I have a failed drive in my array, TrueNAS version TrueNAS-12.0-RELEASE. When I attempt to offline the drive to prepare for replacement, it creates a windows that says Error [disks] Item#0 is not valid per list types: [disk] null not allowed. When I expand the error, it says:
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 137, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self,
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1191, in _call
File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 973, in nf
File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/pool.py", line 1070, in offline
await self.middleware.call('disk.swaps_remove_disks', [disk])
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1233, in call
return await self._call(
File "/usr/local/lib/python3.8/site-packages/middlewared/service.py", line 42, in l_fn
return await fn(*args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 972, in nf
args, kwargs = clean_and_validate_args(args, kwargs)
File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 930, in clean_and_validate_args
value = attr.clean(args[args_index + i])
File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 470, in clean
raise Error(self.name, 'Item#{0} is not valid per list types: {1}'.format(index, found))
middlewared.schema.Error: [disks] Item#0 is not valid per list types: [disk] null not allowed
It won't do anything else, what can I do?
Thanks
Thanks
