smartctl -x /dev/ada3
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p26 amd64] (local build)
Model Family: Western Digital Se
Device Model: WDC WD4000F9YZ-09N20L0
Serial Number: WD-WCC132056754
LU WWN Device Id: 5 0014ee 20a11da36
Firmware Version: 01.01A01
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 7200 rpm
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Nov 2 10:52:42 2015 EST
SMART support is: Enabled
AAM feature is: Unavailable
APM level is: 128 (minimum power consumption without standby)
Rd look-ahead is: Enabled
Write cache is: Enabled
ATA Security is: Disabled, frozen [SEC2]
Wt Cache Reorder: Enabled
General SMART Values:
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
been run.
data collection: (41760) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 451) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x70bd) SCT Status supported.
SCT Data Table supported.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-K 200 200 051 - 0
3 Spin_Up_Time POS--K 142 142 021 - 11875
4 Start_Stop_Count -O--CK 100 100 000 - 30
5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0
7 Seek_Error_Rate -OSR-K 200 200 000 - 0
9 Power_On_Hours -O--CK 088 088 000 - 8760
10 Spin_Retry_Count -O--CK 100 253 000 - 0
11 Calibration_Retry_Count -O--CK 100 253 000 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 30
183 Runtime_Bad_Block -O--CK 100 100 000 - 0
192 Power-Off_Retract_Count -O--CK 200 200 000 - 19
193 Load_Cycle_Count -O--CK 200 200 000 - 10
194 Temperature_Celsius -O---K 103 094 000 - 49
196 Reallocated_Event_Count -O--CK 200 200 000 - 0
197 Current_Pending_Sector -O--CK 200 200 000 - 1
198 Offline_Uncorrectable ----CK 200 200 000 - 0
199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0
200 Multi_Zone_Error_Rate ---R-- 200 200 000 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 GPL R/O 6 Ext. Comprehensive SMART error log
0x04 GPL,SL R/O 8 Device Statistics log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x08 GPL R/O 2 Power Conditions log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters
0x24 GPL R/O 1 Current Device Internal Status Data log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa0-0xa7 GPL,SL VS 16 Device vendor specific log
0xa8-0xb7 GPL,SL VS 1 Device vendor specific log
0xbd GPL,SL VS 1 Device vendor specific log
0xc0 GPL,SL VS 1 Device vendor specific log
0xc1 GPL VS 93 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 10
CR = Command Register
FEATR = Features Register
COUNT = Count (was: Sector Count) Register
LBA_48 = Upper bytes of LBA High/Mid/Low Registers ] ATA-8
LH = LBA High (was: Cylinder High) Register ] LBA
LM = LBA Mid (was: Cylinder Low) Register ] Register
LL = LBA Low (was: Sector Number) Register ]
DV = Device (was: Device/Head) Register
DC = Device Control Register
ER = Error register
ST = Status register
Error 10 [9] occurred at disk power-on lifetime: 8559 hours (356 days + 15 hours)
ER -- ST COUNT LBA_48 LH LM LL DV DC
40 -- 51 00 00 00 00 f9 bd 3b e8 40 00 Error: UNC at LBA = 0xf9bd3be8 = 4189928424
CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name
60 01 00 00 c8 00 00 f9 bd 3b 80 40 08 19d+04:17:33.265 READ FPDMA QUEUED
2f 00 00 00 01 00 00 00 00 00 10 40 08 19d+04:17:33.262 READ LOG EXT
60 01 00 00 c8 00 00 f9 bd 75 50 40 08 19d+04:17:31.267 READ FPDMA QUEUED
60 01 00 00 c0 00 00 f9 bd 3b 80 40 08 19d+04:17:31.267 READ FPDMA QUEUED
2f 00 00 00 01 00 00 00 00 00 10 40 08 19d+04:17:31.264 READ LOG EXT
Error 9 [8] occurred at disk power-on lifetime: 8559 hours (356 days + 15 hours)
60 01 00 00 c0 00 00 f9 bd 75 50 40 08 19d+04:17:29.296 READ FPDMA QUEUED
60 01 00 00 c0 00 00 f9 bd 74 50 40 08 19d+04:17:29.295 READ FPDMA QUEUED
Error 8 [7] occurred at disk power-on lifetime: 8559 hours (356 days + 15 hours)
60 01 00 00 c0 00 00 f9 bd 73 50 40 08 19d+04:17:29.294 READ FPDMA QUEUED
60 01 00 00 c0 00 00 f9 bd 72 50 40 08 19d+04:17:29.293 READ FPDMA QUEUED
60 01 00 00 c0 00 00 f9 bd 71 50 40 08 19d+04:17:29.293 READ FPDMA QUEUED
Error 7 [6] occurred at disk power-on lifetime: 8559 hours (356 days + 15 hours)
60 01 00 00 b8 00 00 f9 bd 6c 50 40 08 19d+04:17:27.299 READ FPDMA QUEUED
60 01 00 00 b8 00 00 f9 bd 6b 50 40 08 19d+04:17:27.298 READ FPDMA QUEUED
60 00 d0 00 b8 00 00 f9 bd 6a 80 40 08 19d+04:17:27.297 READ FPDMA QUEUED
60 01 00 00 b8 00 00 f9 bd 69 80 40 08 19d+04:17:27.296 READ FPDMA QUEUED
60 01 00 00 b8 00 00 f9 bd 68 80 40 08 19d+04:17:27.296 READ FPDMA QUEUED
Error 6 [5] occurred at disk power-on lifetime: 8559 hours (356 days + 15 hours)
60 01 00 00 b0 00 00 f9 bd 62 60 40 08 19d+04:17:25.293 READ FPDMA QUEUED
60 01 00 00 b0 00 00 f9 bd 61 48 40 08 19d+04:17:25.291 READ FPDMA QUEUED
60 00 08 00 b0 00 00 f9 bd 5f f8 40 08 19d+04:17:25.290 READ FPDMA QUEUED
60 01 00 00 a8 00 00 f9 bd 3b 80 40 08 19d+04:17:25.281 READ FPDMA QUEUED
61 00 10 00 a8 00 00 00 40 02 90 40 08 19d+04:17:25.257 WRITE FPDMA QUEUED
Error 5 [4] occurred at disk power-on lifetime: 8559 hours (356 days + 15 hours)
60 01 00 00 48 00 00 f9 bd 3c 80 40 08 19d+04:17:23.200 READ FPDMA QUEUED
60 01 00 00 40 00 00 f9 bd 3b 80 40 08 19d+04:17:23.200 READ FPDMA QUEUED
2f 00 00 00 01 00 00 00 00 00 10 40 08 19d+04:17:23.198 READ LOG EXT
60 01 00 00 40 00 00 f9 bd 3c 80 40 08 19d+04:17:21.219 READ FPDMA QUEUED
60 01 00 00 38 00 00 f9 bd 3b 80 40 08 19d+04:17:21.219 READ FPDMA QUEUED
Error 4 [3] occurred at disk power-on lifetime: 8559 hours (356 days + 15 hours)
2f 00 00 00 01 00 00 00 00 00 10 40 08 19d+04:17:21.216 READ LOG EXT
60 01 00 00 38 00 00 f9 bd 3c 80 40 08 19d+04:17:19.229 READ FPDMA QUEUED
60 01 00 00 30 00 00 f9 bd 3b 80 40 08 19d+04:17:19.229 READ FPDMA QUEUED
Error 3 [2] occurred at disk power-on lifetime: 8559 hours (356 days + 15 hours)
2f 00 00 00 01 00 00 00 00 00 10 40 08 19d+04:17:19.227 READ LOG EXT
60 00 08 00 30 00 00 f9 bd d9 d8 40 08 19d+04:17:17.239 READ FPDMA QUEUED
60 01 00 00 28 00 00 f9 bd 3c 80 40 08 19d+04:17:17.239 READ FPDMA QUEUED
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1 Extended offline Completed without error 00% 8029 -
# 2 Extended offline Completed without error 00% 7373 -
# 3 Extended offline Completed without error 00% 6702 -
# 4 Extended offline Completed without error 00% 5862 -
# 5 Extended offline Completed without error 00% 5201 -
# 6 Extended offline Completed without error 00% 4375 -
# 7 Extended offline Completed without error 00% 3703 -
# 8 Extended offline Completed without error 00% 3033 -
# 9 Extended offline Completed without error 00% 2366 -
#10 Extended offline Completed without error 00% 1526 -
#11 Extended offline Completed without error 00% 857 -
#12 Extended offline Completed without error 00% 642 -
#13 Extended offline Interrupted (host reset) 50% 469 -
#14 Extended offline Completed without error 00% 305 -
#15 Extended offline Completed without error 00% 27 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Status Version: 3
SCT Version (vendor specific): 258 (0x0102)
SCT Support Level: 1
Device State: Active (0)
Current Temperature: 49 Celsius
Power Cycle Min/Max Temperature: 22/54 Celsius
Lifetime Min/Max Temperature: 18/58 Celsius
Under/Over Temperature Limit Count: 0/0
SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 1 minute
Min/Max recommended Temperature: 0/60 Celsius
Min/Max Temperature Limit: -41/85 Celsius
Temperature History Size (Index): 478 (386)
Index Estimated Time Temperature Celsius
387 2015-11-02 02:55 50 *******************************
... ..( 9 skipped). .. *******************************
397 2015-11-02 03:05 50 *******************************
398 2015-11-02 03:06 49 ******************************
... ..(387 skipped). .. ******************************
308 2015-11-02 09:34 49 ******************************
309 2015-11-02 09:35 50 *******************************
... ..( 18 skipped). .. *******************************
328 2015-11-02 09:54 50 *******************************
329 2015-11-02 09:55 51 ********************************
... ..( 10 skipped). .. ********************************
340 2015-11-02 10:06 51 ********************************
341 2015-11-02 10:07 50 *******************************
... ..( 44 skipped). .. *******************************
386 2015-11-02 10:52 50 *******************************
SCT Error Recovery Control:
Read: 70 (7.0 seconds)
Write: 70 (7.0 seconds)
Device Statistics (GP Log 0x04)
Page Offset Size Value Description
1 ===== = = == General Statistics (rev 2) ==
1 0x008 4 30 Lifetime Power-On Resets
1 0x010 4 8760 Power-on Hours
1 0x018 6 58548614156 Logical Sectors Written
1 0x020 6 213734372 Number of Write Commands
1 0x028 6 44589828420 Logical Sectors Read
1 0x030 6 200099955 Number of Read Commands
3 ===== = = == Rotating Media Statistics (rev 1) ==
3 0x008 4 8049 Spindle Motor Power-on Hours
3 0x010 4 8049 Head Flying Hours
3 0x018 4 30 Head Load Events
3 0x020 4 200~ Number of Reallocated Logical Sectors
3 0x028 4 14 Read Recovery Attempts
3 0x030 4 0 Number of Mechanical Start Failures
4 ===== = = == General Errors Statistics (rev 1) ==
4 0x008 4 10 Number of Reported Uncorrectable Errors
4 0x010 4 10 Resets Between Cmd Acceptance and Completion
5 ===== = = == Temperature Statistics (rev 1) ==
5 0x008 1 49 Current Temperature
5 0x010 1 49 Average Short Term Temperature
5 0x018 1 50 Average Long Term Temperature
5 0x020 1 58 Highest Temperature
5 0x028 1 25 Lowest Temperature
5 0x030 1 57 Highest Average Short Term Temperature
5 0x038 1 42 Lowest Average Short Term Temperature
5 0x040 1 53 Highest Average Long Term Temperature
5 0x048 1 43 Lowest Average Long Term Temperature
5 0x050 4 0 Time in Over-Temperature
5 0x058 1 60 Specified Maximum Operating Temperature
5 0x060 4 0 Time in Under-Temperature
5 0x068 1 0 Specified Minimum Operating Temperature
6 ===== = = == Transport Statistics (rev 1) ==
6 0x008 4 164 Number of Hardware Resets
6 0x010 4 437 Number of ASR Events
6 0x018 4 0 Number of Interface CRC Errors
|_ ~ normalized value
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 2 0 Command failed due to ICRC error
0x0002 2 0 R_ERR response for data FIS
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0005 2 0 R_ERR response for non-data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
0x0008 2 0 Device-to-host non-data FIS retries
0x0009 2 8 Transition from drive PhyRdy to drive PhyNRdy
0x000a 2 9 Device-to-host register FISes sent due to a COMRESET
0x000b 2 0 CRC errors within host-to-device FIS
0x000f 2 0 R_ERR response for host-to-device data FIS, CRC
0x0012 2 0 R_ERR response for host-to-device non-data FIS, CRC
0x8000 4 2380133 Vendor specific
I wasn't expecting such a quick response, sorry for my lateness, and thank you for your reply !!!
