Hi all,
Last week we had a brief power failure and my beloved FreeNAS server is not happy. (We did have a Lightning strike in the vicinity).
Not sure if it's fixable and what steps to try to fix it.
I boot off 2 x USB's that are mirrored.
also, have 1 x Volume Vol1 that won't mount.
I've run the following commands with results.
The gpart command makes me think one disk ADA1 has died, but I really don't know.
Is it possible to break the mirror, repair ADA0 and then rebuild the mirror?
PC specs are in my signature. No hardware raid, cause that will defeat the object of ZFS.
[root@freenas ~]# zpool status -v
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0 days 00:05:22 with 0 errors on Tue Jan 22 03:50:23 2019
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
da0p2 ONLINE 0 0 0
da1p2 ONLINE 0 0 0
errors: No known data errors
[root@freenas ~]# zpool status -x
all pools are healthy
[root@freenas ~]# zpool import
pool: Vol1
state: UNAVAIL
status: One or more devices are missing from the system.
action: The pool cannot be imported. Attach the missing
devices and try again.
see: http://illumos.org/msg/ZFS-8000-3C
Vol1 UNAVAIL insufficient replicas
mirror-0 UNAVAIL insufficient replicas
13515042998217772309 UNAVAIL corrupted data
11162558757959515843 UNAVAIL cannot open
[root@freenas ~]# diskinfo -v ada0
ada0
512 # sectorsize
3000615492608 # mediasize in bytes (2.7T)
5860577134 # mediasize in sectors
4096 # stripesize
0 # stripeoffset
5814064 # Cylinders according to firmware.
16 # Heads according to firmware.
63 # Sectors according to firmware.
ST4000DM004-2CV104 # Disk descr.
ZFN08X2K # Disk ident.
Not_Zoned # Zone Mode
[root@freenas ~]# diskinfo -v ada1
ada1
512 # sectorsize
4096 # stripesize
0 # stripeoffset
ZFN1535S # Disk ident.
[root@freenas ~]#
[root@freenas ~]# gpart show ada0
=> 40 5860577056 ada0 GPT (2.7T) [CORRUPT]
40 88 - free - (44K)
128 4194304 1 freebsd-swap (2.0G)
4194432 5856382656 2 freebsd-zfs (2.7T)
5860577088 8 - free - (4.0K)
[root@freenas ~]# gpart show ada1
gpart: No such geom: ada1. ????????????
