Hi Guys,
I've just been upgrading my system to finally to have EEC ram and and then discovered I have a boot drive error.
Gives me:
So, my data appears to be good but I have an error in python3.6.core, and how do I fix this? What other steps should I take to ensure this is the only problem? Would a simple fresh install fix this, or can I get a new copy of python.3.6.core (and if so how?)
Everything appears to be working... (though I'm not doing anything mission critical atm - that's why I upgraded my system to include EEC).
Oh, and I've run a boot scrub, but the error is still there. And I verified my install, and that seems ok too.
Thanks
zpool status -v | moreGives me:
---SNIP---- errors: No known data errors pool: freenas-boot state: ONLINE status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: http://illumos.org/msg/ZFS-8000-8A scan: scrub repaired 0 in 0 days 00:01:25 with 1 errors on Wed Jun 20 09:44:47 2018 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 1 gptid/cf3f6c4b-74f3-11e5-80ca-c86000c046f4 ONLINE 0 0 2 errors: Permanent errors have been detected in the following files: freenas-boot/ROOT/11.1-U5@2018-06-20-09:24:46:/python3.6.core
Thanks
