strangelove
- Dec 27, 2017
I am new to FreeNAS. I just finished my first build (Supermicro X11SSM-F, Sandisk Plus SSD as boot device, 16 GB Kingston EEC memory). I already tried several times to install FreeNAS 11.1 onto the Sandisk Plus SSD. No matter what I try, sooner or later I am ending up with a critical error:
Also, I did run a complete pass of memtest86+, which did not report any errors.
I have 6 x WD Red 4TB (the X11SSM-F has 8 sata ports, but the first two also support Sata DOM, I have the boot device (Sandisk Plus SSD) connected to one of those, this should be fine, right (It is also connected to power)?
Another side note: I only tried installing in UEFI, maybe I should try to install via legacy BIOS (although I don't think this should make a difference...)?
Any ideas?
The boot volume state is ONLINE: One or more devices has experienced an error resulting in data corruption. Applications may be affected.
zpool status -vCode:
pool: freenas-boot state: ONLINE status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: http://illumos.org/msg/ZFS-8000-8A scan: none requested config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 1 ada0p2 ONLINE 0 0 2 errors: Permanent errors have been detected in the following files: //conf/base/etc/remote
smartctl -a /dev/ada0Code:
smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.1-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Device Model: SanDisk SSD PLUS 120 GB Serial Number: 174500469107 LU WWN Device Id: 5 001b44 4a9b2567f Firmware Version: UE3000RL User Capacity: 120,040,980,480 bytes [120 GB] Sector Size: 512 bytes logical/physical Rotation Rate: Solid State Device Form Factor: 2.5 inches Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ACS-2 T13/2015-D revision 3 SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Thu Jan 11 05:26:10 2018 PST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 32) The self-test routine was interrupted by the host with a hard or soft reset. Total time to complete Offline data collection: ( 120) seconds. Offline data collection capabilities: (0x15) SMART execute Offline immediate. No Auto Offline data collection support. Abort Offline collection upon new command. No Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. No Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 21) minutes. SMART Attributes Data Structure revision number: 1 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 5 Reallocated_Sector_Ct 0x0032 100 100 000 Old_age Always - 0 9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 4 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 32 165 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 3 166 Unknown_Attribute 0x0032 100 100 --- Old_age Always - 0 167 Unknown_Attribute 0x0032 100 100 --- Old_age Always - 0 168 Unknown_Attribute 0x0032 100 100 --- Old_age Always - 0 169 Unknown_Attribute 0x0032 100 100 --- Old_age Always - 130 170 Unknown_Attribute 0x0032 100 100 --- Old_age Always - 0 171 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0 172 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0 173 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0 174 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 20 184 End-to-End_Error 0x0032 100 100 --- Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 100 --- Old_age Always - 0 194 Temperature_Celsius 0x0022 070 037 000 Old_age Always - 30 (Min/Max 0/37) 199 UDMA_CRC_Error_Count 0x0032 100 100 --- Old_age Always - 0 230 Unknown_SSD_Attribute 0x0032 100 100 000 Old_age Always - 0 232 Available_Reservd_Space 0x0033 100 100 005 Pre-fail Always - 100 233 Media_Wearout_Indicator 0x0032 100 100 --- Old_age Always - 0 234 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 19 241 Total_LBAs_Written 0x0030 100 100 000 Old_age Offline - 5 242 Total_LBAs_Read 0x0030 100 100 000 Old_age Offline - 2 244 Unknown_Attribute 0x0032 000 100 --- Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 No self-tests have been logged. [To run self-tests, use: smartctl -t] Selective Self-tests/Logging not supported
Any ideas?
