lankster2k
- Oct 23, 2020
I have a degraded pool status and a disk I assume needs replacing.
But if I try to force OFFLINE the device in the Pool Status view it errors :
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 137, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self,
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1191, in _call
File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 973, in nf
File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/pool.py", line 1070, in offline
await self.middleware.call('disk.swaps_remove_disks', [disk])
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1233, in call
return await self._call(
File "/usr/local/lib/python3.8/site-packages/middlewared/service.py", line 42, in l_fn
return await fn(*args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 972, in nf
args, kwargs = clean_and_validate_args(args, kwargs)
File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 930, in clean_and_validate_args
value = attr.clean(args[args_index + i])
File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 470, in clean
raise Error(self.name, 'Item#{0} is not valid per list types: {1}'.format(index, found))
middlewared.schema.Error: [disks] Item#0 is not valid per list types: [disk] null not allowed
I'm on Version: TrueNAS-12.0-RELEASE
From the missing serial number in the disk view I can see its not listed. I assume its da7 that missing as all the other numbers were sequential.
ada0 is where truenas is installed - all the others are for storage in one pool.
Can someone assist in resolving? I assume I can't offline it as its already dead - that would make sense. I just want to confirm next steps.
If i try to REPLACE the following comes up :
The top dialogue just has a dash.
Are there shell commands that would show if that disk is active but not visible to TrueNas Core?
Can i just replace it and then add to the existing pool ?
Many thanks
Many thanks
