In theory it should already be done because you should have at least one backup of this data.
I'm not sure what you mean... I still have the 3 drives which are stripped, and one of which is failing.
No backup of that!
I did a partial backup on an external HD... but only of my important files (like my documents and such).
However, I have several TB of movies and other stuff, which I don't have the space to back up :S
Oh well I'll have to figure something out !
So I'm about to purchase my new hard drives.
Just to make sure :
I have 3 X 4 TB.
I was going to buy an additional 3 X 4TB to mirror them (like a RAID-10 ish setup)
I was hoping that by doing that, and let the 3 first drive mirror on the 3 new drives, I could then replace the failing drive by a new one, and the pool would rebuild itself
But you're saying that will not work, right?
And that I should buy 2 new drives instead, and make a RAID-Z2 pool, which will give me 12 TB of usable space...
And therefore I should buy 2 additional drives, and not 3, and that RAID-Z2 is superior to my RAID 10 thing.
Am I correct?
Also, one last question : let's say I buy 4 new 4TB drives.
And I already have the 3 X 4TB drives, one of which is failing.
I mount a temporary volume of 2 X 4TB = 8TB, it should be enough to backup all my data I think.
Then I take out the failing drive, and trash it.
I still have 4 X 4TB drives (2 old, 2 new), so I create a RAID-Z2 volume, which will give me 8TB of usable space, right?
Then I put my data on that new RAID-Z2... then I can destroy the temporary volume.
Can I add those 2 X 4TB drive to my RAID-Z2 volume then?
In the end it'd be a 6 X 4TB RAID-Z2 volume, giving me 16TB of usable space, correct?
