 0 0 gptid/10da2a03-3a8c-11e6-b068-0cc47aaa6350 DEGRADED 0 0 2.20M too many errors gptid/113daac7-3a8c-11e6-b068-0cc47aaa6350 ONLINE 0 0 0 gptid/11a059d7-3a8c-11e6-b068-0cc47aaa6350 ONLINE 0 0 0 gptid/12053b6c-3a8c-11e6-b068-0cc47aaa6350 ONLINE 0 0 0 errors: Permanent errors have been detected in the following files: /var/db/system/syslog-f36704f2fe794cb6a75657843255655d/log/mdnsresponder.log /var/db/system/syslog-f36704f2fe794cb6a75657843255655d/log/samba4/log.nmbd /var/db/system/syslog-f36704f2fe794cb6a75657843255655d/log/cron /var/db/system/rrd-f36704f2fe794cb6a75657843255655d/localhost/disk-ada1/disk_octets.rrd mediavolume/media@auto-20201110.1100-4w:/4K TV/Game.of.Thrones.S05.2160p.UHD.BluRay.REMUX.HDR.HEVC.Atmos-EPSiLON-xpost/abc.xyz.1b1cc729805fe7.mkv mediavolume/media@auto-20201110.1100-4w:/4K TV/Game.of.Thrones.S05.2160p.UHD.BluRay.REMUX.HDR.HEVC.Atmos-EPSiLON-xpost/abc.xyz.bb38aae875b3ac.mkv mediavolume/media@auto-20201110.1100-4w:/4K TV/Game.of.Thrones.S05.2160p.UHD.BluRay.REMUX.HDR.HEVC.Atmos-EPSiLON-xpost/abc.xyz.0464ff6fb0bb6e.mkv mediavolume/media@auto-20201110.1100-4w:/4K TV/Game.of.Thrones.S05.2160p.UHD.BluRay.REMUX.HDR.HEVC.Atmos-EPSiLON-xpost/abc.xyz.a92b274e1852fe.mkv mediavolume/media@auto-20201110.1100-4w:/4K TV/Game.of.Thrones.S05.2160p.UHD.BluRay.REMUX.HDR.HEVC.Atmos-EPSiLON-xpost/abc.xyz.a04ec95bd3ca60.mkv mediavolume/media@auto-20201110.1100-4w:/4K TV/Game.of.Thrones.S05.2160p.UHD.BluRay.REMUX.HDR.HEVC.Atmos-EPSiLON-xpost/abc.xyz.dafb99f3c41d12.mkv mediavolume/media@auto-20201110.1100-4w:/4K TV/Game.of.Thrones.S05.2160p.UHD.BluRay.REMUX.HDR.HEVC.Atmos-EPSiLON-xpost/abc.xyz.0ee782e74fef14.mkv mediavolume/media@auto-20201110.1200-4w:<0x0> mediavolume/media@auto-20201110.1200-4w:/TempDownload/Game.of.Thrones.S03.2160p.UHD.BluRay.REMUX.HDR.HEVC.Atmos-EPSiLON-xpost/abc.xyz.f6c78c2a01883a.1.mkv mediavolume/media@auto-20201110.1200-4w:/4K TV/Game.of.Thrones.S02.2160p.UHD.BluRay.REMUX.HDR.HEVC.Atmos-EPSiLON-xpost/abc.xyz.1cf8798fde96ed.mkv mediavolume/media@auto-20201110.1200-4w:/4K TV/Game.of.Thrones.S02.2160p.UHD.BluRay.REMUX.HDR.HEVC.Atmos-EPSiLON-xpost/abc.xyz.3886cdb827e5d0.mkv mediavolume/media@auto-20201110.1200-4w:/TempDownload/Game.of.Thrones.S03.2160p.UHD.BluRay.REMUX.HDR.HEVC.Atmos-EPSiLON-xpost/abc.xyz.f6c78c2a01883a.mkv mediavolume/media@auto-20201110.1200-4w:/4K TV/Game.of.Thrones.S02.2160p.UHD.BluRay.REMUX.HDR.HEVC.Atmos-EPSiLON-xpost/abc.xyz.8a62e89cb21f5f.mkv mediavolume/media@auto-20201110.1200-4w:/4K TV/Game.of.Thrones.S02.2160p.UHD.BluRay.REMUX.HDR.HEVC.Atmos-EPSiLON-xpost/abc.xyz.9d8b3cb2f8d764.mkv mediavolume/media@auto-20201110.1200-4w:/4K TV/Game.of.Thrones.S02.2160p.UHD.BluRay.REMUX.HDR.HEVC.Atmos-EPSiLON-xpost/abc.xyz.0b1ba0ea87336d.mkv mediavolume/media@auto-20201110.1200-4w:/4K TV/Game.of.Thrones.S02.2160p.UHD.BluRay.REMUX.HDR.HEVC.Atmos-EPSiLON-xpost/abc.xyz.881d50eb74900f.mkv mediavolume/media@auto-20201110.1200-4w:/4K TV/Game.of.Thrones.S02.2160p.UHD.BluRay.REMUX.HDR.HEVC.Atmos-EPSiLON-xpost/abc.xyz.f0ecca1d1f111b.mkv mediavolume/media@auto-20201110.1200-4w:/4K TV/Game.of.Thrones.S02.2160p.UHD.BluRay.REMUX.HDR.HEVC.Atmos-EPSiLON-xpost/abc.xyz.80b6c83c139bb8.mkv mediavolume/media@auto-20201110.1200-4w:/4K TV/Game.of.Thrones.S02.2160p.UHD.BluRay.REMUX.HDR.HEVC.Atmos-EPSiLON-xpost/abc.xyz.1caa4d84467c5a.mkv mediavolume/media@auto-20201110.1200-4w:/TempDownload/Game.of.Thrones.S03.2160p.UHD.BluRay.REMUX.HDR.HEVC.Atmos-EPSiLON-xpost/abc.xyz.158414a42565cc.mkv mediavolume/media@auto-20201110.1200-4w:/4K TV/Game.of.Thrones.S02.2160p.UHD.BluRay.REMUX.HDR.HEVC.Atmos-EPSiLON-xpost/abc.xyz.3fb8eea904f762.mkv
With much respect,
Andrew
