My setup is close to 10 years old, so please be gentle.
Motherboard: MSI Z87-GD65 (8 SATA)
Hard drives: 8 (3 in raidz1, 5 in raidz1). Two groups, 1 Pool ("Backup")
Separate NIC (can't remember the brand).
RAM: 16GB
For over a month I knew I had to replace a dying drive, so today I proceeded to replace it. Here is the zpool status results before any changes.
Note: I went into the GUI and I think I may have Offline'd the wrong disk (ed4a0185) based on further issues.
After replaced the drive I thought was failing, I noticed 1) that the drive that was failing I had recently put in about a month ago, and 2) the motherboard failed to see the old and new drive I put in. I immediately thought it was the cables so I tried new cables, nothing. Tried connecting using a different SATA port, nothing. Tried connecting another drive I had, it appeared. Maybe bad drives. However, after booting up, my pool became unavailable.
Results for zpool import:
Additional information that may be relevant:
Any help recovering my pool or data at this point would be super helpful. Thanks in advance.
RAM: 16GB
root@freenas:~ # zpool status -v pool: Backup state: DEGRADED status: One or more devices could not be opened. Sufficient replicas exist for the pool to continue functioning in a degraded state. action: Attach the missing device and online it using 'zpool online'. see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-2Q scan: scrub repaired 0B in 08:34:37 with 0 errors on Mon Jan 1 12:34:38 2024 config: NAME STATE READ WRITE CKS UM Backup DEGRADED 0 0 0 raidz1-0 ONLINE 0 0 0 gptid/e0bcc30b-b100-11ec-87cd-6805ca245f8e ONLINE 0 0 0 gptid/2822d91b-31f4-11ed-a435-6805ca245f8e ONLINE 0 0 0 gptid/675c3c94-4bcf-11ec-a91b-6805ca245f8e ONLINE 0 0 0 raidz1-1 DEGRADED 0 0 0 gptid/13c0af7c-de9d-11e7-a6ad-6805ca245f8e ONLINE 0 0 0 gptid/7654e74f-324f-11ed-a5cf-6805ca245f8e ONLINE 0 0 0 gptid/7acc92cb-3082-11ee-ba84-6805ca245f8e ONLINE 0 0 0 5328743724287497878 UNAVAIL 0 0 0 was /dev/gptid/ff359429-4b4c-11ee-a30f-6805ca245f8e gptid/ed4a0185-78d0-11e7-8a15-6805ca245f8e ONLINE 0 0 0 errors: No known data errors pool: freenas-boot state: ONLINE status: Some supported and requested features are not enabled on the pool. The pool can still be used, but some features are unavailable. action: Enable all features using 'zpool upgrade'. Once this is done, the pool may no longer be accessible by software that does not support the features. See zpool-features(7) for details. scan: scrub repaired 0B in 00:13:53 with 0 errors on Tue Dec 26 03:58:54 2023 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 da0p2 ONLINE 0 0 0
root@freenas:~ # zpool status -v pool: freenas-boot state: ONLINE status: Some supported and requested features are not enabled on the pool. The pool can still be used, but some features are unavailable. action: Enable all features using 'zpool upgrade'. Once this is done, the pool may no longer be accessible by software that does not support the features. See zpool-features(7) for details. scan: scrub repaired 0B in 00:13:53 with 0 errors on Tue Dec 26 03:58:54 2023 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 da0p2 ONLINE 0 0 0 errors: No known data errors
root@freenas:~ # zpool import pool: Backup id: 13107975172226338044 state: UNAVAIL status: One or more devices are missing from the system. action: The pool cannot be imported. Attach the missing devices and try again. see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-3C config: Backup UNAVAIL insufficient replicas raidz1-0 ONLINE gptid/e0bcc30b-b100-11ec-87cd-6805ca245f8e ONLINE gptid/2822d91b-31f4-11ed-a435-6805ca245f8e ONLINE gptid/675c3c94-4bcf-11ec-a91b-6805ca245f8e ONLINE raidz1-1 UNAVAIL insufficient replicas gptid/13c0af7c-de9d-11e7-a6ad-6805ca245f8e ONLINE gptid/7654e74f-324f-11ed-a5cf-6805ca245f8e ONLINE gptid/7acc92cb-3082-11ee-ba84-6805ca245f8e ONLINE gptid/ff359429-4b4c-11ee-a30f-6805ca245f8e UNAVAIL cannot open 14355185466639617060 OFFLINE
root@freenas:~ # glabel status Name Status Components gptid/13c0af7c-de9d-11e7-a6ad-6805ca245f8e N/A ada0p2 gptid/7654e74f-324f-11ed-a5cf-6805ca245f8e N/A ada1p2 gptid/e0bcc30b-b100-11ec-87cd-6805ca245f8e N/A ada2p2 gptid/2822d91b-31f4-11ed-a435-6805ca245f8e N/A ada3p2 gptid/7acc92cb-3082-11ee-ba84-6805ca245f8e N/A ada5p2 gptid/ed4a0185-78d0-11e7-8a15-6805ca245f8e N/A ada6p2 gptid/675c3c94-4bcf-11ec-a91b-6805ca245f8e N/A ada4p2 gptid/c963c6e2-3b74-11e7-addf-6805ca245f8e N/A da0p1 gptid/675040a1-4bcf-11ec-a91b-6805ca245f8e N/A ada4p1 gptid/ed28bbcd-78d0-11e7-8a15-6805ca245f8e N/A ada6p1 gptid/7abb91c3-3082-11ee-ba84-6805ca245f8e N/A ada5p1 gptid/280f49e7-31f4-11ed-a435-6805ca245f8e N/A ada3p1 gptid/e0a4cfcb-b100-11ec-87cd-6805ca245f8e N/A ada2p1 gptid/7644eb22-324f-11ed-a5cf-6805ca245f8e N/A ada1p1 gptid/13b205a1-de9d-11e7-a6ad-6805ca245f8e N/A ada0p1 root@freenas:~ # geom disk list Geom name: ada0 Providers: 1. Name: ada0 Mediasize: 3000592982016 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 descr: WDC WD30EFRX-68N32N0 lunid: 50014ee2643601cd ident: WD-WCC7K7YVTJUT rotationrate: 5400 fwsectors: 63 fwheads: 16 Geom name: ada1 Providers: 1. Name: ada1 Mediasize: 4000787030016 (3.6T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 descr: WDC WD40EFZX-68AWUN0 lunid: 50014ee2bfb1199f ident: WD-WX52DC1CHH4X rotationrate: 5400 fwsectors: 63 fwheads: 16 Geom name: ada2 Providers: 1. Name: ada2 Mediasize: 4000787030016 (3.6T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 descr: WDC WD40EFAX-68JH4N1 lunid: 50014ee268a6782b ident: WD-WX22D90N4CXU rotationrate: 5400 fwsectors: 63 fwheads: 16 Geom name: ada3 Providers: 1. Name: ada3 Mediasize: 4000787030016 (3.6T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 descr: WDC WD40EFZX-68AWUN0 lunid: 50014ee21505ebde ident: WD-WX52DC1CH4RF rotationrate: 5400 fwsectors: 63 fwheads: 16 Geom name: ada5 Providers: 1. Name: ada5 Mediasize: 4000787030016 (3.6T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 descr: WDC WD40EFRX-68N32N0 lunid: 50014ee21209ddf7 ident: WD-WCC7K0PD9N3P rotationrate: 5400 fwsectors: 63 fwheads: 16 Geom name: ada6 Providers: 1. Name: ada6 Mediasize: 3000592982016 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 descr: TOSHIBA DT01ACA300 lunid: 5000039fe6d2ad5b ident: 472A2PSAS rotationrate: 7200 fwsectors: 63 fwheads: 16 Geom name: ada4 Providers: 1. Name: ada4 Mediasize: 4000787030016 (3.6T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 descr: WDC WD4003FFBX-68MU3N0 lunid: 5000cca095c73cc1 ident: VBGHXK5F rotationrate: 7200 fwsectors: 63 fwheads: 16 Geom name: da0 Providers: 1. Name: da0 Mediasize: 15728640000 (15G) Sectorsize: 512 Mode: r1w1e2 descr: Kingston DataTraveler 2.0 ident: 1C6F654E3FD0BE414980075F rotationrate: unknown fwsectors: 63 fwheads: 255
