Collerico
- Nov 12, 2022
Hi everyoone, this is my first post I hope I used the right thread.
I use truenas-SCALE-22.12-BETA.1 virtual on unraid server with assigned 8core, 16gb ram (ecc) and 3 pools that I use for different uses.
This morning I had to reboot to do an update on the physical host and on reboot I noticed that the process to load one of the 3 pools took a long time, at the time of reboot I noticed that most of the datasets on this pool were lost and the space used went from around 70% to 36%. this pool is a raidz1 of 4 4tb wd red disk with a 16gb vdisk for deduplication table (maybe this was the problem at the beginning)
in the dataset menu I see only two of the 5 datasets that should be there, one of which is about 1tb now completely empty.
I searched on the forum and on the web but I did not find anything, luckily some of these datasets had replicas and I should be able to recover the data, I am left with the problem on two datasets, of one I only have snapshots, I see the process still present but I don't know how and if I can restore it, I don't have any backup or replicas of another one because I use it as a temporary storage for documents to be sorted.
there are very important things that I need to recover, is there anything that comes to your mind could help me? I'm also okay with having to browse disks and manually copy files to another disk / pool
sorry for the long message but I'm desperate for what happened.
Thanks in advance
Thanks in advance
