permanent errors in freenas_system.txt
qubit
HP N54L
AMD Turion(tm) II Neo N54L Dual-Core Processor
RAM - 16GB
HDD - x4 Seagate 2TB 7200.14 7200rpm ST2000DM001
FreeNAS-9.3-STABLE-201512121950
no encryption
Is it possible to replace or edit just the freenas_system.txt ?
Or how should I proceed?
error email and a subsequent spool status check:
[code}
[root@freenas ~]# zpool status -x
pool: freenas-boot
state: ONLINE
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: http://illumos.org/msg/ZFS-8000-8A
scan: scrub repaired 0 in 0h4m with 1 errors on Tue Jun 7 03:49:44 2016
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 4
da0p2 ONLINE 0 0 8
errors: 1 data errors, use '-v' for a list
[root@freenas ~]#
[root@freenas ~]# zpool status -v
pool: ctx
state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
still be used, but some features are unavailable.
scan: scrub repaired 0 in 2h56m with 0 errors on Sun Jun 5 02:56:13 2016
ctx ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/860cc9f3-80c6-11e3-a06b-c8cbb8c52320 ONLINE 0 0 0
gptid/86661916-80c6-11e3-a06b-c8cbb8c52320 ONLINE 0 0 0
gptid/86be2f29-80c6-11e3-a06b-c8cbb8c52320 ONLINE 0 0 0
gptid/874297bc-80c6-11e3-a06b-c8cbb8c52320 ONLINE 0 0 0
errors: No known data errors
pool: freenas-boot
state: ONLINE
da0p2 ONLINE 0 0 8
//usr/local/www/data/docs/_sources/freenas_system.txt
[root@freenas ~]#
[/code]
thanks
Sakuru
Get 2 new sticks and mirror them this time :)
qubit
thanks anodos and Sakura. OS is on an 8GB Compact Flash, I'll get 2 more...
