SOLVED Degraded RAIDZ volume
Blastmun
I ask for your help because I have a funny problem on truenas scale recently installed.
I have a raidZ composed of 3*4TB + 120GB SSD cache.
After barely 2 weeks of operation, it went into degradation.
I don't understand, I have nothing in the S.M.A.R.T test result.
So I ran a badblock test, nothing either.
I removed the disk from the NAS to connect it to my computer.
SMART test under windows 11 RAS.
test "chkdsk" nothing reported
test Hard Disk Sentinel pro:
so I put the disk freshly reset with a new sata cable in case, same problem after 1 night ....
Arwen
Please list your entire hardware. If the model number is correct for your 4TB drive, "WD40EFRX", then it's not a SMR drive. Which is good news, at least on that front.
morganL
Captain Morgan
Administrator
It's possible (not common) there is an an issue with that particular SATA port.... eg poor solder joint... not just the sata cable.
Blastmun
I will try to run it on another port
MSI B550 TOMAHAWK
Ryzen 5 5600G
Corsair vengence 8Go
