[root@freenaspol] /# zpool status
pool: VOLUME1
state: ONLINE
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see:
http://illumos.org/msg/ZFS-8000-8A
scan: scrub repaired 0 in 5h18m with 55 errors on Sun Sep 20 05:18:43 2015
NAME STATE READ WRITE CKSUM
VOLUME1 ONLINE 0 0 0
gptid/d1801141-f885-11e2-9326-9c8e9908a74c ONLINE 0 0 0
errors: 3 data errors, use '-v' for a list
pool: VOLUME2
state: ONLINE
status: The pool is formatted using a legacy on-disk format. The pool can
still be used, but some features are unavailable.
action: Upgrade the pool using 'zpool upgrade'. Once this is done, the
pool will no longer be accessible on software that does not support feature
flags.
scan: scrub repaired 0 in 2h13m with 0 errors on Sun Sep 20 02:13:46 2015
VOLUME2 ONLINE 0 0 0
gptid/e4769134-f885-11e2-9326-9c8e9908a74c ONLINE 0 0 0
errors: No known data errors
pool: VOLUME3
state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
scan: scrub repaired 0 in 7h11m with 0 errors on Sun Sep 6 07:11:26 2015
VOLUME3 ONLINE 0 0 0
gptid/bc0208bb-29f5-11e3-a7a7-9c8e9908a74c ONLINE 0 0 0
pool: freenas-boot
state: ONLINE
scan: none requested
freenas-boot ONLINE 0 0 0
ada0p2 ONLINE 0 0 0
[root@freenaspol] /# smartctl -a /dev/ada1
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p26 amd64] (local build)
Copyright (C) 2002-14, Bruce Allen, Christian Franke,
www.smartmontools.org
Model Family: Western Digital Caviar Green (AF, SATA 6Gb/s)
Device Model: WDC WD20EARX-00PASB0
Serial Number: WD-WCAZAH949508
LU WWN Device Id: 5 0014ee 2b20786b8
Firmware Version: 51.0AB51
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Thu Oct 8 14:29:21 2015 EDT
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed.
data collection: (39900) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 384) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x3035) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 199 199 051 Pre-fail Always - 9314
3 Spin_Up_Time 0x0027 186 162 021 Pre-fail Always - 5683
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 40
5 Reallocated_Sector_Ct 0x0033 160 160 140 Pre-fail Always - 1695
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 067 067 000 Old_age Always - 24754
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 36
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 18
193 Load_Cycle_Count 0x0032 001 001 000 Old_age Always - 1479214
194 Temperature_Celsius 0x0022 123 114 000 Old_age Always - 27
196 Reallocated_Event_Count 0x0032 001 001 000 Old_age Always - 442
197 Current_Pending_Sector 0x0032 198 195 000 Old_age Always - 817
198 Offline_Uncorrectable 0x0030 193 193 000 Old_age Offline - 2397
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 148 148 000 Old_age Offline - 13955
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed: read failure 90% 24748 676876826
# 2 Extended offline Completed: read failure 90% 24732 676883541
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
