[SOLVED] Critical Alert - SickRage corrupted
henrique
I'm getting one critical alert and I don't know how to fix it. Can you please try to help me?
The output of zpool status -v:
pool: Data
state: ONLINE
  scan: scrub repaired 0 in 0h33m with 0 errors on Sun Oct 18 04:33:12 2015
        NAME                                          STATE     READ WRITE CKSUM
        Data                                          ONLINE       0     0     0
          gptid/e5b75fab-38d8-11e3-9a06-3cd92b0c1f4e  ONLINE       0     0     0
errors: No known data errors
  pool: freenas-boot
state: ONLINE
  scan: scrub repaired 0 in 0h5m with 0 errors on Thu Nov  5 03:50:17 2015
        freenas-boot  ONLINE       0     0     0
          da0p2     ONLINE       0     0     0
  pool: mediacenter
state: ONLINE
        corruption.  Applications may be affected.
action: Restore the file in question if possible.  Otherwise restore the
        entire pool from backup.
   see: http://illumos.org/msg/ZFS-8000-8A
  scan: scrub repaired 0 in 3h51m with 1 errors on Sun Nov  1 03:51:27 2015
        mediacenter                                   ONLINE       0     0     0
          gptid/161b6de3-17d7-11e3-afbd-3cd92b0c1f4e  ONLINE       0     0     0
          gptid/169af013-17d7-11e3-afbd-3cd92b0c1f4e  ONLINE       0     0     0
          gptid/1749c828-17d7-11e3-afbd-3cd92b0c1f4e  ONLINE       0     0     0
        /mnt/mediacenter/jails/sickrage_1/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/tornado/platform
I know it's something related with SickRage plugin, but I searched on forum and seems that nobody has the same problem.
Thanks in advance
The problem is data corruption on your pool--it just happens to be in one of the files of your sickrage plugin. Since you built your pool with no redundancy, ZFS has no way to fix the corrupted data. Your only real option is to delete and reinstall the plugin.
henrique
Thanks for the quick reply!
Now a newbie question: there is an easy way to create some redundancy? I just want to avoid this in the future.
There really isn't a way to add redundancy at this point. Unfortunately, the only real answer would be to back up your data, destroy the pool, and rebuild it in a redundant configuration (RAIDZ).
henrique
Hi again,
After removing and installing the sickrage plugin, I still have the critical alert. Should I run something to refresh the state of freenas?
Joshua Parker Ruehlig
Hi again,
a zpool scrub would clear that
to as to Dan's earlier comment, you could actually add redundancy if you want to go with a mirror. you could add a mirrored drive to your current setup.
most consumers go with raidz/2 setups because you get more utilization of your drive space with more drives. in that case you can't migrate directly from your current zpool
Since his pool appears to consist of a single vdev (with three disks striped), I didn't it would be possible to add mirrors to each of them. I haven't tried it, though, so I could certainly be wrong.
whoops your right! I only looked at the first pool which is obviously his freenas-boot
