Not sure if this is the correct section to post this in, but I have an error in my boot drive after a scrub. My system has been up and running for 7 weeks or so. Do I need to replace my flash drive with a better quality drive, or is this somehow correctable.
This is the info from one of my daily emails I set up.
########## ZPool status report summary for all pools on server FREENAS ##########
|Pool Name |Status |Read |Write |Cksum |Used|Frag|Scrub |Scrub |Last |
| | |Errors|Errors|Errors| | |Repaired|Errors|Scrub|
| | | | | | | |Bytes | |Age |
|freenas-boot !|ONLINE | 0| 0| 5| 14%| | 0| 1| 0|
|one |ONLINE | 0| 0| 0| 9%| 5%| 0| 0| 9|
|two |ONLINE | 0| 0| 0| 3%| 3%| 0| 0| 9|
########## ZPool status report for freenas-boot ##########
pool: freenas-boot
state: ONLINE
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: http://illumos.org/msg/ZFS-8000-8A
scan: scrub repaired 0 in 0h20m with 1 errors on Tue Oct 17 04:05:20 2017
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 1
da0p2 ONLINE 0 0 4
//usr/local/lib/python3.6/config-3.6m/Makefile
| | | | | | | |Bytes | |Age |
pool: freenas-boot
state: ONLINE
da0p2 ONLINE 0 0 4
